Thread Tools Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 11-27-2014, 01:36 PM #1
NJCatalana's Avatar
NJCatalana NJCatalana is offline
Real Name: Nick
NJCatalana is on a distinguished road
NJCatalana's Avatar
Real Name: Nick
Hilux 167 snorkel for 3rd gens
Hey guys, a few guys have posted up about this in another thread, along with their pictures, but I found out that there was much more involved with the install, so I thought I would try to make one that had all of the steps. Theirs were great write ups, but I took a few more pictures of the process and though I'd post up. This snorkel is great quality, fits pretty damn good, and is a hell of a price.
This is definitely open to suggestions/modifications if those who have installed it feel the need to! Thanks for the guys who I messaged with while installing mine
Here's the amazon link:
Amazon.com: Snorkel Air Ram Intake Kit For Toyota 167 Series Hilux SR5 STH167RA: Automotive
I got mine off ebay and there are several sellers on there as well, but amazon always seems to have them at a constant price.
In the box you'll receive:
snorkel
snorkel head
3 hose clamps (one black, 2 silver)
locking nuts
bolts
bracket to connect it by the windshield
3 hex bolts for the windshield bracket
a set of 5 pins (no idea what they are for, I never used them)
template (will need modification, the big hole works but the 5 smaller ones do not)
what you'll need:
3 5/8 hole saw
5/16 drill bit (start with this one, then go larger if necessary)
black caulk (sealing around the small gaps)
Door edge guard (any weatherstripping will work, I found this to work easier because it was wedge shaped)
three 8x1/2 self tapping screws (windshield bracket)
locktite
patience, patience, and more patience
bravery to realize you're cutting a big ass hole into your fender
some one with small hands would also help
I'll list the steps I went in, some have pictures, some do not.
1) we started with the rubber L shaped house being connected to the air box. Many people have posted that this process was a huge pain, but it went quite simple for us. Having two people makes it much easier. Heat the tube up over a small flame to stretch it out. Start to put it on your factory airbox and use a flat head screwdriver to get it over it. Once on, use a pair of vice grips to stretch the tubing over your air box outlet. This rubber is very strong and will not rip. Place the air box back in with the house and house clamp connected. Wait until after install is completed to tighten the 3 bolts back on, just incase adjusting is needed.
2) attach the template to your fender, lining it up a the door end of the fender, holding it very flat and taught, making sure it is taped as smoothly as possible
3) after taping, begin to cut your hole, slowly. After the hole is cut, you'll want to set the snorkel in, line it up on the windshield mount, and then trace around its position. You'll use this tracing to modify the template for your own holes.
4) once you cut the hole you will find some factory tubing between the fender and the engine bay frame. rip that tubing out.
5) to make the template, you'll take it with the big hole already cut out and tape it to the back of your snorkel. Then you'll feel under the paper and punch out the 5 holes from the snorkel. While you're going this step, you can also attach the bolts into the snorkel. use a hex bit to tighten them and make sure to use locktite.
6) after the template it make, retape it back onto your fender and drill your holes. Give a quick punch in each hole to make sure your bit doesn't walk all over
7) once the holes are drawn, line it all up, make modifications of necessary and put the sucker in!
8) Take the wheel off for easier access. You'll have to pull down that fender liner to access the bolts. This is a bit of a pain and having someone with small hands will make it much easier
9) keep the fender lining peeled back and slide the L shaped house onto the snorkel. Attach the hose clamp they supplied. Its a huge pain to tighten and will not fully tighten. I suggest getting some gorilla tape and going around the connection just to be safe. Use the same flathead/vicegrip process when joining the tube and snorkel.
10)once all the bolts are tightened the gaps will fill in and all the pain work is finished.
11) attach the head of the snorkel using the black hose clamps. Before you put the head on, cut a dryer sheet and place it over the snorkel. This will prevent bugs and what not from going down the snorkel, while still allowing for airflow.
after that step you're finished!
message me or post up with any questions or suggestions.
