Old 04-30-2021, 09:51 PM #1
CWccw CWccw is offline
CWccw is on a distinguished road
Dash indicator lights stuck on
The picture explains a lot. The keys are not in the ignition and some of the lights are still on. Its not the ign cylinder, removed that. I unplugged the ign switch and the lights stay on. I'm not familiar with the 4runner dash wiring so I'm not sure where to start.
16198339100262213451668683714656 — ImgBB image won't post
Looks like the accy power is stuck
98 SR5 4wd, CS144, compass/temp mirror, 2nd gen Hilux Altimeter/Inclinometer ,Chinese knock off diesel heater, Chinese copy of Alpicool CX50, OME 3" lift, 1" Toytec body lift, Snorkel, 13WE, Borla catback, Android hu, LED H4
CWccw is offline   Reply With QuoteReply With Quote
Old 04-30-2021, 10:42 PM #2
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot is a jewel in the rough Devbot is a jewel in the rough Devbot is a jewel in the rough
Devbot's Avatar
Real Name: Devan
You have a short somewhere, and looks like a good one too. Look up how to take apart our dash, it's very simple (I think like 10 screws in total?) and all the wiring looms are very visible once you pull out the gauge cluster some
Is your vehicle stored and/or has been stored in an area prone to mice? If I remember correctly a while back I saw someone say it's easy for them to somehow get in where the cabin air vents are which eventually leads to the dash. If memory serves me right I wonder if maybe one got in and had a snack
Y2K Highlander Millennium Silver 3.4L auto @ 295k and climbing
TRD coils / Tundra 5100s / Total Chaos Diff Drop / JBA UCAs / CVJ 9168R Axles / Dobinson 210v / Tokico Blacks / Vision Soft 8's / Widepeak AT3W 285s / EimKeith PCK / Spiker Hood Struts / Hood Scoop LED Mod / SRQ Corner Lights + Filler Panels + Grille w/ Raptor Lights / Durobump Front Stops / Daystar Rear Stops / Taco Antenna + Stereo / Braided + Extended Brake Lines / Extended Sway Bar Links / Elbow Delete + ISR / True North Fab. Hybrid Bumper / Smittybilt XRC Gen 3 Comp. / Northstar 880CCA AGM / Big 3 / Extended Rear Diff Breather / Drivelines NW Prop Rod
4runner , dash , ign , lights , wiring
Green 4WD indicator stuck on/wonít engage 4wd Parkss1181 4th Gen T4Rs 20 08-19-2020 05:52 PM
Check-Engine, Slip Indicator and VSC Off lights stuck on! Need help ddicosmo 4th Gen T4Rs 9 07-07-2020 09:58 AM
p1780 cel park neutral switch error with erratic dash indicator lights Mountain Fun 3rd gen T4Rs 1 11-19-2017 11:55 PM
MPG indicator stuck at korborh 5th gen T4Rs 4 06-29-2015 11:15 PM
Electrical ...(Dash indicator lights) 98LTD Problems & Warranty Issues 3 01-09-2009 07:51 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
