Old 04-24-2021, 01:09 PM #1
alphyn's Avatar
alphyn alphyn is offline
alphyn will become famous soon enough
alphyn's Avatar
OEM Bumper Repair or Replace? Lower Valence Tabs, Face Bar Brackets and Paint
I'm in the process of restoring my neglected 4Runner and going through a number of repairs and addressing deferred maintenance items. One of them is the front bumper.
My primary issues I am trying to address are with the lower valence and metal bumper face bar. I didn't know if others have attempted repairs or just picked up new bumpers. My goal is to keep a stock look, modified to meet the aesthetic of other enhancements to my truck. My bumper is currently removed and disassembled into its component parts (upper plastic valence, metal face bar, lower plastic valence). Truck is a 1999 SR5 Highlander in black. Face bar is body colored, plastics are unpainted and faded. My plan was to repaint the metal face bar. It's taken quite a bit of rock damage over the years and paint is pretty chipped. I was going to bedliner the plastic valences to match my bedlinered fender flares.
Structural Fixes / Repairs Needed
Metal Face Bar
Spot welds on one of the mounting brackets popped. Debating whether to buy a new face bar and paint it black since I was already planning on respraying my existing face bar. Trying to determine if it is more economical to re-weld the support bracket to the face bar or just get a new face bar, strip it down and repaint. My concern about re-welding the bracket on to face bar are that it could be out of alignment and cause fitment issues. My concern buying a used bumper would be all the prep required to repaint and difficulty finding a 1999-2002 bumper in good condition.
Lower Plastic Valence
Several mounting tabs have broken off. Some right behind the front license plate area. I think those will be fairly easy to fix with epoxy. Mounting tabs attaching the top part of the valence to the metal face bar have broken out and I don't have a solution identified I feel confident with yet. I'm debating trying to plastic weld with either a metal support screen or some other structural element. 2-tabs are torn out. I'm looking for better solutions if anyone has any. Here are the tab locations:
Debating if it is worthwhile to try and fix or source a new valence. I've seen some aftermarket ones for about $100 shipped. If I was confident they were quality replacements, I'd just go with a replacement. If I could source an OEM part at a junkyard, I'd consider that option - although I'd be concerned with broken tabs and damage I'd have to fix anyway.
Any thoughts from the brain trust here? I did a quick T4R search and didn't find a ton of info. I don't know if anyone has bookmarks linked or has better search skills than I do. Appreciate all the help!
1999 4runner Highlander (Manual)
1993 Nissan 300zx Twin Turbo
alphyn is offline   Reply With QuoteReply With Quote
Old 04-24-2021, 01:48 PM #2
cl4Rk's Avatar
cl4Rk cl4Rk is offline
cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold
cl4Rk's Avatar
I know it’s not exactly the same thing, but I just picked up aftermarket chrome pieces for the rear bumper (factory look). Seems fine. I’ll know more after the install (and post photos).
I’ve also noticed a lack of info on stock bumper restoration. I think a lot of people just live with a beat up factory bumper until they’re ready to get some armor?
2000 SR-5 V6 4x4 Auto
"Ol' Ruby" - build thread
@Y2K_4X4
cl4Rk is offline   Reply With QuoteReply With Quote
Old 04-24-2021, 01:57 PM #3
alphyn's Avatar
alphyn's Avatar
I'm looking in to fixing up the rear bumper, too. I have some pretty significant dings in mine. I think the previous owners enjoyed backing into walls. My goal has been to repair or replace all wear parts / maintenance items bumper to bumper. So far I haven't made it past the engine bay.
What aftermarket suppliers have you found? I'm a little bit more in to quality than price these days. Any reputable?
Old 04-24-2021, 02:06 PM #4
cl4Rk's Avatar
cl4Rk's Avatar
Sounds like we have similar goals.
You can check out my build thread to see some of the parts I got (link in my signature). I prefer OEM for the most part on critical components/systems, but for the bumper chrome I just went cheapest on AMZN. They seem to look fine and fit. The middle section showed up with a very small dent near the bottom/underside, but not very noticeable, and a few of the mounting tabs were bent in transit, but not a big deal to me. Evan Fischer was the chrome supplier.
@Y2K_4X4
Old 04-24-2021, 09:55 PM #5
photoleif photoleif is offline
Real Name: Leif
photoleif will become famous soon enough
Real Name: Leif
we replaced our front valance with a new one. the old one was cracked and pretty wretched. i looked into attempting to fix it, and realized that with the kind of wind it has to put up with, there's really no adhesive that would hold against that vibration. i could bracket and bolt it, and then i'd have ugly bolts showing... so got the new one from amazon and it was a perfect fit. arrived in about the largest, lightest box the UPS guy had ever seen, he said. i told him i bought 4 lbs of air. the exact one i got is no longer listed on amazon, but it sounds like you have located some.
'99 'Highlander' 4R SR5 5VZ-FE | 5-spd | LED lighting | TBU | 265-75R17 Duratrac stuffed after some pinch-weld convincing
'95 Xtra cab 5VZ-FE swap 5-spd | 33x10.50-15 BFG AT/KOs | 4" Superlift | ARB rear locker | OME torsion bars | Total Chaos idler arm & uniball | Smittybilt bumpers | Sportsman topper | Aisin manual hubs | K&N | Dual Optimas | Extended diff breathers | Bilstein 5100s | De-striped | Hella pencil-beams
photoleif is offline   Reply With QuoteReply With Quote
bar , bumper , face , metal , valence
2017 SR5 Bumper repair or replace RSP007 General Discussions 1 11-04-2017 06:38 PM
Lower Control Arms - need to repair/replace? hobosapien 4th Gen T4Rs 11 08-08-2017 10:27 PM
How to Replace the Rear Bumper Face Plate 4runner001 3rd gen T4Rs 14 12-07-2016 01:41 AM
WTB: 3rd gen Limited front lower bumper valence dynabyhd Want to Buy/Trade 0 01-14-2012 09:58 AM
WTB: 3rd gen Limited front lower bumper valence dynabyhd Want to Buy/Trade 0 07-17-2011 09:38 PM