2015 SR5 Premium: June 21-
2000 SR5 Highlander:June 2018-Jan 2019 [I]
06 Sport 9/2016-6/2018
99 SR5:Old Man Emu suspension up front, LC 9 wraps in back, Aussie Locker,ARB front bumper, snorkel,etc:[B]10/2010-10/2015 Build thread for the '99: http://www.toyota-4runner.org/3rd-ge...ld-thread.html
NJCatalana is offline   Reply With QuoteReply With Quote
Old 11-27-2014, 04:14 PM #2
Asaspades93's Avatar
Asaspades93 Asaspades93 is offline
Real Name: Asa
Asaspades93 is on a distinguished road
Real Name: Asa
2 people should run arb snorkels so I can sell my taco intake tubes. Good write up and pics! The holes on my template were off so deff triple check before you drill
96 SR5, Ghetto ISR mod, SCS Stealth 6s, 35x12.5 Toyo MTs, Bilstein 5100s/Eibach coils, B&M Transmission cooler, 1.5 Inch Fat Pat body lift, OME 851s, TJM XGS Gold series LC shocks, Satoshi grill, Rear diff breather, 167 series snorkel, Toytec rear brake line, All Pro apex Front bumper with custom hoops, Custom rear bumper with Ghetto swing out, First Gen roll bar,LED parking lights/turn signals, Hybrid model
Asaspades93 is offline   Reply With QuoteReply With Quote
Old 11-27-2014, 10:53 PM #3
Doc2012's Avatar
Doc2012 Doc2012 is offline
Location: Stationed in Camp LeJeune, home is Conover, NC
Doc2012 has a spectacular aura about Doc2012 has a spectacular aura about
Doc2012's Avatar
Awesome damn write up man.
Now, to get the gf to allow me to purchase one of these.......
"We are experts in the application of violence."
-LtCol Christian Cabannis, Camp Letherneck, Afghanistan, 2009. The "Summer of Decision."
Doc2012 is offline   Reply With QuoteReply With Quote
Old 11-27-2014, 11:35 PM #4
RussToy's Avatar
RussToy RussToy is offline
Real Name: Russel
RussToy is an unknown quantity at this point
RussToy's Avatar
Real Name: Russel
I agree with Doc...great write up!
This really frustrates me...these guys can make this snorkel kit and sale it for a profit at $170 with free shipping! Then ARB makes a very similar snorkel...yet they sell theirs for over $400 plus shipping! Come on...why does ARB have to charge so much for their products?? I know it's quality stuff...but damn!!
RussToy is offline   Reply With QuoteReply With Quote
Old 11-27-2014, 11:36 PM #5
Kryptoroxx's Avatar
Kryptoroxx Kryptoroxx is offline
Real Name: John
Kryptoroxx has a spectacular aura about Kryptoroxx has a spectacular aura about
Kryptoroxx's Avatar
Real Name: John
Indeed a great writeup. Shows everything needed to pull thus mod off...and it doesn't cost 400 bucks.
98 Toyota 4runner 3rz 5spd 4x4 - Sold Build Thread
06 4runner 2uz Build Build Thread
Instagram: @Kryptowerkz
Kryptoroxx is offline   Reply With QuoteReply With Quote
Old 11-28-2014, 12:18 AM #6
Dirtyfingers's Avatar
Dirtyfingers Dirtyfingers is offline
Real Name: Trevor
Dirtyfingers is on a distinguished road
Real Name: Trevor
Yeah I just bought mine for 130 on eBay. I was hesitant on buying one because I wanted to get ditch lights but it seems like I should be able to clear thin with this snorkel.
98 4Runner V8 tundra swapped 'Lucky' This that and another. My build http://www.toyota-4runner.org/3rd-ge...ld-thread.html
"I say it all the time, my truck is a hybrid damnit, it goes on and off road."
