10-28-2011, 09:09 PM
Removable Tire Carrier for 3rd gens
Here's the link to the first thread I started if you care to see how long it took me to finally get this done, LOL. here I've got pretty much everything figured out for making these now if anyone needs one. Remove 2 bolts and it's out. Fully adjustable for stock to larger tires. No holes to be drilled...attaches to cargo D rings.
Pics are taken with a 285/70r17 but there is probably enough room for a 36 but definitely a 315/75r16.
It is not made to hold a Hi-Lift. I was just taking a look to see if I wanted to try to get it to fit. I have a 60" but a 48" might work.
戦争イーグル
Cory J
Wheel converter,
10-28-2011, 09:30 PM
Looks nice. Simple too.
2000 4runner Sport, SAS/4wheel Underground 3 link, Diamond axle, 14" Radflo coilovers, double locked, Custom rear 3 link, 12" Fox shocks, full armor Gerdo's Build Thread
Real Fuel Tank Skidplates for sale Lil' Skip's OffRoad
Rear control arm mount skids and Hi-Lift adapter for sale Lotus Development
10-28-2011, 10:13 PM
Thanks Gerdo. It looks simple but I had a few set backs that took up some time. Atleast I learned a few things and have a good tucked up, out of the way, spare tire carrier now.
戦争イーグル
Cory J
Wheel converter,
10-28-2011, 10:27 PM
Hey that's pretty sweet. Could you mount it on either side?
2000 4RUNNER SR5 TRD Supercharger, OME 882's w/ topout's and n91sport strut up front.OME 851's w/ cones and trekmaster LC shocks in the rear. R.I. LED lighting, retrofit E locker, 1" diff drop, 315/75/16 cooper discoverer STT, 2" R.B. body lift, rear disc brake conversion, Ingen intake, Spectre cone filter, Fitch fuel cat, Cobra LTD29 CB, custom front, and rear bumper, smittybuilt 8000 # winch, 66" 4xinovations rock sliders w/kickout, lil skip's gas tank skid. Custom skid plates. My build thread is @ http://www.toyota-4runner.org/3rd-ge...ld-thread.html
10-28-2011, 11:01 PM
It's not universal in that way if you mean could you swap from side to side freely. It can be made to fit either side with a simple change in the area circled in red though.
OR
I could make it like a "T" on the encircled part so you can swap from side to side. The only inconvience you would have is rolling the tire around the small extension.
戦争イーグル
Cory J
Wheel converter,
10-29-2011, 01:59 AM
I personally have been trying to move gear out of the 4runner, but you can't beat a compact way to hold stuff inside where it is nice and safe from would be thieves. I would be tempted to bracket off of it to have a way to hold a tool box/bag on top of the wheel well behind the tire. Not sure how much more weight those two 6mm bolts will hold though.
10-29-2011, 02:47 AM
With the tire sitting on the floor like that, there isn't much force applied to the bolts as is. It would almost stand on its own without being bolted down since the tire acts like another leg.
What did you have in mind? If the wheel hump could help support the weight it should work
戦争イーグル
Cory J
Wheel converter,
10-29-2011, 03:15 AM
Ideally would be like a flat plate that sits on top with a tool box that could slide on and off for easy access (with a latch of some kind). It would tuck it back out of the way but allow super quick access. I may have to figure out a way to do something like that in mine. I don't plan to move the tire inside, but I hate having the tool box ratchet strapped down, its too long of a process when I need something out of it.
10-29-2011, 03:56 PM
Originally Posted by ChildrenOfBodom
Looks awesome, I'd run it
DesertRunners T4R
10-29-2011, 04:18 PM
looks awesome, simple, sweet and effective
a couple years ago a guy i thought was a friend said he would me and two other friends a tire carrier, lets just it say it never happened lol
I like yours but with a cargobox I couldnt do that, but looks great, good enough Im going to think about redoing my cargobox to have something like that
2007 Sport.
"Colorado is FULL, try N.M."
"Everyone is an expert"
10-29-2011, 04:32 PM
Functional, ease of use, mulitple applications and simply brillant. Nice job..... looks like you're on to something here. Although I have not looked if this product is not already available, I would look into protecting your design.
A thought that crossed my mind, perhaps attaching to the existing frame a hinged platform 6-10", just enough when folded down would support the tire footprint off the carpet. I see two benefits, it would protect the carpeted area the tire sits on as well as added stability to the upright structure tieing it further into the tire mass.
congrats........regards 8sm
97 House of Kolor Imperial White SR5 TRD S/C TRD Headers AirRaid Intake MagnaFlow high-flow cat Borla exhaust 4x4 5sp E-Locker ICON Vehicle Dynamic Suspension 1st Gen RollBar Bushwacker Flares URD 6th injector kit O2 Calibrator & Short shifter MB Razor BigO XTs DevilsOwn Meth-injection quick disconnects diff. drop, certifit sport hood, kickout sliders, rigid LEDs, front plated and rear swing out bumper and Savage skid plates.
10-30-2011, 04:54 AM
I don't know how to protect the design, honestly. Didn't even know if it would be worth doing.
That carpet protector could easily be added for sure. I tried to keep as much weight off as possible but that idea never crossed my mind. Good idea, some people have nice carpet unlike myself.
My goal was to make something simple, adjustable, lightweight, and as small as possible to help with shipping costs. Without the wheel mount bracket attached the frame only weighs 15lbs. That bracket probably weighs less than 10lbs.
戦争イーグル
Cory J
Wheel converter,
10-30-2011, 04:56 AM
I most definitely would too. So when do these go into production?
My 2002 4Runner
10-30-2011, 05:15 AM
Whenever anybody wants one. I have enough material to make 2 quickly. I can also offer it $30 cheaper if you know someone that can weld. Also, would probably make shipping cheaper.
$160 + shipping for welded in bare metal
$130 + shipping for unwelded but marked for assembly
I rattle canned mine but I can have it powdercoated for an additional amount....ball park of $30-$40. I haven't been given a formal quote. I got that from conversation so I can't say for 100% sure but I will find out if interested.
戦争イーグル
Cory J
Wheel converter,
