Old 05-15-2021, 08:42 AM #1
RobS10 RobS10 is offline
RobS10 is on a distinguished road
'99 with original radiator, want to avoid the dreaded Strawberry Milkshake
We have a '99 4Runner with 197K miles. Our local trusted mechanic has changed the water pump when replacing the timing belt at the regular intervals, and completely flushed and refilled the coolant system with Toyota Red coolant.
The radiator is original and have just found out it's a potential time bomb, just waiting to take out our tranny with the dreaded Strawberry Milkshake Trans Cooler failure. Our mechanic said he could order a new Toyota radiator and do all the work for around $500 - OUCH! He also said he might be able to tell from looking inside the radiator core if it was getting bad. Does this sound legit? If it should be replaced, is there an Aftermarket brand that's better than the Toyota, or can we expect that a new Toyota brand radiator will get us to at least 250K miles?
Thanks!
RobS10 is offline   Reply With QuoteReply With Quote
Old 05-15-2021, 09:07 AM #2
tgreenwood75's Avatar
tgreenwood75 tgreenwood75 is offline
tgreenwood75 is on a distinguished road
Last I knew, the Koyo and Denso radiators were both around $100 and seem to be the most commonly used options on this site. I know that both have some quality control complaints so maybe somebody else will chime in with their opinion.
I personally ordered a Denso online and swapped it in my driveway in ~1hr, super simple job. I would imagine you can do it yourself or get out of it for $200 paying your mechanic for an hour of his time. That's a lot cheaper than gambling your tranny!
2001 T4R 4x4 3.4L AT - Bilstein 5100s, OME Coils, Wildpeak AT3Ws, 230k miles, Rust
tgreenwood75 is offline   Reply With QuoteReply With Quote
Old 05-15-2021, 09:20 AM #3
Thanks tgreenwood75. I hear you on paying a shop. I used to do almost all of my own wrenching, but the older I get, the less I want to mess with it :-(.
Old 05-15-2021, 09:33 AM #4
zcruiser's Avatar
zcruiser zcruiser is offline
zcruiser will become famous soon enough zcruiser will become famous soon enough
zcruiser's Avatar
Get a B&M 70268 SuperCooler and have him install it as a bypass to the stock transmission cooler section of your existing radiator. Disconnect the lines from your stock radiator and run them through the B&M instead.
Drain & clean the lower section then shunt the two stock lines together in case you ever do have a breach.
2012 4Runner Limited, Shoreline Blue Pearl / Beige leather, RCI skid, ext rear diff breather, Derale 13504 cooler, 110K
1993 300ZX Cherry Red Pearl with some bling, K&N intake, PowerTrix suspension, 130K
zcruiser is offline   Reply With QuoteReply With Quote
Old 05-15-2021, 10:11 AM #5
I thought of that, but was a little apprehensive at going with air cooling for the transmission. I read the internal radiator tranny cooler is a better all-around set up. Every vehicle I've owned has used that design and never had a problem, and I'm talking even 1970s/80s crappy American vehicles. A little disappointed in Toyota over this one :-(.
Old 05-15-2021, 10:50 AM #6
jgue467's Avatar
jgue467 jgue467 is offline
jgue467 is a jewel in the rough jgue467 is a jewel in the rough jgue467 is a jewel in the rough
jgue467's Avatar
Originally Posted by RobS10 View Post
... Every vehicle I've owned has used that design and never had a problem, and I'm talking even 1970s/80s crappy American vehicles. A little disappointed in Toyota over this one :-(.
So the oem radiator from toyota has lasted about 22 years and you're dissappointed or is it they choose a similar design as crappy american cars? BTW other foreign jobs ran the same setup too...
And yes it will get hotter than you like without the built in cooler, I've run with only an external in 100+ weather, towing in stop/go, trans temps will go well over 200 to nearly 230, ouch. Linked internal cooler back and temps never go above 197 now at the trans. Luck.
2001 Limited 4WD - 333+K - SunfireRed\Thunder Cloud; - 265/75/16 Michelin A/T2s - Fat Pat's 1.5" BL, ZERO RUST - StopTech ANGLED rotors - Magnefine trans filter - In series trans cooler, ORIGINAL: paint, engine, 4wd, trans, mstr cyl & brake system, rear axle seals, A/C, steering pump, steering rack, front/center/rear diffs, all electric motors, seat heaters and so on. WooHoo!!
Oh yeah, GO LONGHORNS!
Old 05-15-2021, 11:00 AM #7
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot is a glorious beacon of light Devbot is a glorious beacon of light Devbot is a glorious beacon of light Devbot is a glorious beacon of light Devbot is a glorious beacon of light
Devbot's Avatar
Real Name: Devan
$500 to replace a rad?
