Old 04-16-2021, 05:48 PM #1
Langcow1 Langcow1 is offline
Langcow1 is on a distinguished road
Newby question re: Starter
I need to put in a new starter and I havenít done it before. I also need new valve cover gaskets. Are these two jobs related enough that I should do both at once or does doing one not matter to doing the other a few weeks later? I mean, I need the starter now, but is it going to be more labor to hold off on the valve cover gaskets for a different weekend?
1999 SR5 manual 4WD; 275,000 miles
Langcow1 is offline   Reply With QuoteReply With Quote
Old 04-16-2021, 05:58 PM #2
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot has a spectacular aura about Devbot has a spectacular aura about Devbot has a spectacular aura about
Devbot's Avatar
Real Name: Devan
Completely different jobs. Do the starter now if you need to.
Y2K Highlander Millennium Silver 3.4L auto @ 290k and climbing
TRD coils / Tundra 5100s / Total Chaos Diff Drop / JBA UCAs / CVJ 9168R Axles / Dobinson 210v / Tokico Blacks / Vision Soft 8's / Widepeak AT3W 285s / EimKeith PCK / Spiker Hood Struts / Hood Scoop LED Mod / SRQ Corner Lights + Filler Panels + Grille w/ Raptor Lights / LED Interior / Durobump Front Stops / Daystar Rear Stops / Taco Antenna + Stereo / SS + Extended Brake Lines / Elbow Delete + ISR + O Gasket / TNF Open Wing Bumper / Smittybilt XRC Gen 3 Comp. / Northstar 880CCA AGM / Big 3 / Extended Rear Diff Breather / Drivelines NW Prop Rod
Old 04-16-2021, 06:21 PM #3
T4topher's Avatar
T4topher T4topher is online now
T4topher is a jewel in the rough T4topher is a jewel in the rough T4topher is a jewel in the rough
T4topher's Avatar
Might want to think about rebuilding your starter instead of buying a whole new one. Get OEM toyota parts, watch the timmy the toolman video. He has a video on both the starter and the valve cover gaskets.
T4Tophers build (click here)
T4topher is online now   Reply With QuoteReply With Quote
Old 04-16-2021, 06:25 PM #4
phattyduck has much to be proud of phattyduck has much to be proud of phattyduck has much to be proud of phattyduck has much to be proud of phattyduck has much to be proud of phattyduck has much to be proud of phattyduck has much to be proud of phattyduck has much to be proud of
I'd second this, or at least make sure you get a Denso or OEM starter.
The job is relatively easy with a 2WD, and a bit of a pain with a 4WD.
'16 Honda Odyssey
Old 04-16-2021, 06:54 PM #5
photoleif photoleif is offline
Real Name: Leif
photoleif will become famous soon enough
Real Name: Leif
make sure you have extensions and a swivel for your impact gun.
'99 'Highlander' 4R SR5 5VZ-FE | 5-spd | LED lighting | TBU | 265-75R17 Duratrac stuffed after some pinch-weld convincing
'95 Xtra cab 5VZ-FE swap 5-spd | 33x10.50-15 BFG AT/KOs | 4" Superlift | ARB rear locker | OME torsion bars | Total Chaos idler arm & uniball | Smittybilt bumpers | Sportsman topper | Aisin manual hubs | K&N | Dual Optimas | Extended diff breathers | Bilstein 5100s | De-striped | Hella pencil-beams
photoleif is offline   Reply With QuoteReply With Quote
Old 04-16-2021, 07:03 PM #6
I picked up a remanufactured one at NAPA. Am I going to regret that?
Old 04-16-2021, 08:47 PM #7
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Highly doubt it. I used a DB Electric starter I believe fwiw, definitely not OEM. Even had a random one from vatozone on my last truck and it lasted me 7-8 years until I sold it. Compare the noses to ensure the gearing is the same between the two before installing.
Don't forget to remove the upper half of the tranny fill tube to make the job 100x easier (disconnects just below the starter, one bolt up top and should pop right out)
Old 04-16-2021, 09:12 PM #8
Real Name: Leif
Real Name: Leif
good suggestion. guy i knew who is a toyota-certified mechanic by day rebuilt my 1995 truck's starter for me and it has been doing great going on eight years now. that's 27 years for the bulk of it this november.
@Langcow1 it looks like you've gone aftermarket. once you get your OEM starter out, it'd be nice to have it around to rebuild and keep for that hypothetical day when the new one doesn't live up to expectations. i've got an alternator sitting around for that reason.
Old 04-16-2021, 09:53 PM #9
Thatís a cool idea. I do have a core return but itís only like $40. No reason I couldnít keep it rather than return
Old 04-16-2021, 11:02 PM #10
Real Name: Leif
Real Name: Leif
cool. unless it's severely damaged for some reason, it's worth rebuilding. several threads here point to their longevity in general, and also as you're seeing, their life after a rebuild.
Old 04-17-2021, 09:57 PM #11
19963.4lsr5 is a glorious beacon of light 19963.4lsr5 is a glorious beacon of light 19963.4lsr5 is a glorious beacon of light 19963.4lsr5 is a glorious beacon of light 19963.4lsr5 is a glorious beacon of light
Any reman starter will be an OEM Denso. The starter from DB electric will be a knock off of a OEM Denso. You can roll the dice and see how long it lasts and put a OEM brush kit in it if it doesnít work out.
Old 04-17-2021, 10:26 PM #12
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Originally Posted by 19963.4lsr5 View Post
Any reman starter will be an OEM Denso. The starter from DB electric will be a knock off of a OEM Denso. You can roll the dice and see how long it lasts and put a OEM brush kit in it if it doesn’t work out.
What makes you think it's a knock off? I mean by that metric a Wix filter is just a knock off Toyota one
There was a DBE employee that browses this forum who seemed to stand behind their products, maybe I can find and tag them and they could better explain the differences if any
cover , gaskets , newby , starter , valve
Starter Question chale0118 4th Gen T4Rs 3 05-04-2015 02:26 AM
Starter Replacement Question kong 3rd gen T4Rs 5 06-07-2014 04:51 PM
Starter Question jlewis74 Classic T4Rs 13 07-22-2012 07:57 PM
Starter question 99Grunner 3rd gen T4Rs 11 02-18-2011 02:13 PM
starter / (?) question gimme789 Classic T4Rs 1 12-01-2008 03:35 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
