Old 05-02-2021, 02:08 PM #1
FD7683 FD7683 is offline
FD7683 will become famous soon enough FD7683 will become famous soon enough
Hatch Wires Cracked Causing "Door Open" Issue
Hey guys, I've been trying to chase the "door open" light staying on for some time and I think I found the issue. Trying to see which door sensor is broken, I found that all 4 sensors are ok so I went to the hatch to check the wiring and sure enough the wires are cracked. Reading through this further I did find that it's a common issue and the only fix is to re-wire the cables.
Right now I just want to fix the wire that will sense the back hatch closed. Anyone know which wire operates the "door open" to sense that it's closed? I need to program my new key fob and can't do it when the doors are not closing. Any response is appreciated. Thanks.
Hatch Wires Cracked Causing "Door Open" Issue-0-jpeg
2000 4Runner Limited 4x4 V6
Old 05-02-2021, 03:31 PM #2
Danger Mouse's Avatar
Danger Mouse Danger Mouse is offline
Danger Mouse is on a distinguished road
I had to do my rear doors since the previous owner chopped the wiring harness to both if them
had to trim and solder each pair of wire ends and wrap with electrical tape.
you should be able to part the wires slightly and slip some electrical tape through and isolate the wires so whichever one is the problem isn't grounding any more.
looks like several have cracked insulation from the pic
good luck
Danger Mouse is offline   Reply With QuoteReply With Quote
Old 05-02-2021, 09:48 PM #3
good luck
Thanks for the reply. I have decided that replacing all the cracked ones with fresh new wire will be the smartest option. Good thing I learned how to solder wire recently
closed , door , hatch , issue , open
"Door Open" light problem Mike415 3rd gen T4Rs 13 05-20-2021 06:12 PM
NRA Calls Texas Open Carry Protests "Downright Weird" and "Just Not Neighborly" ndcent Off Topic 13 06-06-2014 08:29 PM
Door Open "Ding" Removal 4Running Daily 3rd gen T4Rs 13 10-12-2013 09:27 AM
WTB: OME 906 Coils & "SR5" + "4wd" Rear Hatch Badges slampe Want to Buy/Trade 0 08-14-2011 09:00 PM
Camry '05 NAV causing "check engine"? dareames Engines / Suspension / Wheels / Tires / Audio / Accessories 4 12-30-2005 04:14 PM
