Old 04-16-2021, 02:01 AM #1
Langcow1 Langcow1 is offline
Real Name: Matt
Langcow1 is on a distinguished road
Real Name: Matt
Matching front OME coils to rear
I’m having a hard time figuring out which Old Man Emu front coils to match to the rears. I have a 1999 and I want to keep it somewhat similar to stock. I got a set of 4 Bilstein 4600s, and I am looking at the OME 2890 springs for the rear. But what I can’t figure out is which front springs would be the right match. 2880s?
I was leaning towards 2880s until I saw Wheelers Offroad has a set with 2890 rears and 2882s for the front. I’m not sure why they paired them that way - it doesn’t seem like the right match but I could be wrong. Is there a chart somewhere? I’ve searched and haven’t found one.
Thanks for your help.
1999 SR5 manual 4WD; 300,000 miles!
Langcow1 is offline   Reply With QuoteReply With Quote
Old 04-16-2021, 02:04 AM #2
Real Name: Matt
Real Name: Matt
Here’s what Wheelers says about the rear 2890s:
* Provides a slightly firmer than stock ride, with approx 2.5" of lift for '96-'02 4Runner
* Great for maintaining ride height and load stability while hauling up to 200-300lbs of extra weight
Old 04-16-2021, 10:34 AM #3
fourfive's Avatar
fourfive fourfive is offline
fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough
fourfive's Avatar
Do you have a stock front end?
-If you do then that will rule in 880 & 881 for OME.
How much rake do you want?
-If you want the rear to sit about 1" higher then 880.
-If you want the rear to sit about .5" higher then 881.
Do you have height adjustable shocks?
-Gives the ability to fine tune your ride height.
Wheeler's is correct. 890s gave me about 2.5" rear lift (22.5" center hub to fender) & about 2.75" with no cargo load.
1. Black 2002 SR5 4x4 5vz: Front Toytec Ultimate coilovers/eibach 600#, SPC UCA, durobumps Rear Bil5100/Superflex, SS adjustable panhard, PCK, durobumps Body Lift 2" 4crawler Tires 315/75/16 BFG KO2 Wheels SCS F5 Matte black 16x8 3.5bs Armor Custom bolt on rock sliders (no frame drilling)
2. Black 2001 SR5 4x4 5vz: stock
3. Black 2018 TRD Pro (wife’s): Armor Custom bolt on rock sliders (U-bolts)
fourfive is offline   Reply With QuoteReply With Quote
Old 04-16-2021, 03:19 PM #4
Real Name: Matt
Real Name: Matt
Yep everything is stock. No lift
Old 04-16-2021, 06:03 PM #5
Real Name: Matt
Real Name: Matt
So I called Wheelers and they recommended the 2881s. Also, thank you for the info re: the difference in height of the 2880 and 2881. That helped me visualize it better.
Old 04-16-2021, 06:11 PM #6
Endlessblockades's Avatar
Real Name: Blair
Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold
Real Name: Blair
No help, but I am running OME 881F/906R Basic setup, medium weight.
Old 04-16-2021, 07:07 PM #7
Real Name: Matt
Real Name: Matt
I did go ahead and order the 881s for the front. How do you like yours?
Old 04-16-2021, 07:19 PM #8
Real Name: Blair
Real Name: Blair
If you're asking me, they are OK, but I know a lot more abpout mountain bike suspension than trucks, I'm afraid. It feels a bit 'stiff' for lack of better term. I will eventually be adding a plate bumper, so I think it will easily support that. I don't know what shocks you are running, but that will have a lot to do with your outcome. I'm on the standard 5100s on the bottom perch (about 2" lift). My whole rig sounds like a "skeleton in a filing cabinet" (stolen from another poster here) going down the trail, so I'm usually not paying attention to the nuances of front spring travel.......LOL. It handles what I need it to in terms of obstacles just fine.....
Old 04-16-2021, 09:54 PM #9
Real Name: Matt
Real Name: Matt
Thanks - yeah it sounds like they should be fine for me. Definitely less expensive than OEM too
2880s , front , match , rears , springs
3rd gen matching front and rear 4.10 differentials 29 Palms CA Kryptoroxx For Sale: T4R Items 2 09-29-2014 07:45 PM
Matching Fronts to LC Coils Alabamaguy 3rd gen T4Rs 23 09-25-2011 04:15 AM
help w/adjustable 5100's matching LC coils 01t4rnr 3rd gen T4Rs 7 11-09-2010 05:32 PM
35/75/r16 on lc's and matching front coils, will it fit? theizzardking 3rd gen T4Rs 11 09-22-2009 11:56 PM
