Old 04-28-2021, 04:43 PM #1
CWccw CWccw is offline
CWccw is on a distinguished road
What brand upper balljoint to get? Press tool?
I lost a UBJ a few months back in Big Bend, was towed to autozone and got whatever BJ they had to get me back home. I can't for the life of me remember the brand or how I put it on working basically on the side of the road with a 2 jaw remover tool.
Now I'm takling the other side UBJ with a Moog that I can't seem to get on. Ordered a press tool from Amazon thats slightly too big to get this started.
What brand balljoints should I get from autozone/oreillys that I can get this done with the same side-of-the-road tools I had/have? I'm replacing both before I got on a roadtrip.
98 SR5 4wd, CS144, compass/temp mirror, 2nd gen Hilux Altimeter/Inclinometer ,Chinese knock off diesel heater, Chinese copy of Alpicool CX50, OME 3" lift, 1" Toytec body lift, Snorkel, 13WE, Borla catback, Android hu, LED H4
CWccw is offline   Reply With QuoteReply With Quote
Old 04-28-2021, 05:19 PM #2
bmason8159 bmason8159 is offline
bmason8159 is an unknown quantity at this point
To be honest why not go oem? I just picked up a set from Timmy the toolman Toyota’s link on his YouTube video. Not expensive at all.
bmason8159 is offline   Reply With QuoteReply With Quote
Old 04-28-2021, 06:01 PM #3
A stealership is no where near me. Thats why I asked for brands, aka alternatives. Not everyone is has a dealership in reach. What are the toyota quality brands? Its not ac Delco or Motorcraft. Hell not even moog. Also don't have time to wait for delivery.
Old 04-28-2021, 06:08 PM #4
repo repo is offline
repo has a spectacular aura about repo has a spectacular aura about
I got every single press set loaner and found a combo of the big Advance Auto Master C-clamp set and the O'Reilly 4WD adapter set worked, and I still had to swap half way through because the O'reilly one was too shallow but it allowed the screw down far enough to fot the one that came with it. The problem is you cant use those press clamps with the screw the right way around because the knuckle spindle arm or whatever its called gets in the way. I wasnt able to try the Autozone master adaper set becaused none of them had it. It might work with their clamp.
I think this one may work too: https://www.autozone.com/loan-a-tool...ler/209523_0_0
99 SR5 v6 4WD
11 SR5 v6 4WD
repo is offline   Reply With QuoteReply With Quote
Old 04-28-2021, 07:04 PM #5
tyler.lewis tyler.lewis is offline
tyler.lewis is on a distinguished road
Yes I am having that issue right now installing mine. The rental tool at oreillys is too big and hits the spindle. However since I am running the JBA off-road UCA arms which has the ball joint bolted on the control arm, I just need to to install the female end. I think I am going to try using a large socket and a through bolt and tightening it up to see if I can get it to seat. Just ran out of patience using that tool this weekend.
tyler.lewis is offline   Reply With QuoteReply With Quote
Old 04-28-2021, 08:16 PM #6
Installing was massively easier. I did SPC arms and the knuckle part was shaped to fit directly in that type of ball joint c-clamp press. Removing the UBJ would be much easier if you cut the stud off, which I didnt do. It's like trying to play tetris eith thede adapters otherwise. The O'Reilly obe I only used as a receiver cup for removal. The large Advance Auto kit had the right size adapter for installing.
99 SR5 v6 4WD
11 SR5 v6 4WD
Old 04-28-2021, 08:52 PM #7
The Toyota quality brand is Toyota. I would just use Moog if youre not going to wait for Toyota, should be fine. There's not much stress on the upper joint compared to lower.
99 SR5 v6 4WD
11 SR5 v6 4WD
Old 04-28-2021, 11:17 PM #8
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot is a jewel in the rough Devbot is a jewel in the rough Devbot is a jewel in the rough
Devbot's Avatar
Real Name: Devan
+1 for JBA UCAs, never look back
This is a good removal set up regardless
Y2K Highlander Millennium Silver 3.4L auto @ 295k and climbing
TRD coils / Tundra 5100s / Total Chaos Diff Drop / JBA UCAs / CVJ 9168R Axles / Dobinson 210v / Tokico Blacks / Vision Soft 8's / Widepeak AT3W 285s / EimKeith PCK / Spiker Hood Struts / Hood Scoop LED Mod / SRQ Corner Lights + Filler Panels + Grille w/ Raptor Lights / Durobump Front Stops / Daystar Rear Stops / Taco Antenna + Stereo / Braided + Extended Brake Lines / Extended Sway Bar Links / Elbow Delete + ISR / True North Fab. Hybrid Bumper / Smittybilt XRC Gen 3 Comp. / Northstar 880CCA AGM / Big 3 / Extended Rear Diff Breather / Drivelines NW Prop Rod
Old 04-29-2021, 04:26 AM #9
Zoom-a-Loom Zoom-a-Loom is offline
Zoom-a-Loom is on a distinguished road
Order OEM UBJ on-line Nothing compares to the factory ball joints, this is well known and proven.
Zoom-a-Loom is offline   Reply With QuoteReply With Quote
Old 04-29-2021, 01:11 PM #10
3bears 3bears is offline
Real Name: Joshua 3 Bears
3bears is a glorious beacon of light 3bears is a glorious beacon of light 3bears is a glorious beacon of light 3bears is a glorious beacon of light 3bears is a glorious beacon of light
I know it wont help much in your situation, but when I did mine I did the upper bushings too, so I took the entire arm off and did it all on a press.
as others have said, the upper is not under stress like the lower and most major brands are fine, but I used all toyota. Years back a friend rebuilt his entire front end with moog, except the lower ball joints...and it lasted a few years b4 he sold it for a tundra.
I remeber years back, seeing a guy on youtube do the uppper ball joints using just mostly simple tools.....its not one of timmys videos....might have been on a taco, dont remember, but same set up as a 4runner
2000 SR-5 Highlander. bought 6/16/20. 4:30's, factory locker, Green
2001 SR-5.. bought 12/10/20. thunder cloud metallc, problem child...
2000 SR-5 V6 Auto . lifted, e locker, other cool stuff, TOTALED 10/22/20.
big , brand , press , side , tool
Leaking upper balljoint noises Bernardchan96 4th Gen T4Rs 4 10-07-2019 09:06 PM
Wheel bearing press tool erklep For Sale: T4R Items 2 03-21-2017 07:49 PM
JBA or Camburg balljoint Upper control arms Billynath1988 4th Gen T4Rs 15 06-23-2016 12:22 AM
Can't seperate spindle from Upper BallJoint 96pearlrunner 3rd gen T4Rs 20 03-09-2016 08:24 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
