Old 04-21-2021, 02:35 PM #1
texadelphia texadelphia is offline
texadelphia will become famous soon enough
Replace ITREs/PS Bushings or entire rack?
I've started gathering parts to replace my power steering bushings and inner tie rod ends. I believe only one of my ITREs are bad but I was maybe just going to replace both while I'm in there. I started pricing things and new OEM ITREs are $160 each and the bushings I got were about $50. Out of curiosity I checked the price on a new OEM rack and it's just over $500. The rack is original to the truck as far as I know and I'm currently at 226K miles. I don't have any symptoms pointing to a new rack but it's my understanding that mine's getting long in the tooth.
It seems kind of silly to spend $370 on bushings and ITREs when I can get the rack with ITRE's and bushings installed for $550 with the extra bushing that isn't included.
What would you do?
1997 SR5, 3.4L, Manual
texadelphia is offline   Reply With QuoteReply With Quote
Old 04-21-2021, 02:44 PM #2
spartacus's Avatar
spartacus is a splendid one to behold spartacus is a splendid one to behold spartacus is a splendid one to behold spartacus is a splendid one to behold spartacus is a splendid one to behold spartacus is a splendid one to behold
spartacus's Avatar
What would you do?
For what you are doing, a replacement of complete rack will be a better value option.
Old 04-21-2021, 03:06 PM #3
CT135 CT135 is offline
CT135 will become famous soon enough
I'd go with a new OEM rack but still get poly steering rack bushings. A whole set of poly is cheaper than that single rubber OEM. At it makes steering tighter in my opinion.
97 Limited, 5100ís, OME 883/891, Built Right UCA, Custom Sliders, coastal off-road front bumper, 4x innovations rear bumper(custom built swing out), 4.88 gears, 16x8 konig countersteer offroad wheels, Yokohama geolandar mt G003 285/75r16
CT135 is offline   Reply With QuoteReply With Quote
Old 04-21-2021, 03:14 PM #4
The rack comes with the bushings pre-installed except for the large one that goes around the rack on the passenger side.
Old 04-21-2021, 03:22 PM #5
RumHam26 RumHam26 is offline
RumHam26 is on a distinguished road
It seems some people have trouble disconnecting the PS lines without breaking them, so be prepared to deal with that if you need to. I'm getting ready to install a new rack myself, and I'm going to get a new set of lines to replace my rusty ones.
RumHam26 is offline   Reply With QuoteReply With Quote
Old 04-21-2021, 04:53 PM #6
photoleif photoleif is offline
Real Name: Leif
photoleif will become famous soon enough
Real Name: Leif
the new rack sounds fiscally smart. fwiw i did bushings only on mine, and because getting OEM ITREs wasn't feasible given my schedule, i went with moog-branded 555, and they feel great, both manipulating them by hand, fitment, and feel while driving. i could get the outers as OEM so i did that. the hydraulic lines seem to be the issue to contend with.
'99 'Highlander' 4R SR5 5VZ-FE | 5-spd | LED lighting | TBU | 265-75R17 Duratrac stuffed after some pinch-weld convincing
'95 Xtra cab 5VZ-FE swap 5-spd | 33x10.50-15 BFG AT/KOs | 4" Superlift | ARB rear locker | OME torsion bars | Total Chaos idler arm & uniball | Smittybilt bumpers | Sportsman topper | Aisin manual hubs | K&N | Dual Optimas | Extended diff breathers | Bilstein 5100s | De-striped | Hella pencil-beams
photoleif is offline   Reply With QuoteReply With Quote
Old 04-21-2021, 05:07 PM #7
There's hardly any corrosion on mine so I'm assuming the hydraulic lines wouldn't be an issue but if there's one thing I've learned about working on cars, it's not to assume anything.
Old 04-21-2021, 07:45 PM #8
So the Moogs that Advance sells are rebranded Sankei 555?
Old 04-21-2021, 09:06 PM #9
19963.4lsr5 is a glorious beacon of light 19963.4lsr5 is a glorious beacon of light 19963.4lsr5 is a glorious beacon of light 19963.4lsr5 is a glorious beacon of light 19963.4lsr5 is a glorious beacon of light
Sorry, Iím late to the game....every Moog I ever installed was replaced by a NAPA. Iíll never buy Moog. Ball joints, shocks...etc. Never!!!!!!
Old 04-21-2021, 09:52 PM #10
Originally Posted by 19963.4lsr5 View Post
Sorry, I’m late to the game....every Moog I ever installed was replaced by a NAPA. I’ll never buy Moog. Ball joints, shocks...etc. Never!!!!!!
Napa brand or the Altrom Sankei 555?
Old 04-21-2021, 10:40 PM #11
Real Name: Leif
Real Name: Leif
the moog EV433 that i bought off amazon are rebranded 555. i'm sorry that i do not recall if they're sankei. they bear a 555 casting. here's the link, fwiw. i'd take a picture too, but they're all booted up now.
Old 04-22-2021, 09:29 AM #12
Napa
Old 04-22-2021, 10:57 AM #13
Wedgy's Avatar
Wedgy Wedgy is offline
Wedgy will become famous soon enough Wedgy will become famous soon enough
Wedgy's Avatar
You might want to get a flair wrench for the PS lines. I would definitely do a whole OEM rack.
Wedgy is offline   Reply With QuoteReply With Quote
Old 04-29-2021, 11:53 PM #14
I found OEM ITREs on Amayama for almost half as much as anywhere in the states. Hopefully they don't take too long to ship.
Sent from my SM-T380 using Tapatalk
Old 04-30-2021, 12:59 AM #15
HiLife HiLife is offline
HiLife has a spectacular aura about HiLife has a spectacular aura about HiLife has a spectacular aura about
I was in the same delema as you are in. My rack is still good, no leaks, so I kept the original rack.
Replaced both left and right itr from Amayama. Left and right otr's and rack boots from my local toyota. And poly rack bushings from a member from this site.
Prices were cheaper then.
bushings , itres , oem , rack , replace
Replace side mirror cap or entire assembly Edison_chen 5th gen T4Rs 5 11-05-2018 02:18 PM
Replace CV Boot, or Entire CV Shaft? DanielMaat89 4th Gen T4Rs 9 05-09-2015 06:48 PM
Should I replace ITREs? ShooterMcGavin 3rd gen T4Rs 32 03-09-2015 09:35 PM
Replace entire Brake system with Tundra's? Castaway 3rd gen T4Rs 11 01-28-2015 12:03 AM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
