Old 05-02-2021, 12:37 AM #1
texadelphia texadelphia is offline
texadelphia will become famous soon enough
Hitch drop
I need to buy a hitch ball mount to potentially tow a U-haul trailer in a couple months. I was curious what amount of drop people typically have the most luck with. I'm anticipating some rear end sag since I'm not running airbags. Should I get a zero drop ball mount or is a 2" drop a good bet?
Sent from my moto x4 using Tapatalk
1997 SR5, 3.4L, Manual
texadelphia is offline   Reply With QuoteReply With Quote
Old 05-02-2021, 11:05 AM #2
alumarine alumarine is offline
alumarine has a spectacular aura about alumarine has a spectacular aura about
It all depends on the trailer and your hitch.
I have 2" and 3" Ups (not drops) for mine.
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
alumarine is offline   Reply With QuoteReply With Quote
Old 05-02-2021, 11:49 AM #3
Malcolm99's Avatar
Malcolm99 Malcolm99 is offline
Malcolm99 has a spectacular aura about Malcolm99 has a spectacular aura about
Malcolm99's Avatar
Agreed, it all depends on the trailer, the position of the load in the trailer, your lift height and your hitch receiver, ideally you wanna see that trailer sitting dead level when loaded and hooked up to the truck, especially for twin axle trailers. I usually end up with a 4-6" drop drawbar that uses a 1"-1.25" ball hitch shank, 3/4" shank just doesn't cut it IMO and you don't want a 3/4" shank ball on a 1" drawbar eye. I have found every trailer is different, and those Uhauls are usually pretty tongue heavy, so I have about 4 different drawbars lying around.
Malcolm99 is offline   Reply With QuoteReply With Quote
Old 05-02-2021, 04:56 PM #4
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
I've rented several U-Haul trailers of varying sizes and the standard 2" was enough to get plenty of weight on the ball hitch. 98 with stock springs and stock sized tires. If any of that is different, you'll need to add roughly 1" of drop for every 1" of tire or spring height.
326WHP 347TQ
ball , drop , end , hitch , mount
FS Lock N Roll vehicle side hitch 2.5” rise/ drop SOCAL $125 DBGW5 For Sale: Non-T4R Items 2 01-24-2020 11:51 AM
Andersen Drop Hitch TheJimboTron 5th gen T4Rs 4 06-10-2017 07:25 AM
How much drop in hitch mount? MadeInMaine General Discussions 7 07-31-2014 08:30 AM
What size Hitch Drop... CoMarc 3rd gen T4Rs 4 06-11-2011 02:16 AM
Drop Hitch '03 4Runner SteveM Engines / Suspension / Wheels / Tires / Audio / Accessories 6 04-25-2004 07:59 AM
