Old 05-06-2021, 03:32 PM #1
texadelphia texadelphia is offline
texadelphia will become famous soon enough
Window switch flaking out
The switch for the rear passenger door in the driver door panel has started to only work intermittently. I was considering blasting it with electronic parts cleaner and seeing if that works. I did that to the turn signal switch of my Golf years ago and it worked really well. Any other suggestions beyond just replacing the switch panel with a new one?
1997 SR5, 3.4L, Manual
texadelphia is offline   Reply With QuoteReply With Quote
Old 05-06-2021, 03:46 PM #2
Skulking Skulking is offline
Skulking is a jewel in the rough Skulking is a jewel in the rough Skulking is a jewel in the rough
I only have the wiring diagrams for my 2000, but assuming that the wiring is functionally the same between the two, I'd verify it is the switch that is the problem by checking if the switch on the rear passenger door is working properly. If that switch works properly, then I'd be looking at a faulty switch on the master switch panel. If that is also intermittently failing, I'd look at a broken wire in the boot, probably on the drivers door, but potentially on the rear passenger door.
Skulking is offline   Reply With QuoteReply With Quote
Old 05-06-2021, 04:00 PM #3
The switch on the rear door works flawlessly, it's just the driver door switch that's intermittent. Noticed that there's no boot on the rear door wires, just a bundle of wires wrapped in electrical tape. Looks like someone's been in there before me.
Old 05-06-2021, 09:06 PM #4
After watching this video I took my driver switch box apart and found that the contacts were all carboned up. Cleaned them up with some sandpaper and electrical contact cleaner and it seems to be working again. There are some finicky bits in there for the auto down window control and the window control lock button but I was able to get it all back to working order.
https://www.youtube.com/watch?v=rGTbzPfcAH4&feature=youtu.be
Old 05-06-2021, 09:17 PM #5
Here's a before and after.
Sent from my moto x4 using Tapatalk
door , golf , panel , switch , window
Tailgate / back window doesn't work (motor works and it isn't the window lock switch) seattlee 3rd gen T4Rs 17 04-03-2022 08:58 PM
4WD selector switch light/Rear window light switch replacement Ventil8 4th Gen T4Rs 22 10-09-2020 11:24 PM
2014 4runner 4x4 switch and rear window switch doesn't light up? slee05 5th gen T4Rs 5 06-28-2014 05:10 PM
1991 T4R - Rear Window Switch and Window Lock Switch ? El_Estrago Classic T4Rs 0 07-25-2011 04:03 AM
rear window switch, sunroof switch cdmasm Classic T4Rs 2 07-06-2006 04:23 PM
