Old 04-15-2021, 07:46 PM #1
St Runner's Avatar
St Runner St Runner is offline
St Runner will become famous soon enough
St Runner's Avatar
Bead lock fun
A couple years ago I picked up a used set of KMC XD series rims with some half done Koyo M/T open country 285's. The tires are completely worn out now so i picked up a set of BF Goodrich KO2's and after researching a little bit decided to change them out myself. That and not trusting anyone local to do it since they have probably never seen a bead-lock. Well its not going so good. The ring refuses to come off. I carefully pried it, banged on it with a rubber mallet and even put 30lbs of air pressure in the tire with the ring unbolted. I finally broke the bead on the back side but it took 7 or 8 passes with both 4runners. Its like they red locktited the tire on. I put some deep creep in all the ring holes and will let it sit until sunday when I have more time to work on it. I take it this is not normal at least from the videos I watched. I figured I had 4 hours and could get a couple done but have not even got the first tire off. Any suggestions would be appreciated
Bead lock fun-img_0977-jpg
1997 SR5 4x4
R150f swap E-locked 4.30 gears
Tundra 231 brakes LC 80 rims 285/75/16
2001 SR5 4x4
St Runner is offline   Reply With QuoteReply With Quote
Old 04-15-2021, 08:44 PM #2
cl4Rk's Avatar
cl4Rk cl4Rk is offline
cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold
cl4Rk's Avatar
Apply some heat? IDK
2000 SR-5 V6 4x4 Auto
"Ol' Ruby" - build thread
@Y2K_4X4
cl4Rk is offline   Reply With QuoteReply With Quote
Old 04-15-2021, 10:12 PM #3
St Runner's Avatar
St Runner's Avatar
Thanks cl4Rk, but I am not sure I want to use much heat on painted aluminum. It is possible I could just burn the whole tire off, but that is not the most environmentally friendly solution
1997 SR5 4x4
2001 SR5 4x4
Old 04-16-2021, 01:12 AM #4
HiLife HiLife is offline
Did you try tightening the bolt up a bit (breaking any kind of surface corrosion), then try loosening it.
Or you could use vibration in form of an impact and or a pneumatic hammer on the bolt.
Old 04-16-2021, 07:30 AM #5
St Runner's Avatar
St Runner's Avatar
Thanks HiLife, I will give that a try. I tried to put a longer bolt in there to lift the ring but the ring bolts seem to be a finer not common thread, and being it is just threaded into aluminum I need to be careful.
1997 SR5 4x4
2001 SR5 4x4
Old 04-17-2021, 06:59 PM #6
St Runner's Avatar
St Runner's Avatar
Well i figured out the problem and once again its me. Took a careful look this afternoon with a mirror and a light and its a fake bead lock. The "ring" is simply part of the rim with bolts for show. Now I can just bring it to the local garage where they can change it with a machine. Its not a problem they are not real bead locks, I bought them because they were cheap and I liked the way they looked. Its harder to admit I am an idiot but since that is the truth you guys are going to have to deal with that
Bead lock fun-img_0981-jpg
1997 SR5 4x4
2001 SR5 4x4
Old 04-17-2021, 09:24 PM #7
Endlessblockades's Avatar
Real Name: Blair
Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold
Real Name: Blair
HAHA - laugh it off - I am usually my own worst enemy! I was going to ask for a pic of the beadlock side, but then I thought better of it - never had a set, so WTF would I know anyway?
Old 04-17-2021, 10:06 PM #8
St Runner's Avatar
St Runner's Avatar
I have never owned a set of bead locks either and I still haven't.
1997 SR5 4x4
2001 SR5 4x4
Old 04-17-2021, 10:51 PM #9
Lol, I had that in the back of my mind and wondered if those were true beadlocks. No harm no foul, just got to laugh about the moment.
Too many serious things going on right now everywhere else.
I can appreciate times where I can just laugh it off by myself or with friends.
bead , couple , put , ring , tire
To Bead Lock or Not Dad's Toy 5th gen T4Rs 19 04-29-2021 02:18 PM
WTB Trd bead lock rims in 17 I know it’s a unicorn Mudballz For Sale: Suspension/Wheels/Tires 10 05-07-2020 03:25 PM
FS: ME, BFG KM2 285 70 17 on bead lock wheels Quadsbc For Sale: Suspension/Wheels/Tires 5 03-10-2015 07:53 PM
Bead Lock Wheels trijicon Off-Roading 2 03-09-2006 11:44 AM
Can someone please explain Bead Lock to me? Cleric 4th Gen T4Rs 2 05-11-2005 08:50 PM
