Originally Posted by Skulking
I only have the wiring diagrams for my 2000, but assuming that the wiring is functionally the same between the two, I'd verify it is the switch that is the problem by checking if the switch on the rear passenger door is working properly. If that switch works properly, then I'd be looking at a faulty switch on the master switch panel. If that is also intermittently failing, I'd look at a broken wire in the boot, probably on the drivers door, but potentially on the rear passenger door.
The switch on the rear door works flawlessly, it's just the driver door switch that's intermittent. Noticed that there's no boot on the rear door wires, just a bundle of wires wrapped in electrical tape. Looks like someone's been in there before me.
