Old 05-07-2021, 07:33 PM #1
EJosephs EJosephs is offline
EJosephs is on a distinguished road
Rear Parking Brake Return Springs and Bell Cranks - OEM or Dorman?
I need to get a new return spring for the parking brake bell crank on my rear right drum brake.
I can either try this and hope it works, from Toyota (OEM) but not listed for a 1998 4Runner for $9: Toyota 4Runner Spring, tension(for parking brake bell crank return) - 9050620019 | Desert Toyota, Tucson AZ
Or buy a full set from Dorman for $33: Amazon.com: Dorman 924-753 Parking Brake Bell Crank for Select Toyota Models: Automotive
I really only need the springs, but what are your opinions on the safety and interchangeability of the other parts? Do you think the springs are trash anyways? I've never bought Dorman parts.
Some backstory for those interested. TL;DR: I was missing one of the return springs on the parking brake bell crank. The long version:
I just finished cleaning and adjusting my rear drum brakes. The LR brake adjusted very easily, and by cranking the parking brake handle I was easily able to get it to position. The RR, that was a different story...
I manually adjusted it with a screwdriver ALL the way from loose, because the parking brake bell crank wasn't fully resetting. Upon releasing the brake handle, it would stop shy of touching the back plate about a quarter inch. After the brakes were properly adjusted, this meant that if you set the parking brake, it would NOT disengage. The first reason is that there is some corrosion (rust) on the parts. That will clean up easily enough. The second, is that I'm missing one of the two return springs!
EJosephs is offline   Reply With QuoteReply With Quote
Old 05-07-2021, 07:52 PM #2
Too Stroked's Avatar
Too Stroked Too Stroked is offline
Too Stroked is a jewel in the rough Too Stroked is a jewel in the rough Too Stroked is a jewel in the rough
In my experience, Dorman is the Harbor Freight of auto parts. Take that for what it's worth.
Too Stroked is offline   Reply With QuoteReply With Quote
Old 05-07-2021, 08:15 PM #3
19963.4lsr5 19963.4lsr5 is online now
I got my three sets from napa.
19963.4lsr5 is online now   Reply With QuoteReply With Quote
Old 05-08-2021, 12:01 AM #4
Thanks for the input. I would imagine buying this just for the springs would be fine, not sure how much I'd trust the bell cranks themselves though.
Old 05-08-2021, 09:58 PM #5
FD7683 FD7683 is offline
FD7683 will become famous soon enough FD7683 will become famous soon enough
I replaced both of my bell cranks due to rust. Dorman bell cranks is what I installed on my truck and it's been great even though I rarely use the e-brake. If your bell cranks are perfectly fine, I would get a new spring from Toyota or I would even head to the junkyard and get one from a donor rig.
If you are going for the new ones, remember to pack the entire boot with grease when you are assembling them. Also use a feeler gauge to adjust the bell crank screw gap to the surface - I went with .020 inch on the gap with the spring off.
2000 4Runner Limited 4x4 V6
Old 05-09-2021, 09:53 PM #6
MaineRunna's Avatar
MaineRunna MaineRunna is offline
MaineRunna will become famous soon enough MaineRunna will become famous soon enough
MaineRunna's Avatar
I've used both and the Dorman's are fine, its a piece of steel, aluminum, a clevis pin, cotter pin, rubber boot and a couple of springs. Even Dorman can't screw that up.
98 SR5 4X4 5spd, desert dune metallic, Toytech Eibach 3" lift, 1" body lift, RAD Rubber Designs splash guards, 4XInnovations bumpers, Doug Thorely Headers, Magna-flow converter, JBA muffler & tail pipe, RCI skid plate, SPC UCA's & rear LCA's, front sway bar links on rear, gen II rear links on front, Tundra brakes, '02 headlights, tail lights & sidemarkers, BFG 255/85R16 Mud Terrain T/A's 241,000 miles.
MaineRunna is offline   Reply With QuoteReply With Quote
adjusted , brake , parking , parts , springs
parking brake parts hankd 4th Gen T4Rs 5 07-23-2020 02:02 PM
How to disassemble the rear parking brake? flsurf 4th Gen T4Rs 4 01-13-2020 08:42 PM
Parking brake not holding after rear brake job 4OYOTER 5th gen T4Rs 6 10-06-2017 11:04 PM
help me identify/find these parking brake pivot bolts and parts s20004runner 3rd gen T4Rs 0 02-14-2016 01:24 AM
Is driving 07 T4R with the parking brake shoes on, only hurting the parking brake’s jow 4th Gen T4Rs 2 05-15-2013 02:31 PM
