05-13-2021, 04:30 PM
Why lock the steering wheel when replacing rack bushings?
Everything I've watched or read says to make sure the steering wheel is locked when replacing the rack bushings because you can mess up the steering wheel alignment if you don't. I can't wrap my head around how this would happen unless you disconnected the rag joint from the rack. It seems like as long as the rag joint isn't disconnected, and you just remove the rack mounting hardware, the position of the rack is tied to the position of the steering wheel. Am I missing something?
1997 SR5, 3.4L, Manual
05-13-2021, 04:37 PM
You're not missing anything, but I don't think you have enough room to press the bushings unless you disconnect the intermediate shaft from the rack.
05-13-2021, 05:13 PM
In the 2 videos I've watched the intermediate shaft wasn't disconnected.
05-13-2021, 07:22 PM
I've done it on a 1st gen sequoia and 4runner, no locked steering and no removing shafts. But you will need a 2nd set of hands....
05-13-2021, 09:01 PM
How so? Was planning on flying solo.
05-13-2021, 09:20 PM
Did it without disconnecting steering shaft or having it locked and also did it solo (several times). Its not the easiest thing to do but it’s not the hardest by any means..
05-13-2021, 09:21 PM
The main reason for locking the steering wheel is so if you disconnect the rack from the steering shaft, you don't rotate the steering wheel and break the clock spring.
98 SR5 4X4 5spd, desert dune metallic, Toytech Eibach 3" lift, 1" body lift, RAD Rubber Designs splash guards, 4XInnovations bumpers, Doug Thorely Headers, Magna-flow converter, JBA muffler & tail pipe, RCI skid plate, SPC UCA's & rear LCA's, front sway bar links on rear, gen II rear links on front, Tundra brakes, '02 headlights, tail lights & sidemarkers, BFG 255/85R16 Mud Terrain T/A's 241,000 miles.
05-13-2021, 10:37 PM
Sounds like it's not super important but I'll probably lock it just to be safe. Since I'll be doing the LBJs and inner tie rods at the same time I was mainly just wanting to be able to turn the wheels so I can get to all the LBJ bolts. But I'll disconnect the tie rods first then I can rotate the knuckles all I want with the steering wheel locked.
05-14-2021, 08:36 PM
Real Name: Bill
Real Name: Bill
I did my steering rack bushings a while back and forgot to lock the steering wheel and when I was finished the steering wheel was off center about an inch and a half to the left. When I asked the mechanic about it he said " did you forget to lock the steering wheel? Ha!
'97 T4R LTD 4WD desert dune, bone stock, factory E-locker, RS3000, Scangauge II, Hella 450's, 191k
05-14-2021, 11:38 PM
Interesting. I still don't understand the mechanics behind how that can happen but I guess I'll just do as I'm told. haha.
05-15-2021, 01:33 AM
Weird, the bolts still have to go in the same holes, and besides the passenger side collar, they go directly through the rack. Don’t see how the steering could shift unless maybe you got an alignment while the vertical bushings were gone.
I did mine while the diff was out, which made it easier I guess.
05-16-2021, 12:55 AM
Well I couldn't figure out how to lock the wheel so I just went for it without it being locked. The steering wheel is now very slightly to the left, but before I did it the wheel was very slightly to the right by about the same amount. It feels like it drives straight and isn't pulling to either side but I guess I'll take it in for an alignment on Monday.
Sent from my moto x4 using Tapatalk
05-17-2021, 11:44 AM
Real Name: Patrick
Real Name: Patrick
If the vehicle isn't pulling then you can remove the steering wheel airbag, remove the steering wheel and move it over a spline (or more as required) toward center and reassemble. What happens is the steering rack holes for the bolts are a close fit, but not a perfect fit so the rack can be off from where it was originally ever so slightly. It doesn't have to be off much for your steering wheel to change.
05-17-2021, 09:20 PM
Just got back from the alignment shop. I went to a different shop that uses lasers and computers and I'm glad I did. Everything was off. Steering wheel is straight as an arrow now.
05-18-2021, 08:48 AM
Real Name: Patrick
Real Name: Patrick
I didn't know there were still alignment shops that didn't use a newer style laser alignment machine.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
