User Tag List
Reply
Thread Tools Rate Thread Display Modes
Old 05-04-2021, 12:44 AM #1
NJ-4Runner NJ-4Runner is offline
Member
NJ-4Runner will become famous soon enough
Member
A/T oil temperature light: what temperature?
I have a 2002 4runner. At what temperature will the a/t trans temp light come on. Does it state this temperature somewhere in the FSM somewhere. Has anyone verified it with an actual analog gauge or anything like that? In the FSM I have it states to check the temp sensor resistance at 68 degrees and 230 degrees Fahrenheit, does that mean the light comes on at 230 degrees?
I was in deep sand the other weekend on the beach and my light came on and I immediately shut the truck down. I realize now I should have let it idle but I did not know any better at the time. I literally shut it off about 10 seconds after the light came on. I started the truck back up a short while later and drove away like nothing happened, light was off and never came back on. I lowered the PSI in tires some more and the truck was driving a lot easier through the sand, trans was not working so hard. I checked the fluid and it is still a bright red color and smells just like tranny fluid. It is Valvoline Max-Life trans fluid...probably less than 2000 miles on the fluid as well. I changed it not too long ago, the 4Runner is not my main vehicle. I was going to change the fluid but it looks brand new, and I also read that Maxlife can withstand high temperatures (280 degrees) with no issue. Was looking for some more detailed info for when that gauge lights up.
NJ-4Runner is offline   Reply With QuoteReply With Quote
Old 05-04-2021, 01:04 AM #2
Endlessblockades's Avatar
Endlessblockades Endlessblockades is offline
Senior Member
Real Name: Blair
Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold
Senior Member
Real Name: Blair
I don't know the answer, but on an extended off road trip (climbing a few thousand feet), I got my UltraGauge trans temp up to 249 and the dash light did not trigger. I can see the bulb works at start up. I gave it a 30 min rest and never saw those heights again, but will be adding a dedicated trans cooler in series as soon as I get a chance.
__________________
260K - Y2K/E - Clock still works
Endlessblockades is offline   Reply With QuoteReply With Quote
Old 05-04-2021, 01:13 AM #3
FD7683 FD7683 is offline
Member
FD7683 will become famous soon enough FD7683 will become famous soon enough
Member
Stating the obvious but did you make sure it's right at the correct level? I don't think it should be triggering the a/t temp light on unless it was very rough to roll in the sand.
__________________
2000 4Runner Limited 4x4 V6
FD7683 is offline   Reply With QuoteReply With Quote
Old 05-04-2021, 08:06 AM #4
Member
Member
Quote:
Good idea. I will check the level again but I am pretty sure it was spot on when I exchanged the fluid.
The thing with beach sand (at least in my area) is that it is like driving through sugar and it takes some effort. You basically follow the existing ruts and it is a couple inches deep most of the time. The tires are pushing up against the side of the existing ruts, the truck is moving slow, only in gear 2 most of the time, and the torque converter never locks up. You have to give it just enough throttle to stay moving at a pace. If you give it too much throttle the tires just fight the sand and you don't go any faster, this is what I was doing. It was my first time out this year and I wasn't paying attention to the driving method, also I didn't air down enough.
I didn't really think it was that big of a deal if the light came on for a second. But then I searched on the forum and there was a lot of doom and gloom!
Old 05-04-2021, 09:20 AM #5
ej86923 ej86923 is offline
Member
ej86923 is on a distinguished road
Member
IIRC, it's somewhere in the 270-290 range. Basically right before it starts blowing out of the vent tube.
I think I saw that on another forum so take it with a grain of salt.
Personally I've never seen the light come on but I've never had it over 220 or so.
ej86923 is offline   Reply With QuoteReply With Quote
Old 05-04-2021, 09:45 AM #6
jgue467's Avatar
jgue467 jgue467 is offline
Senior Member
jgue467 is just really nice jgue467 is just really nice jgue467 is just really nice jgue467 is just really nice jgue467 is just really nice
Senior Member
jgue467's Avatar
Quote:
Originally Posted by NJ-4Runner View Post
... At what temperature will the a/t trans temp light come on. ...
It is a very high number, like others said upper 200s, closer to 300, way too high, hence they call it an 'idiot' light.
Did you pull trans dipstick to have a look at the color? If on just a tiny bit probably won't make much difference but everything affects everything, in a trans anyway.
