Old 09-16-2021, 04:41 PM #31
cl4Rk's Avatar
cl4Rk cl4Rk is offline
cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold
cl4Rk's Avatar
Originally Posted by 5th4runner View Post
Am curious, however, if there is enough adjustment to remove the positive camber with the standard setup after a 2" lift?
I got an alignment yesterday with OME 880s (~1.5"-2" lift), 265/75r16 tires, original UCAs and original CVs. Here's my numbers:
Front Left: Camber 0.0, Caster 3.0, Toe 0.12
Front Right: Camber 0.1, Caster 3.3, Toe 0.13
Total Toe: 0.26
Steer Ahead: -0.01
2000 SR-5 V6 4x4 Auto
"Ol' Ruby" - build thread
@Y2K_4X4
cl4Rk is offline   Reply With QuoteReply With Quote
Old 09-16-2021, 08:37 PM #32
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
What does NAPA's warranty say about off-road use? Autozone states their warranty won't cover it if you break it while wheeling
Edit: So which one of you made this review? https://www.oreillyauto.com/detail/c.../idd1/to8043et
Old 09-21-2021, 03:22 AM #33
theriddler's Avatar
theriddler theriddler is offline
theriddler is on a distinguished road
theriddler's Avatar
Are any of you guys trading in your cores on these axles? From what I'm seeing NAPA isn't requiring a core charge which is great if you still have OEM axles that you'd like to keep and rebuild.
I'm sure these aren't the best out there but since there's free shipping, lifetime warranty, and maybe no core charge. I think they may be worth a shot for the money, everyone seems to be happy with them so far.
2002 4Runner Sport Edition-285/75R16 Duratracs, OME suspension, TRD wheels, Shrockworks front/rear bumpers, White Knuckle sliders, etc.
theriddler is offline   Reply With QuoteReply With Quote
Old 09-21-2021, 07:45 AM #34
cl4Rk's Avatar
cl4Rk's Avatar
Extended/High articulation CV Axle
I just ordered TrakMotive TO8043ET Extended Articulation CV Axles. No core charge. I’ll reboot/rebuild my originals and keep them as spares.
Time will tell. I’ll update after some miles.
@Y2K_4X4
Old 09-21-2021, 02:01 PM #35
CRB Racing CRB Racing is offline
CRB Racing has a spectacular aura about CRB Racing has a spectacular aura about
Are replacement boots available?
CRB Racing is offline   Reply With QuoteReply With Quote
Old 11-10-2021, 01:06 AM #36
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
I suppose all's well?
Old 11-13-2021, 03:26 PM #37
Romeo1's Avatar
Romeo1 Romeo1 is offline
Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice
Romeo1's Avatar
Mine are doing what they’re supposed to.
99’ Black “Highlander” sport, oak, 5VZ auto, 4.30 axle, e-lock, 265/75 Grabber X3,, Bilstein 6112 (2”) front 5160 rear shocks, OME 2906 springs, Durobumps, 4x Inovations front middle rear skid plates, 4XI square TRD tube sliders, lil skips tank skid, lotus dev RCA skids, overland custom sway bar links, Amp’d hidden winch, warn Vr Evo 10s
Romeo1 is offline   Reply With QuoteReply With Quote
Old 12-16-2021, 04:01 PM #38
Locke434 Locke434 is offline
Locke434 is on a distinguished road
CV and 5100
Originally Posted by CT135 View Post
I got one from rockauto (to8043et) for $120 shipped and I also got one from autozone (duralast or whatever) and its the exact same axle. They definitely articulate better than my OEM ones. There are reports that they do not fit with bigger coilovers but I just have basic 5100's and its a perfect fit.
I have 6112 in front, and I was wondering if there about the same size? I didn't want to order the Tracktion CV and it not fit?
2000 4Runner 4wd SR5 Limited.
Cheers!
Locke434 is offline   Reply With QuoteReply With Quote
Old 12-16-2021, 04:19 PM #39
cl4Rk's Avatar
cl4Rk's Avatar
@Locke434 The TrackMotive axles are quite a bit thicker than OEM.
