Old 05-10-2021, 05:01 PM #1
AJPuleo23's Avatar
AJPuleo23 AJPuleo23 is offline
AJPuleo23 will become famous soon enough
AJPuleo23's Avatar
Trans cooler line part #'s
It took some time, but I have finally tracked down what I believe to be the culprit of some spots under the truck. After cleaning under the 4runner, driving it around the block and checking (to see no spots) I finally pinned my fluid leak down.
It is a transmission fluid leak, and only when the fluid gets to temp/hot will it begin to leak.
I came across a thread where it looked like someone had a similar issue with a 4th Gen 4runner but am struggling to find much in regards to these lines on a 3rd gen.
Does anyone happen to know the OE part #'s for the trans cooler lines? I cant seem to find them searching through toyotapartsdeal and camelback and would prefer to put the OEM parts back in, but would be open to ideas if anyone has made this work with a bit of ingenuity.
Pics below... Excuse the makeshift diaper...
Trans cooler line part #'s-trans-cooler-1-jpg  Trans cooler line part #'s-trans-cooler-2-jpg
2001 SR5 | 275K+ | 3" Toytec Ultimate Coils | SPC UCA's | MotegiMR150 17x8.5 + Yoko Geo 295/70/R17 | 4Xi full drivetrain skids | OCD sway bar links F&R | Powerstop TBU | Opt OR Upper & Lower rear arms | MF Overland Exhaust | Retrofit LEDs | Vivid Lumen Fogs | Full Prinsu Rack | Front bumper retrofit/fat lip delete
1983 Pickup SR5 | 93K | LCE Street Headers | 31x10.5 BFG K02's, Full Desmog and Otherwise Original
1981 Pickup SR5 longbed | 142K |
AJPuleo23 is offline   Reply With QuoteReply With Quote
Old 05-10-2021, 05:35 PM #2
HiLife HiLife is offline
The inlet one that connects to the passenger side of the radiator is: 3292135270.
Drivers side (outlet) is: 3292235300
Used a 01 3.4L 4x4 sr5 for the pn search.
Old 05-10-2021, 05:56 PM #3
AJPuleo23's Avatar
AJPuleo23's Avatar
Thank you for this information. I very likely came across these parts, but was unsure because it is not in with the Automatic Trans section of various parts lists.
Safe to assume that the parts you sent marry with the rubber ATF hoses from the bottom of the radiator?
Old 05-10-2021, 06:08 PM #4
Those are Toyota part numbers, so it should be the same as your factory one. Sometimes Toyota does modify it's replacement part as a better designed one or a consolidation of a part number that's no longer made.
It should be able to hook up to your existing rubber hoses. I would check the rubber for flexibility while your replacing the hardline though, as older rubber tends to be less flexible and unable to conform to the new hardline surface imperfections and sealing them.
cooler , fluid , leak , lines , spots
Add A Trans Temp Gauge to Cooler Line DanielMaat89 4th Gen T4Rs 11 06-03-2017 07:42 AM
Re-Routing Trans Cooler Lines In Line With Rad Cooler Questions nc-grayson 3rd gen T4Rs 3 12-07-2016 09:09 PM
broke trans cooler line loose from radiator. how do i flush the transmission homeinspector 3rd gen T4Rs 6 12-01-2014 06:51 PM
TOYOTA OEM TRANSMISSION COOLER Trans Cooler nissanh For Sale: T4R Items 1 03-30-2013 10:24 PM
Is that a trans cooler or oil cooler in front of the AC Condensor? kn38ms 4th Gen T4Rs 8 06-05-2008 07:41 PM
