Old 05-11-2021, 11:40 AM #1
bmason8159 bmason8159 is offline
bmason8159 is on a distinguished road
Auto trans fluid level
Hi guys. Have a 99 Ltd auto trans, was in Texas doing some maintenance before traveling to New England. Decided to do a drain and fill in the trans, and only a little over 2.5 maybe 3 quarts came out. So I matched the fluid that came out to put back in.
I get back to New England and check the level after running it for about a half hour drive and the fluid level says it’s in the lowest of the cold level. I added two more quarts but it still says it low. I’ve never touched the trans before this. How much fluid is safe to add at one time?
bmason8159 is offline   Reply With QuoteReply With Quote
Old 05-11-2021, 12:09 PM #2
The 2WD and 4WD trans pan is different and so a drain and fill will be different between the two (4WD pan is larger).
The difference between the min and max lines on the dipstick is less than a quart, so be careful when adding fluid.
Make sure the fluid is 'fully warm' when checking the fluid level. The FSM says 154-176*F, I believe (for level checking).
Make sure you are checking on a level surface, the dipstick is not in the center of the pan and the level will change significantly when not reading from level.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 05-11-2021, 12:10 PM #3
Skulking Skulking is offline
Skulking is a jewel in the rough Skulking is a jewel in the rough Skulking is a jewel in the rough
Just to get it out of the way, the cold lines are only for reference doing an initial fill. The level you actually care about is going to be the hot level, and to check that you want the car on level ground at operating temperature with the engine running. Run the gear shift from park down through all the gears and then back to park, then check the fluid level.
As far as how much fluid you can safely add at one time, there isn't really an answer to that. You can safely add as much as you need to bring the fluid level to the correct range. Exactly how much that is depends on how low you are. I'd go with smaller increments and repeated checks to avoid overfilling.
If you were already up to the cold low level, 2 quarts should have moved the level on the dipstick a solid amount. Just to check, where are you adding the transmission fluid?
Skulking is offline   Reply With QuoteReply With Quote
Old 05-11-2021, 02:13 PM #4
Adding through the trans dipstick tube
Old 05-11-2021, 02:14 PM #5
Should I add the fluid when the truck is running or off is another question I had
Old 05-11-2021, 02:48 PM #6
19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold
Engine should be running and in park to check the level.
With my 4wd I just drain it and add 4qts. That dipstick is a pain to get in and out smoothly.
Old 05-11-2021, 04:40 PM #7
alumarine alumarine is offline
alumarine has a spectacular aura about alumarine has a spectacular aura about
Doesn't matter when you add it.
Does matter how you check it.
If you try and check it right after you add some you might get a false reading as it will take a bit for it to run down the dipstick tube and into the trans.
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
alumarine is offline   Reply With QuoteReply With Quote
Old 11-25-2024, 09:55 PM #8
fourfive's Avatar
fourfive fourfive is offline
fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough
fourfive's Avatar
Is this still correct? I actually need to add a little. I checked the FSM to see if they mentioned the atf fluid quantity between the min & max lines on the dipstick and didn't see it specified.
1. Black 2002 SR5 4x4 5vz: Front Toytec Ultimate coilovers/eibach 600#, SPC UCA, durobumps Rear Bil5100/Superflex, SS adjustable panhard, PCK, durobumps Body Lift 2" 4crawler Tires 315/75/16 BFG KO2 Wheels SCS F5 Matte black 16x8 3.5bs Armor Custom bolt on rock sliders (no frame drilling)
2. Black 2001 SR5 4x4 5vz: stock
3. Black 2018 TRD Pro (wife’s): Armor Custom bolt on rock sliders (U-bolts)
fourfive is offline   Reply With QuoteReply With Quote
Old 11-26-2024, 01:08 PM #9
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
I would run it through all the gears, then in park check it on level ground. then add if needed then let it sit a bit so fluid can drain down into pan and your not getting a false reading on dip stick
2002 tundra ac v8 4wd
1969 kharmann ghia
back , fluid , level , quarts , trans
Can you check the trans fluid level without the dipstick? jross20 3rd gen T4Rs 28 04-21-2020 04:15 PM
trans fluid level....again 3bears 3rd gen T4Rs 8 08-25-2015 02:42 PM
Auto Trans Fluid Capacity Help PrinceYota 3rd gen T4Rs 16 07-29-2013 05:17 PM
Auto trans fluid change advice needed z28forlife 3rd gen T4Rs 8 02-12-2012 12:44 PM
Do you check the trans fluid level with the engine warm and running??? Jeff T 4th Gen T4Rs 6 04-22-2011 06:45 PM
