Originally Posted by nissanh
Remove the hatch panel and then take off the metal cover. Now you can see the ends of that wire harness attached to two wire plugs. Remove those.
Inside the hatch frame, this wire harness is mounted in two places, just remove those.
NOw remove the rear cargo lamp and its housing. Also remove the driver side cargo side panel (just enough to access the wire harness). Then you can slowly lower the cargo lamp area panel.
Then slowly bring down the hood liner. Use some kind of a supporting lever to make some space so you can access the wire harness.
Also remove the hatch top mounted brake lamp. Then to its bulb holder, attach a long wire (about 3-4 feet).
Now you have to pull the wire that is inside the hatch from the top (near the hinge).
Once you take the 3rd brake lamp wires out. Disconnect the 3-4 feet wire from the holder.
YOu can slowly lift the plastic rings attached to the roof area and the hatch area.
Hood liner? heh, I've heard all the limey terms for car parts, they of course don't have a hood, they have a bonnet. Never heard that one though, goes to show you there's always a first time.
Good advice on how to go about fixing it too!