Here are some photos of the TrakMotive and Bilstein 5100 clearance.
Steering wheel dead center, stock weight truck sitting on level ground.
5100s set to lowest perch and paired with OME 880 coils.
Hopefully gives you a better idea about 6112 fitment:
@Y2K_4X4
Old 12-16-2021, 10:12 PM #40
Romeo1's Avatar
Romeo1's Avatar
Mine fit 6112 bilsteins and these CV’s just fine. Stock upper arms and 2” setting.
Old 12-31-2021, 01:36 PM #41
Kwikvette's Avatar
Kwikvette Kwikvette is offline
Kwikvette will become famous soon enough
Kwikvette's Avatar
Didn't realize there was a thread here on these.
I've had mine for about a year, when they first came out.
Plenty of info and pictures I've posted in case anyone wants to check them out -
Anyone running these beefy CV axles? | Tacoma World
Kwikvette is offline   Reply With QuoteReply With Quote
Old 12-31-2021, 10:02 PM #42
Twan's Avatar
Twan Twan is offline
Twan will become famous soon enough Twan will become famous soon enough
Twan's Avatar
Ordered a pair since I've needed some for a while, and I can take my OEM ones down to CVJ. Napa also has(had) a 20% off sale through tonight, so I figured why not.
2000 SR5 Sport - 4EAT and E-locker, King 2.5s, EimKeith PCK, SPC UCAs, 33" KO2s on Black Rhino Boxer gloss gold 17x8.5, Savage/Lotus skids, 4xInnovations front bumper/sliders, Shrockworks bumper & tire carrier, Lil Skip Gas Tank Skid, Magnaflow Overland cat back
Twan is offline   Reply With QuoteReply With Quote
Old 01-02-2022, 11:26 PM #43
MarkamisPrime's Avatar
MarkamisPrime MarkamisPrime is offline
MarkamisPrime will become famous soon enough MarkamisPrime will become famous soon enough
The video you posted on hire it actually extends is awesome.
These are definitely a game changer.
2012 TRD Tacoma wheels
Grey wire mod
Toytec ultimate lift w/super flex rear coils
1.25 spidertrax coming soon
MarkamisPrime is offline   Reply With QuoteReply With Quote
Old 02-05-2022, 07:33 PM #44
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
Catching up on this thread
Seems Napa is OOS on these, can't order and none of the stores can get
O'Reilly has TO8043ET for $258.99 each
BAP has ETCVs PN 90-06353N for $223.41 each
Both claim to have Unlimited Mileage Limited Lifetime Warranties, whatever that means, but look different - the O'Reilly mod shafts look beefier and being able to swap them locally (vs shipping back to BAP) will probably be worth the $60 cost difference in the long run.
The bigger question - with Extended Length CVs and a 3" front lift, will a diff drop still be required/desired? I'd prefer NOT to drop the diff if at all possible.
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
Old 02-05-2022, 10:00 PM #45
cl4Rk's Avatar
cl4Rk's Avatar
FWIW I went with the O'Reilly CVs.
My guess would be that you don’t need a diff drop if you’re going with extended articulation CVs and a 3” lift. But it’s just a guess.
@Y2K_4X4
articulation , axle , extended , shaft , travel
New Sonoran Steel Product: KDSS High Articulation/Long Travel Trac/PanHard bar sschaefer3 5th gen T4Rs 128 11-13-2020 08:51 PM
at what lift height would you consider extended axle CVJ necessary? heron163 5th gen T4Rs 8 05-09-2019 10:44 PM
Extended axle/drop ss brake line lengths tv4184 4th Gen T4Rs 3 08-14-2018 11:50 AM
Rear Axle Extended Breather Thai 3rd gen T4Rs 1 04-14-2013 04:49 PM
FS: Jeep straight axle dana 30 High Pinion Prerunnin Rocco Classifieds - buy & sell (no commercial ads please) 0 04-29-2010 02:27 AM