Might even do a quick drain/fill.
If you have 4x4, I'd use it in 4Lo next time on the sand or going really slow. You can start in 2nd gear and avoid the hard 1-2 shift in 4Lo on 01-02s, another feature!
Luck.
__________________
2001 Limited 4WD - 346+K - SunfireRed\Thunder Cloud; - 265/75/16 Michelin A/T2s - Fat Pat's 1.5" BL - StopTech ANGLED rotors - In series 699 trans cooler, New Yota1 transmission, All new OEM suspension front to rear.
jgue467 is offline   Reply With QuoteReply With Quote
Old 05-04-2021, 09:55 AM #7
Member
Member
Luck.
I did check the fluid. The trans fluid is red in color and looks like it just came out of the bottle. Smells as good as transmission fluid could.
Thanks for the tip with the 2nd gear. I know practically nothing about auto transmissions. I am 43 years old and this is the first 4x4 (or vehicle for that matter) with an automatic transmission I have ever owned. I always had manuals, after this I feel like I don't know how to use the auto properly. I know that sounds silly but it's true. I actually don't mind the auto in the woods, it is nice to not be on the clutch all the time. But the heat thing is a buzzkill.
If I put the trans in 2 and the transfer case in Lo like you said does the torque converter ever lock up?
Old 05-04-2021, 10:45 AM #8
alumarine alumarine is offline
Member
alumarine has a spectacular aura about alumarine has a spectacular aura about
Member
My records show that the A/T temp light comes on at 302 F and goes out when it falls back to 248 F. I can't find where I got that info though.
In any case, the resistance tests in the FSM for 68F and 230F is to test the sensor. It assumes if the values are correct at those two points the sensor is good.
It's not practical to test the sensor over 230F in a shop.
__________________
2000 4runner 4wd Auto V6 - Tru-Cool LPD4454 trans cooler in series
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
alumarine is offline   Reply With QuoteReply With Quote
Old 05-04-2021, 11:51 AM #9
phattyduck phattyduck is offline
Elite Member
phattyduck has a reputation beyond repute phattyduck has a reputation beyond repute phattyduck has a reputation beyond repute phattyduck has a reputation beyond repute phattyduck has a reputation beyond repute phattyduck has a reputation beyond repute phattyduck has a reputation beyond repute phattyduck has a reputation beyond repute phattyduck has a reputation beyond repute phattyduck has a reputation beyond repute phattyduck has a reputation beyond repute
Elite Member
No, but in 4LO, you don't really need to lock the torque converter. Low in the transfer case really lowers the load on the engine/torque converter/transmission (by 2.7x).
Depending on speed, you might find that in 4LO that you'll run in 3rd (OD off) with the torque converter locked in sand.
-Charlie
__________________
'99 4Runner SR5 Auto - 4WD swapped
'89 Camry Alltrac LE 3S-GTE 5spd
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Previous: '88 Camry Alltrac LE 3S-GE BEAMS, 90 Camry 3S-GTE, 90 Camry DX, '03 WRX wagon, '08 Outback XT
phattyduck is offline   Reply With QuoteReply With Quote
Old 05-04-2021, 01:07 PM #10
Member
Member
Good answer. Thanks!
-Charlie
Super good advice. Thanks!
Old 05-04-2021, 01:39 PM #11
3bears 3bears is offline
Senior Member
Location: north east of Fairbank out there in the frontiers Alaska
Real Name: 3 Bears
3bears is a splendid one to behold 3bears is a splendid one to behold 3bears is a splendid one to behold 3bears is a splendid one to behold 3bears is a splendid one to behold 3bears is a splendid one to behold 3bears is a splendid one to behold
Senior Member
Real Name: 3 Bears
lots of good advice above.
I too was not that fammiliar with automatics in a 4wd till I got my 2000 ( now have a 2001) While I never did trigger my trans light....what really got my attention...and thus changed my driving habits ...was when i got my OBD2 reader and torque pro for my phone. YOu can watch the temps in real time. That phone app as well as advice here and I think timmy has a video on trans temps and driving off road helped improve my off road habits alot.
side note.....after moving to alaska i also saw how cold my tranny was running...which is bad too...so I then went back and hooked my external cooler back in series to help warm up my tranny fluid.....and also put on a tranny heater so then my rig had a block heater as well as a tranny pan heater.
