Old 12-02-2017, 01:01 PM #1
jimiv's Avatar
jimiv jimiv is offline
jimiv is on a distinguished road
jimiv's Avatar
3rd gen upper rear shock mount rusted
Hello all, I was hearing a clunk in the rear of my 97 4Runner. I found the upper right side to be gone !!
Any ideas on what I can do ?
Thanks
3rd gen upper rear shock mount rusted-unnamed-jpg  3rd gen upper rear shock mount rusted-unnamed1-jpg
jimiv is offline   Reply With QuoteReply With Quote
Old 12-02-2017, 01:04 PM #2
thegipper's Avatar
thegipper thegipper is offline
thegipper is a jewel in the rough thegipper is a jewel in the rough thegipper is a jewel in the rough
thegipper's Avatar
It's happened to a few others before. I believe you have to cut the old mount out and weld in a new one. I believe Toyota does sell the mount.
Plan on it being a total pain in the ass as there is no room to work. Sorry for the bad news but it can be fixed.
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
thegipper is offline   Reply With QuoteReply With Quote
Old 12-02-2017, 01:07 PM #3
kolelt kolelt is offline
kolelt will become famous soon enough kolelt will become famous soon enough
Yes. I fixed mine. Toyota sells a replacement OEM Part. I went through the same issue. It's a lot of work to fix it. But it's doable. Ofcourse do both sides. If one side pushed through then the other will probably do the same. When you go to put in he new ones. Tap the drain hole bigger and slightly pitch it so it drains better. But you will need to clean if occasionally after wheeling. Dirt clogs it up.
I'm not uploading photos. Go through my build thread and you'll find plenty of info and photos. Page 12 or 13 I think.
koltlt 97 sr5 build thread
97 3.4 JDM/5 Speed swap/eLocker Swap/ICON CDC all around/+more.....
kolelt is offline   Reply With QuoteReply With Quote
Old 12-02-2017, 01:07 PM #4
jimiv's Avatar
jimiv's Avatar
I'm not so sure yet if there is anything solid to weld or mount anything to it. I cant find this part online either. Was thinking of welding a mount to the frame if its solid.
Old 12-02-2017, 02:02 PM #5
Scramble's Avatar
Scramble Scramble is offline
Real Name: Scramble
Scramble has a spectacular aura about Scramble has a spectacular aura about
Scramble's Avatar
Real Name: Scramble
The whole piece is about 10"wX18"l & it welds to the frame & cross members.
I sanded mine down, drilled the drain hole larger, added a second drain hole, added 2 coat's of Eastwood rust converter & 2 coats of VHT Chassis paint. Mine wasnt rusted through yet. This pic is just one coat of Eastwood, the final product is still on my camera. Good Luck!
3rd gen upper rear shock mount rusted-img_2584-jpg
____________
'99 4Runner - 2.7L 3RZ, 5 Speed, 4.56 Gears - Lifted, Locked & Loaded - 166k Original owner - http://www.toyota-4runner.org/3rd-ge...ld-thread.html
'99 Limited - E-Locker- Stock (for now) - 233k 2nd Owner http://www.toyota-4runner.org/3rd-ge...ted-build.html
Scramble is offline   Reply With QuoteReply With Quote
Old 12-02-2017, 06:51 PM #6
I don't remember the part #. @TheDurk helped me with those.
Believe me. You will have plenty of meat to weld on. Factory is welded through the top before the body is on. Now you'll have to do exactly like mine. Which is strong. After it got welded. I smeared fluid film in the tight cracks.
Old 12-02-2017, 09:33 PM #7
a216vcti a216vcti is offline
a216vcti is on a distinguished road
I had this issue too. I ended up getting a local shop to fab up some angle iron on the outside of the frame to mount the top of the shock for ~$100. It seems to work without any issues but I don't wheel the truck. I'll get some pictures on Monday. The truck is at the alignment shop at the moment.
a216vcti is offline   Reply With QuoteReply With Quote
Old 12-02-2017, 10:16 PM #8
I should have mentioned. I wheel the piss out of my Truck after the fix. And 0 issues.
Old 12-03-2017, 11:32 AM #9
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light
TheDurk's Avatar
https://parts.conicellitoyotaofconsh...ZyPWxheWVyXzI4
My Backyard Frame Swap
Old 12-03-2017, 11:39 AM #10
Originally Posted by TheDurk View Post
What about rear right ? And i remember that one side was more expensive than the other side. And also, both brackets are slightly different. They are not identical!
Old 12-03-2017, 12:38 PM #11
Ifirefight's Avatar
Ifirefight Ifirefight is offline
Ifirefight is on a distinguished road
Ifirefight's Avatar
Very nicely done. This will be an interesting thread to follow. If the OP has the skills and friends you do, it shouldn't be a problem. I'm retired from the auto body business now, but did it for 20 years. My first thought when I saw his pictures was, that's going to be a pain..it can obviously be done, just going to be a lot of work. Good luck Sir.
Ifirefight is offline   Reply With QuoteReply With Quote
Old 12-03-2017, 01:40 PM #12
Yes sir. Good friends, and some beer. Advice on grinding of the old welds. Cut into the weld with a cut of wheel carefully. Then use a air chisel to peel the weld bead of.
Old 12-03-2017, 01:47 PM #13
jimiv's Avatar
jimiv's Avatar
Thanks everyone for all the great info !!! Ill keep you all posted
Old 12-03-2017, 01:53 PM #14
TheDurk's Avatar
TheDurk's Avatar
I know. I had it wrong for a few minutes. No one would ever know if you hadn't quoted me right away. Thanks.
Left is more expensive. Only Toyota knows why. Here is left:
Old 12-03-2017, 02:15 PM #15
Ifirefight's Avatar
Ifirefight's Avatar
Did you also pull the body off the frame to do the repair? Seems like the best way to do it..albeit a crap load more work. Looking at the OP pictures, it looks pretty rusty even in the surrounding areas. Hopefully he will have good metal to weld to. Again, good luck and keep us posted. I will be following this thread because I know personally how much work this kind of repair will take to do it right.
Rear upper shock mount jstim 3rd gen T4Rs 4 06-18-2017 11:31 PM
rear upper shock mount CSM4runner 3rd gen T4Rs 9 02-07-2017 06:51 PM
Rear upper shock mount? SilentYoda3 3rd gen T4Rs 15 08-30-2013 12:10 PM
Help! Top of Rear Shock Mount Rusted Away seoulstice 3rd gen T4Rs 6 02-23-2013 08:56 PM
Rusted Out Rear Drivers Side Upper Shock Mount Awdtsi42o Classic T4Rs 6 12-07-2011 05:23 PM
