Old 04-29-2021, 12:45 AM #31
heat's Avatar
heat heat is offline
heat will become famous soon enough heat will become famous soon enough
heat's Avatar
15301-62070
1995-2004 Toyota Dipstick 15301-62070 | Toyota Parts
'02 Limited 4x4 AT - Stock ~181k miles
Thundercloud aka metallic dirt
heat is offline   Reply With QuoteReply With Quote
Old 04-29-2021, 09:08 AM #32
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Originally Posted by sean.turner.1238 View Post
I still need to recharge my AC system too as I discharged it when disassembling everything. Anybody know if I can just use the cans you can buy at auto parts stores for this? Or should I take it to a shop?
If you opened up the ac system you will need to pull a vacuum on the ac system before charging. It's easiest to just take it somewhere to do the whole process. I'd recommend changing the drier out before recharging the system since you had it open for more than 24 hours.
Old 04-29-2021, 11:55 AM #33
sean.turner.1238 sean.turner.1238 is offline
sean.turner.1238 is on a distinguished road
Originally Posted by heat View Post
Thank you
Sent from my Pixel 4 using Tapatalk
sean.turner.1238 is offline   Reply With QuoteReply With Quote
Old 04-29-2021, 11:57 AM #34
Okay. How much would something like that cost?
And is this the drier you're talking about?
Old 04-29-2021, 05:04 PM #35
Real Name: Patrick
Real Name: Patrick
That's the drier. I can't tell you because it varies vastly based on location. I would try calling around and asking. I don't remember how much it takes, but it shouldn't be more than 2 lbs of R134 refrigerant.
Old 04-30-2021, 10:56 AM #36
calimobber's Avatar
calimobber calimobber is offline
calimobber will become famous soon enough
calimobber's Avatar
I just replaced my A/C condenser and drier.
I just bought the vacuum pump and gauges on amazon for recharing(followed Chrisfix on youtube). I think everything including tools and new parts was less than $200.
It requires 20oz of R134a. 2 $6 cans at autozone was $12 for me.
My 2002 4runner Build : http://www.toyota-4runner.org/3rd-ge...r-project.html
calimobber is offline   Reply With QuoteReply With Quote
Old 04-30-2021, 12:37 PM #37
Soren96 Soren96 is offline
Soren96 is on a distinguished road
The gauges and vac pump is also part of the loaner tool programs at most auto parts stores if you don’t feel like building up your collection. It’s actually very easy to do.
If all you’re doing is replacing the drier, be sure to use plain old r134 cans and not the ones mixed with oil or any other crap. If the old dryer has a bunch of oil in it, you can put a similar amount back in the new one before assembly to keep the total system volume the same. A bit extra if a noticeable amount came out when you discharged.
Soren96 is offline   Reply With QuoteReply With Quote
Old 04-30-2021, 01:19 PM #38
How can I tell if there is oil in the old one? I watched the Chrisfix tutorial but I'd rather not spend the money on a tool I'll use so rarely
Old 04-30-2021, 05:35 PM #39
Remove the old one and measure how much oil drains out. Then add that much oil back into your system.
Old 05-02-2021, 11:51 AM #40
Got it thanks
Old 05-03-2021, 11:03 AM #41
Had to go in and pull my intake manifold just to get at this sensor. I could fit a deep 12mm socket over the broken one, but not the new one. So I pulled the manifold and used a combination wrench to get the new one on. I can now see my coolant temp woohoo
back , cams , exhaust , start , started
05 V6 head gaskets Monkeydad 4th Gen T4Rs 16 07-02-2016 03:46 PM
Head gaskets 3.0 IMA944T Classic T4Rs 8 10-03-2013 12:23 AM
head gaskets again! 6cyliners Classic T4Rs 12 04-03-2012 03:06 AM
Head gaskets ToyNutt 3rd gen T4Rs 5 05-07-2011 10:51 AM
Head Gaskets-I think runnerbug Classic T4Rs 0 10-18-2007 06:57 PM
