Figured I would get this build thread started before I forget what I might have done, even though I can't even see the finish line quite yet. Every time I think I am closer to the end, I end up finding something else to do.
What has been done.
Exterior/Wheels/Tires/Brakes
Removed the running boards
SCS Matte Black SR8 16's
General AT2 265/75/16
Wheeler's Off-Road Brake lines
13WL Tundra Brake Upgrade
Shrockworks front bumper with baja designs led fogs
Shrockworks rear bumper w/swing out and jerry can holder
Shrockworks full skids
Full length roof rack courtesy
eimkeith
Interior/Electronics
Alpine CDE-HD149BT with the XM antenna
Kicker CS65 6 1/2" in the front doors
Kicker CS5 5 1/4" in the back doors
LED dome light replacements
Uniden 520XL CB w/3ft Firestik
LED Lighting in the dash
Under the Hood
New OEM radiator/hoses/thermostat
Toyota Red long life coolant
New B&M 70264 Transmission cooler
New idle air control valve
new PCV valve
new plugs and wires
New rear sway bar bushings
Suspension
Icon CDCV 2.5 coilover
Icon CDCV rears
OME 861
Built right UCAs
Sway bar end links
MStudt
New Lower ball joints (OEM)
Outer Tie Rod ends (OEM)
New Sway Bar Bushings Front/Rear
Steering Rack Bushing Kit
Complete rear end rebuild
Mods to come in the future
HID Headlight Retrofit
Trans flush/filter and fluid change to Royal Purple
White Knuckle off-road sliders
Scan Gauge II
Maintenance
Timing belt/water pump/thermostat-250,413
OEM plugs/wires/PCV valve-251,413
Head gasket-251,413
Rear main seal-251,413
1999 Toyota 4Runner SR5 - Icon CDCV 2.5's, SCS Matte Black SR8 wheels, Audio overhaul (Alpine CDE-HD149BT, Kicker CS65s up front and CS5s in back
My build thread:
http://www.toyota-4runner.org/3rd-ge...ack-pearl.html
2015 Toyota 4Runner Trail Premium traded for 2015 Ford F-250 Super Duty
Originally Posted by StreetCreeper
And you also tell him that right before Absalom smokes them on the trail—he skins them first and fashions their dirty lifeless hides into camp-hats to keep warm at nite...
