Old 05-07-2021, 11:51 AM #31
HiLife HiLife is offline
Yup. Even if they are new out of the box, those "new" parts are still suspect if the problem persists.
Down at those core yards, workers don't get paid well going through a mountain of cores weeding out the bad ones for rebuild. And sometimes bad rebuilt ones do slip through and goes into customers hands.
Old 05-07-2021, 12:47 PM #32
19963.4lsr5 19963.4lsr5 is online now
Originally Posted by nathanroyse View Post
Okay so i made a little discovery tonight when checking the contacting surfaces on the hubs.. when i jack the front of the car up, the passenger side wheel spins freely... however the driver side does not. it has a lot of resistance because of the brake pads contacting the rotors. if i compress the brake pistons the wheel spins freely but the second i tap the brakes it gets stuck again. it’s not loosing pressure when the brake petal is not being pressed. if that makes sense... all the other wheels are fine.... what could this be?
How old are your brake hoses?
I’ve had that problem be a sticking caliper and a bad rubber hose. The give away for it being a hose problem was the fact that I opened the bleeder and fluid didn’t come out unless I pushed the brake pedal. It wouldn’t flow with gravity.
19963.4lsr5 is online now   Reply With QuoteReply With Quote
Old 05-07-2021, 01:37 PM #33
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
i had that exact proboem too....sticking caliper and a bad hose. now when I do a major brake job on thes 20+ year old rigs I just replace all the hoses....then not worry for years.
I found a hose can go bad with no outside visual bulge or cracks....and plug up inside.
Old 05-07-2021, 02:03 PM #34
nathanroyse nathanroyse is offline
nathanroyse is on a distinguished road
Originally Posted by Too Stroked View Post
Partially frozen caliper. Time for a new or rebuilt one.
calipers are brand new
nathanroyse is offline   Reply With QuoteReply With Quote
Old 05-07-2021, 02:03 PM #35
Originally Posted by NJ-4Runner View Post
Totally....caliper problem. Didn't you just put new calipers on though?
yes i did. i don’t think it’s a caliper
Old 05-07-2021, 02:47 PM #36
Too Stroked's Avatar
Too Stroked Too Stroked is offline
Too Stroked is a jewel in the rough Too Stroked is a jewel in the rough Too Stroked is a jewel in the rough
Brand new OEM, brand new aftermarket or brand new remanufactured / rebuilt? The reason I ask is that brand new OEM calipers rarely freeze up out of the box. Brand new aftermarket, occasionally. Brand new remanufactured / rebuilt - all the time.
The other possibility is that you pad ears are hanging up in the caliper bracket.
Too Stroked is offline   Reply With QuoteReply With Quote
Old 05-07-2021, 03:41 PM #37
How old are your brake hoses. The inner rubber lining delaminates and acts like a check valve similar to what is in our blood vessels.
Old 05-07-2021, 03:56 PM #38
brand new from autozone so i’m assuming rebuilt. i will post a picture in a second.
Old 05-07-2021, 03:58 PM #39
I have never changed the brake hoses... and i doubt the previous owner did either. 200k miles on them. probably not a bad idea to change them... is there any way to test if they are bad before i go buy new ones? and if they are bad is it okay to just get them from Autozone/Oreillys?
Old 05-07-2021, 04:00 PM #40
Also, i read online now that i have narrowed it down to the drivers side front that it could be the master cylinder that’s messing stuff up... not to sure but sounds like someone else was having a similar problem and fixed it by replacing the MC
Old 05-07-2021, 04:45 PM #41
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Don't take this the wrong way, but why are you asking for help just to shoot down everyone's helpful suggestions? Are you looking for an echo chamber?
Old 05-07-2021, 05:55 PM #42
The brake hoses are fine from autozone etc.....around 15 dollars.
Old 05-07-2021, 06:48 PM #43
Is there a right way to take that statement? I am very grateful for everyone who has take the time to reply in hopes of helping me fix my issue. I’m also doing my own research too instead of relying on only your guys’ suggestions. I have tried all of the possible solutions above but unfortunately they have not worked.
Old 05-07-2021, 08:16 PM #44
Violent shaking when braking
Try the brake hose. Replace both since it will require a brake bleed.
Old 05-07-2021, 08:40 PM #45
just put on the new hoses. when it’s off the ground the wheel is still hard to spin unless i manually depress the pads at the caliper... i’m thinking that it might not have been the problem and that my master cylinder is bad and not letting the brake fluid return. cause the pistons to hold pressure when the brake is not applied
braking , it’s , rotors , shake , violently
97 Limited T4R VIOLENT shaking sw1 3rd gen T4Rs 20 10-17-2021 06:56 AM
Shaking While Braking XCG3 3rd gen T4Rs 43 02-06-2020 02:58 PM
Braking and shaking smh Morphyne Problems & Warranty Issues 7 06-19-2017 10:54 PM
Violent shaking/shuddering when coasting at speed BrandonF 3rd gen T4Rs 13 05-21-2014 04:19 PM
Violent shaking on acceleration p0171 ColoradoMTNlivin 3rd gen T4Rs 1 02-14-2014 10:54 AM
