Old 04-23-2021, 08:30 PM #1
ats90mph's Avatar
ats90mph ats90mph is offline
ats90mph is on a distinguished road
ats90mph's Avatar
Lower Ball Joint Saga Contd...
Hello,
On a previous thread I was discussing on whether or not I should replace my LBJ’s after a squeak developed (more info here):
Suspension Conundrum
The joints only had 13,000 miles on them, and grease had been added to them, and the squeak resolved. So today, I had the left joint replaced (just to be safe), and boy was I happy I did.
These parts were OEM Toyota parts bought off eBay. The joints were stiff, but seemed to be in good condition. I’ll let the photos tell the rest. Let me repeat, these have only been on the truck for 13,000 miles!
Lower Ball Joint Saga Contd...-6031c9dc-c6ed-4914-9b1c-df08a79aa61c-jpg  Lower Ball Joint Saga Contd...-06d5740a-bef6-4b61-a809-dfe563f27392-jpg  Lower Ball Joint Saga Contd...-d1471c30-73d4-4799-abf8-b0471cbaf51c-jpg
ats90mph is offline   Reply With QuoteReply With Quote
Old 04-23-2021, 09:09 PM #2
cl4Rk's Avatar
cl4Rk cl4Rk is offline
cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold
cl4Rk's Avatar
Whoah
2000 SR-5 V6 4x4 Auto
"Ol' Ruby" - build thread
@Y2K_4X4
cl4Rk is offline   Reply With QuoteReply With Quote
Old 04-23-2021, 09:10 PM #3
JZiggy's Avatar
JZiggy JZiggy is offline
JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future
JZiggy's Avatar
Try wiping some of that dark grease off the ball so we can see if there is scoring. It looks a bit like lubrication failure.
JZiggy is offline   Reply With QuoteReply With Quote
Old 04-23-2021, 09:41 PM #4
Twisted Sid's Avatar
Twisted Sid Twisted Sid is offline
Twisted Sid has a spectacular aura about Twisted Sid has a spectacular aura about Twisted Sid has a spectacular aura about
What are the chances that these were counterfeit parts?
'99 4Runner SR5: 5VZ, 2wd, AT, 400k+ club
'94 Pickup: 2wd, 22RE, 5spd, (3RZ swap in progress)
Front: Total Chaos Uniball Kit, Fox 2.5 8'' coilover
Rear: Deaver F67 Leaf Springs, Fox 2.0 14'' Reservoir Shocks, E-locker Axle 4.88 Gears 33x10.5 BFG ATs
Twisted Sid is offline   Reply With QuoteReply With Quote
Old 04-23-2021, 10:20 PM #5
ats90mph's Avatar
ats90mph's Avatar
Not likely IMHO. First, counterfeiting a part with such low volume seems not worth it, as this joint was identical to a joint I got from the dealer. I think the part was just old, and it had been sitting for a long time, and the grease dried up. The grease you see in the joint now was added a few days ago to verify that the noise was coming from this part....
Old 04-23-2021, 10:32 PM #6
ats90mph's Avatar
ats90mph's Avatar
Lack of grease is exactly what I think caused this...
Lower Ball Joint Saga Contd...-8794805f-23a5-4b5b-9d6f-15fbd2939e66-jpg  Lower Ball Joint Saga Contd...-d494ac72-e804-4712-89af-79b68178dcef-jpg
Old 04-23-2021, 10:37 PM #7
ats90mph's Avatar
ats90mph's Avatar
One more....
Lower Ball Joint Saga Contd...-1ae5670e-82fa-4f8d-aa8c-91d9e72923c7-jpg
Old 04-24-2021, 03:20 AM #8
Malcolm99's Avatar
Malcolm99 Malcolm99 is offline
Malcolm99 has a spectacular aura about Malcolm99 has a spectacular aura about
Malcolm99's Avatar
I'm curious what your hub to fender height is, these LBJ's do not have much range of motion, I'm sure anyone over and around 23" is pushing its limits, myself included. I wish there was a better option or at least a better priced OEM LBJ.
Malcolm99 is offline   Reply With QuoteReply With Quote
Old 04-24-2021, 03:41 AM #9
HiluxSurf SSR-G's Avatar
HiluxSurf SSR-G HiluxSurf SSR-G is offline
HiluxSurf SSR-G will become famous soon enough HiluxSurf SSR-G will become famous soon enough
that doesn't look like a Genuine Toyota LBJ.
most probably one of the fakes sold in ebay
HiluxSurf SSR-G is offline   Reply With QuoteReply With Quote
Old 04-24-2021, 03:45 AM #10
if grease dries up due to old age, then how come Genuine Toyota LBJs do not need to be greased while being used for many years and/or several tens of thousands of miles? there have been cases that have been used for 100,000+ miles without being greased
... I think the part was just old, and it had been sitting for a long time, and the grease dried up. The grease you see in the joint now was added a few days ago to verify that the noise was coming from this part....
Old 04-24-2021, 04:05 AM #11
repo repo is offline
repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light
I envy your optimism.
99 SR5 v6 4WD
11 SR5 v6 4WD
repo is offline   Reply With QuoteReply With Quote
Old 04-24-2021, 04:21 AM #12
If you didnt buy from a proper Toyota dealer who for some reason prefers to pay ebay fees instead of sell directly, they are counterfeit or some weird gray market crap. I dont even trust Amazon let alone ebay. Theres a huge global market for fakes including LBJs I'm afraid.
99 SR5 v6 4WD
11 SR5 v6 4WD
Old 04-24-2021, 10:13 AM #13
Spiker Engineering's Avatar
Spiker Engineering Spiker Engineering is offline
official vendor
Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of
official vendor
It does look like they were dry, leading to galling. It would be interesting to see some photos of the joint with the grease cleaned off, to show the metal parts more clearly. Not sure it really matters at this point though.
High Lift Hood Struts | Ultragauge/Scangauge Mounts | Phone Mounts
Custom 3rd Gen 4Runner products | 100% designed, fabricated, and assembled in the USA
https://spikerengineering.com
Spiker Engineering is offline   Reply With QuoteReply With Quote
Old 04-24-2021, 10:23 AM #14
Sarki Sarki is offline
Sarki has a spectacular aura about Sarki has a spectacular aura about
Sure seems like a case of counterfeit parts. I bought a pair of inner tie rods on eBay and they turned out to be counterfeits, why not LBJ’s.
How much did you pay as that may also (not always) be an indication if legit OEM parts.
2002 SR5 Sport 4WD
Sarki is offline   Reply With QuoteReply With Quote
Old 04-24-2021, 04:04 PM #15
FD7683 FD7683 is offline
FD7683 will become famous soon enough FD7683 will become famous soon enough
Has to be a counterfeit part to be worn already at 13k. I did read about the quality of the OEM ball joints going down recently but this is of the extreme. Having dealt with counterfeit parts before, I from now on go to the dealer or a reputable website when it comes to very critical parts.
2000 4Runner Limited 4x4 V6
000 , joints , miles , parts , squeak
Lower Ball Joint Chilow 5th gen T4Rs 3 07-22-2020 11:14 PM
Upper Ball Joint/Lower ball joint replacement Tigerfan86 4th Gen T4Rs 1 03-03-2020 03:10 PM
Tie Rod & Lower ball joint DannyLlama 5th gen T4Rs 26 10-29-2016 11:45 PM
2003 Lower Control Arm/Lower Ball Joint replacement Wahoo96 4th Gen T4Rs 5 01-30-2015 02:16 PM
Lower ball joint nissanh 3rd gen T4Rs 6 11-09-2013 09:16 PM
