Old 04-15-2021, 07:18 PM #1
Langcow1 Langcow1 is offline
Real Name: Matt
Langcow1 is on a distinguished road
Real Name: Matt
Side to side rocking on highway
A quick question for the 4runner hivemind:
My 1999 4runner has 275,000 miles and I’ve just re-done pretty much all of the front assembly. I’m noticing now in certain situations on the highway I get an extreme rocking side to side. It doesn’t happen all the time, just when I’m on a weird bit of paving or I hit a bump just right. But the rocking is dramatic when it happens. My guess is that I need new coils and shocks. Maybe having the front all tight now puts more pressure on the old suspension? Is there anything else I should be considering as the cause? I never noticed it before the front work, but honestly it’s possible that those are still original coils and shocks.
Thanks for your advice and comments.
1999 SR5 manual 4WD; 300,000 miles!
Langcow1 is offline   Reply With QuoteReply With Quote
Old 04-15-2021, 07:35 PM #2
GhostRing's Avatar
GhostRing GhostRing is online now
GhostRing will become famous soon enough GhostRing will become famous soon enough
GhostRing's Avatar
At that mileage,just about every factory bushing on the rig is likely roached. I had a pretty bad sway/wander as well and found the rear lower arms pretty much had no usable rubber inside them.
This was even present with the new OME springs and Billies, so just those alone may not be the solution...
Build Etc...
If it ain't broke, fix it 'til it is.
GhostRing is online now   Reply With QuoteReply With Quote
Old 04-15-2021, 08:18 PM #3
calicojax's Avatar
calicojax calicojax is offline
calicojax is on a distinguished road
calicojax's Avatar
The shocks and struts can cause this.. I'm with Ghostring on control arm bushings. Also if you're lifted the panhard angle could be the issue. I went with Whitline bushings. They helped a lot (except they squeak). Emkieth kit for the pan hard. Problem solved.
calicojax is offline   Reply With QuoteReply With Quote
Old 04-15-2021, 08:56 PM #4
Real Name: Matt
Real Name: Matt
Ok thanks. I’ll check out those bushings. The only ones done so far are the front and back sway bar bushings. I’ve got new shocks waiting to be installed & I’ll order some coils.
Oh it’s not lifted.
Old 04-15-2021, 09:08 PM #5
Ted02 Ted02 is offline
Ted02 is on a distinguished road
Did you happen to get new tires also? Tread design can give a rocking side to side feeling when on some surfaces also. My new Cooper At3 4s tires cause my 4runner to rock side to side when I’m on new concrete sections of I-80, where they trowelled small groves in the concrete. I have Goodrich Rugged Trails on my ‘01 Tacoma and zero rocking on the same section of freeway. I hate the feeling, but getting used to it.
Some of your symptoms suggest other issues, but thought I’d throw it out there anyway.
2002 4Runner SR5 4WD 3.4L Thundercloud
2001 Tacoma Xtracab TRD 4WD 3.4L Black Sand Pearl (original owner)
1971 El Camino (second owner, purchased in ‘81)
2010 Cadillac DTS
Too many cars, but love them all!
Ted02 is offline   Reply With QuoteReply With Quote
Old 04-15-2021, 09:15 PM #6
Real Name: Matt
Real Name: Matt
Not new tires but they did get rotated. They still have decent tread but are worn unevenly because of the other issues. I figured I’d replace them after dealing with the front end and suspension. The tires could definitely be the culprit though, since the problem popped up recently and it really seems connected to the pavement conditions.
Old 04-15-2021, 09:25 PM #7
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
i will go for rear control arm bushings and panhard rod bushings.....esp if any kind of lift
Old 04-16-2021, 05:24 AM #8
thennen's Avatar
thennen thennen is offline
thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold
thennen's Avatar
You're in CA so likely not a rust problem. My 2001 at 265k had had enough Ohio road salt, and the right rear control arm bracket weld gave out, causing unnerving swaying on its final drive to be traded.
thennen is offline   Reply With QuoteReply With Quote
coils , front , rocking , shocks , side
Rocking at highway speed eanema 3rd gen T4Rs 25 08-08-2017 04:42 PM
Clunking sound with light side to side movement after in rear after 3" lift BXPhoto 3rd gen T4Rs 1 11-24-2016 11:53 PM
WTB 2013 4runner passenger side rocker panel side skirt vinodmp Want to Buy/Trade 0 10-27-2014 10:52 AM
Stuck on side of highway yota-runner 3rd gen T4Rs 7 08-05-2013 07:31 PM