__________________
2000 SR-5 Highlander version 4:30's, factory locker , green, bought 6/21
2001 SR-5... bought 11/20..sold 6/21....
2000 SR-5 moded, lifted, e locker, other cool stuff, totaled 10/20
3bears is offline   Reply With QuoteReply With Quote
Old 05-04-2021, 10:48 PM #12
jgue467's Avatar
Senior Member
Senior Member
jgue467's Avatar
.. But the heat thing is a buzzkill.
Right on the buzzkill, 4Lo will keep trans cooler in low speed driving.
Starting on 2 in 4Lo will allow vehicle to go about 20 before it shifts to 3rd but I never drive that fast off-road when I need 4Lo, so I'm always in 2.
Try taking off from 0 in 4Lo in first gear, when you hit about 10 you'll see what I mean about the hard 1-2 shift and probably won't like it. I only use 4Lo in sand or crawling slowly uphills in rocky terrain the rest of the time she's in 4Hi with center diff locked (really helps on deep mud and snow/ice).
__________________
Old 05-05-2021, 05:19 AM #13
SeaCreechur SeaCreechur is offline
Junior Member
SeaCreechur is on a distinguished road
Junior Member
Hi NJ4Runner,
I have been driving the beaches of Cape Hatteras Sea Shore for the past 20 years. It has some notorious soft sand, especially entering and exiting the access ramps.
I have owned my stock 2000 4Runner since 2001. I air down to 17 lbs and have never been stuck. Driving and navigating soft sand is all about tire pressure, staying in the ruts, and avoiding the wet red sand.
I also monitor my tranny temps with a ultraguage. I use 4hi and never see temps exceeding 185-190.
SeaCreechur
A/T oil temperature light:  what temperature?-20201022_080026-1-jpg  A/T oil temperature light:  what temperature?-img_20201023_125307_482-jpg  A/T oil temperature light:  what temperature?-20180607_140550-1-jpg  A/T oil temperature light:  what temperature?-img_20210424_134649_299-jpg
SeaCreechur is offline   Reply With QuoteReply With Quote
Old 05-05-2021, 08:23 AM #14
thegipper's Avatar
thegipper thegipper is offline
Senior Member
Real Name: Mike
thegipper is a jewel in the rough thegipper is a jewel in the rough thegipper is a jewel in the rough
Senior Member
thegipper's Avatar
Real Name: Mike
Wow, nice fish. That sheepshead is massive!
__________________
1997 SR5 4x4 Auto, 99' tall coils up front, OME 906's, Truetrac LSD, Airaid MIT
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
thegipper is offline   Reply With QuoteReply With Quote
Old 05-05-2021, 10:48 AM #15
Member
Member
Quote:
Originally Posted by SeaCreechur View Post
Hi NJ4Runner,
SeaCreechur
That's awesome.
After some digging I think I know what some of my problem is. I have Mickey Thompson MTZ P3 Mud Terrain tires. They are 265/75 R16 load range E. These are small load range E tires. When I air down to 18 PSI the tires are not even squatting, it is not enough and the tires are digging in too much. They are fighting me in the sand at that PSI and my natural reaction was to add throttle which is the wrong move. I think I have to drop down to more like 15 PSI, or lower to even begin to float on top of the sand. I used to have 31x10.5 load range C tires and they behaved very differently at 18 PSI.
The next question is how the hell have you been driving that 4Runner on an east coast beach for 20 years and it is not a pile of rust and rubber! The beach is straight up vehicle killer. I knew I would be taking mine on the beach and when I bought the truck I pretty much knew that it is a sacrifice. We have guys up here that simply lease jeeps, drive them on the beach for 4 years, and turn them in with substantial rust. do you wash it after every beach run? Are you on the beach often?
Reply
Tags
degrees , fluid , light , temperature , truck
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Temperature gauge help!!! bertsch911 Classic T4Rs 8 02-28-2013 01:06 PM
outside temperature Limited2K 3rd gen T4Rs 8 01-14-2011 01:53 PM
Outside temperature not available mcflavin 4th Gen T4Rs 10 01-08-2011 10:47 PM
Outside Air Temperature firsttoyo 3rd gen T4Rs 15 12-27-2009 04:35 PM
temperature gauge? bigtino Problems & Warranty Issues 0 01-10-2007 10:04 PM
Powered by vBadvanced CMPS v3.2.2
Copyright ©2000 - 2024, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
Copyright © 2020
