Old 05-08-2021, 04:50 PM #1
Majkmichael's Avatar
Majkmichael Majkmichael is offline
Majkmichael is on a distinguished road
Stiff Steering (Fixed)
For the past year I've been dealing with annoyingly stiff steering. It progressively got worse as time went by. It felt like a sudden extreme tightness in my steering at certain points in a turn and overall stiffer than it should be. I replaced the rack, pump, lower ball joints, and had it aligned to no avail. The fix that did it was opening up the plastic cover behind my pedals and spraying the bearings on the steering u joint with WD40. Over time the grease dried up and became like a glue that was sticking the body of the u joint to the bearing race.
2002 Sunfire Red Pearl Sr5 Sport 2wd Bilstein 5100 Front/4th Gen Bilstein 5100 Rear OME 881/890
Majkmichael is offline   Reply With QuoteReply With Quote
Old 05-09-2021, 01:23 AM #2
pluton's Avatar
pluton pluton is offline
Real Name: Keith
pluton will become famous soon enough pluton will become famous soon enough
pluton's Avatar
Real Name: Keith
Good to hear of a problem and the simple solution, but if it were me, I'd attempt to re-lube them with an actual lubricant since WD-40 is not an oil or grease.
pluton is offline   Reply With QuoteReply With Quote
Old 05-10-2021, 07:19 PM #3
OpenYota OpenYota is offline
OpenYota is on a distinguished road
Do you think silicone lubricant would suffice?
2001 4Runner SR5 4x4
OpenYota is offline   Reply With QuoteReply With Quote
Old 05-10-2021, 08:44 PM #4
Good point, there's still grease in the u joint though. Just less of the dried up crap that the wd 40 took care of
Old 05-10-2021, 08:45 PM #5
Yes only after the WD40 though. Only problem is that its a ***** to get grease in those bearings easily
Old 05-10-2021, 09:31 PM #6
repo repo is offline
repo has a spectacular aura about repo has a spectacular aura about
I use white lithium grease for stuff like that, it lasts a long time.
99 SR5 v6 4WD
11 SR5 v6 4WD
repo is offline   Reply With QuoteReply With Quote
Old 05-10-2021, 11:04 PM #7
ads2539's Avatar
ads2539 ads2539 is offline
ads2539 has a spectacular aura about ads2539 has a spectacular aura about
ads2539's Avatar
It sounds like you need a new steering shaft. I donít know the exact 3rd gen part but, at least with the 4th gen, if spraying/lubing the u-joint fixes the stiff steering (temporarily), you need to replace the intermediate (?) steering shaft.
If youíre still on your original 3rd gen steering shaft, itís time for a new one. You got many years out of the original. I bought mine on eBay for a fraction of the OEM price. I couldnít get mine out myself (no air hammer), so I got a mechanic to do it in about an hour.
2004 Limited 4WD 180k miles. Stratosphere Mica paint, Stone interior. Too many mods to list here.
ads2539 is offline   Reply With QuoteReply With Quote
Old 05-11-2021, 02:48 AM #8
Malcolm99's Avatar
Malcolm99 Malcolm99 is offline
Malcolm99 will become famous soon enough Malcolm99 will become famous soon enough
Malcolm99's Avatar
The 4th gen and 3rd gen 4runners are completely different, 3rd gens don't have 99% failure rate of the steering shaft ujoint, being stored safely out of the elements, unlike the 4th gen 4R's and 2nd gen tacomas which have the ujoint completely exposed in the wheel well basically, so 3rd gen 4R's and 1st Gen Taco's don't typically need to change a steering shaft ever.
Note: I wouldn't use a ebay part for any steering components on any vehicle.
Malcolm99 is offline   Reply With QuoteReply With Quote
joint , opening , steering , stiff , time
Intermediate Steering Shaft Replacement - fixed steering clunk! Lamer 3rd gen T4Rs 6 01-20-2021 10:38 PM
Stiff Steering t4rFL 3rd gen T4Rs 23 01-07-2019 11:18 PM
Replace u-joint on steering linkage to fix stiff steering? sibanez 4th Gen T4Rs 2 09-30-2014 08:28 AM
Sticky/Stiff Gas Pedal Fixed Baja Runner 3rd gen T4Rs 0 08-25-2011 10:39 PM
Stiff Steering BigK75 4th Gen T4Rs 0 11-19-2009 11:33 AM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