Dirtyfingers is offline   Reply With QuoteReply With Quote
Old 11-28-2014, 01:54 AM #7
Real Name: Asa
Real Name: Asa
@MrHentoni is running this snorkel with ditch lights, close fit but it works
Old 11-28-2014, 07:49 AM #8
my92t4r's Avatar
my92t4r my92t4r is offline
my92t4r is on a distinguished road
my92t4r's Avatar
you are paying for R&D
Darn you OP, why did you have to post this now? I was going to hold up on anymore modding but now i want one so i can do my dual battery setup. Nice write up.
I pick things up and put them down
my92t4r is offline   Reply With QuoteReply With Quote
Old 11-28-2014, 02:26 PM #9
JWaldz's Avatar
JWaldz JWaldz is offline
Moderator
Real Name: Waldo
JWaldz is a jewel in the rough JWaldz is a jewel in the rough JWaldz is a jewel in the rough
Moderator
JWaldz's Avatar
Real Name: Waldo
ARB does have a specific snorkel in the works for the 3rd gen btw..
'99 Toyota 4Runner LTD - Dual Locked | Geared | Mid-Travel | 35s | Armored
Sponsors: Coastal OR | Extreme LED | SherpaEC | Overland GG
3G Build: ShowGirl | Instagram: ^Click Above^ | FB Page: JWaldz4R | T4R Mod: Contact Me
JWaldz is offline   Reply With QuoteReply With Quote
Old 11-28-2014, 02:55 PM #10
Real Name: Trevor
Real Name: Trevor
I'd like to see pictures if possible.
Old 11-28-2014, 05:24 PM #11
RussToy's Avatar
Real Name: Russel
RussToy's Avatar
Real Name: Russel
Have you seen any pictures of this. Where did you read this at? I'd like to see it also and try and find out when it might come out and how much??
Thanks
-Russel
Old 11-28-2014, 06:15 PM #12
MrHentoni's Avatar
MrHentoni MrHentoni is offline
Real Name: Tanner
MrHentoni is on a distinguished road
MrHentoni's Avatar
Real Name: Tanner
DLBs and 167 Series Hilux Snorkel
The bracket barely contacts the snorkel. I'm not too worried about vibrations since they are mounted very close and both to the body of the truck.
AND LIGHTS!!!
- 2000 Limited Desert Dune -
- CURRENTLY - Toytec BOSS C/Os, Total Chaos UCAs, OME 861s, FOX Remote Resi Rear Shocks, 315/75/16 Baja MTZs on Method Mesh Wheels, CBI Front and Rear Bumpers -
- Supercharged w/ 2.1 pulley, Tundra Brakes, and many others -
- HOPES AND DREAMS - Re-Gear, Fuel Mods and Tuning, Custom Rack, On-Board Air, and Shrockworks Full Skid Package -
MrHentoni is offline   Reply With QuoteReply With Quote
Old 11-28-2014, 06:27 PM #13
Real Name: Trevor
Real Name: Trevor
Sweet. Do you have it moved over like that because the light hits the tube?
Old 11-28-2014, 06:36 PM #14
MrHentoni's Avatar
Real Name: Tanner
MrHentoni's Avatar
Real Name: Tanner
nah... i just didn't want them sticking out as far, i did the same but opposite on the other side.
Old 11-28-2014, 07:54 PM #15
Real Name: Trevor
Real Name: Trevor
I see. So I should be able to fit then on there pretty comfortably.
Safari Snorkel confirms snorkel for 4th-gen coming 4WDToyotaOwnerMag 4th Gen T4Rs 488 11-01-2020 10:46 PM
Safari Snorkel releasing snorkel for 3rd-gen 4Runners 4WDToyotaOwnerMag 3rd gen T4Rs 127 03-28-2020 07:56 PM
Anyone have an fj with a snorkel? Iroke17 FJ Cruiser 1 05-26-2013 01:21 PM
Snorkel joeyporter 4th Gen T4Rs 2 09-30-2010 09:40 AM
3rd Gens and 4th Gens EVERYONE PLEASE READ!!! Matt Starr 3rd gen T4Rs 12 03-13-2009 02:22 AM