Hope you don't consider him a friend cause he's shafting you
Y2K Highlander Millennium Silver 3.4L auto @ 295k and climbing
Tundra TRD Lift in Front / LC Lift in Rear / JBA UCAs / CVJ 9168R Axles / Diff Drop / PCK / Extended Bump Stops; Brake Lines; Sway Bar Links; Rear Diff Breather / True North Fab. Hybrid Bumper / Smittybilt XRC Gen 3 Comp. / Northstar 880CCA AGM / Drivelines NW Rear Shaft / Lil Skip Gas Skid / BudBuilt Front Skid
Old 05-15-2021, 11:05 AM #8
Yeah, I guess a little disappointed that something that could cause such a catastrophic problem wasn't engineered a little better. If the problem was due to running cheap coolant or allowing the radiator to run low or overheat, that would be different. But on a well maintained vehicle, running Toyota Red coolant? When I looked up this issue, it' wasn't just on vehicles that were currently 22 yrs old, but dates back quite a few years when the vehicles were a lot newer. Frame rot is another Black Mark for the venerable Toyota brand. No excuse on that one, after all these years!
As far as American vehicles, my 1984 Dodge pickup has the same set up, and never heard of this problem on ANY vehicle until someone on a Toyota FB page pointed out that 3rd Gen 4Runners seem to have the issue. My Dodge does have other issues, to be sure ;).
Old 05-15-2021, 12:52 PM #9
Endlessblockades's Avatar
Endlessblockades is just really nice Endlessblockades is just really nice Endlessblockades is just really nice Endlessblockades is just really nice
If you really want to go ham on the trans protection/cooling situation, get an OEM radiator, new upper and lower hoses, an OEM thermostat (6 O'clock juggle valve), new Toyota coolant, run a B&M trans cooler in series with the radiator and pop in a Magnafine filter. You can do all that yourself in an afternoon for WELL under $500 - if you have a place to work and the time. Living in the City myself, I know that can be an issue. I can use the parking lot at my job on weekends (until told otherwise LOL), but I have also brought parts I have purchased online that I didn't have the wherewithal to install (suspension, ball joints) to a shop and negotiated a labor deal. I use the Toy Shop on Geary for that. I think we may have spoken about that place in another thread?
Y2K/E - SLOW AND LOW
Old 05-15-2021, 05:34 PM #10
Includes new Toyota radiator, upper and lower hoses and thermostat, flush system and all new Toyota coolant. Everything in San Francisco is stupid expensive
Old 05-15-2021, 05:38 PM #11
Yes, Toy Shop was the quote and included everything you mention, sans extra cooler. I may end up doing it myself if I get inspired. I used to do everything, many clutches, engine swaps/rebuilds, more oil changes than I can possibly count. But I'm getting old and lazy ;-).
Old 05-15-2021, 07:13 PM #12
Cree's Avatar
Cree Cree is offline
Cree will become famous soon enough
Cree's Avatar
It warms faster and stays warmer in the winter. No difference in the summer. In fact, you'll run cooler not sharing the radiator.
If you want to avoid that, you can install a thermal bypass in line with the cooler OR get a cooler that's internally bypassed. I'll be switching to the Hayden internal bypass this summer to get temps up in the cold a bit. Right now I have a single Hayden 679, gonna switch to dual 699's. That ought to do the trick.
00 Limited - Stuff!
18 Audi A6 Quattro 3.0T - No stuff, Just boost
Cree is offline   Reply With QuoteReply With Quote
Old 05-15-2021, 07:53 PM #13
TheSaturnV TheSaturnV is offline
TheSaturnV will become famous soon enough
...and I'm talking even 1970s/80s crappy American vehicles.
One of the finest vehicles I've ever owned.
'99 with original radiator, want to avoid the dreaded Strawberry Milkshake-1981-chevrolet-camaro-z28-jpg
"Not everyone is cut out to be a 3rd Gen owner."
2000 Black LTD with ELOCKER, almost 100% stock
TheSaturnV is offline   Reply With QuoteReply With Quote
Old 05-15-2021, 10:02 PM #14
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Oh that's pretty average shop pricing then
Old 05-15-2021, 10:08 PM #15
FD7683 FD7683 is offline
FD7683 will become famous soon enough
I would say that $500 is too much for them to replace it when you could order an OEM unit for around $100-200 and replace it yourself. Last time I checked they were around $100 but I didn't chose to replace it because mine isn't brown colored (replaced before). Tbh, I looked at a video on how to replace it and it isn't too bad of a job.
2000 4Runner Limited 4x4 Sport Edition V6
brand , coolant , mechanic , radiator , toyota
Another Strawberry Milkshake.... 4runnerWiniarski23 3rd gen T4Rs 20 08-21-2016 04:53 PM
New Radiator to avoid pink milkshake freshley 3rd gen T4Rs 40 10-18-2013 04:40 PM
Strawberry Milkshake ledger35 3rd gen T4Rs 5 02-04-2013 07:48 PM
Strawberry Milkshake SmokEaterHD 3rd gen T4Rs 69 02-09-2012 02:21 PM
strawberry milkshake - help KROCK 3rd gen T4Rs 4 11-27-2010 08:03 AM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
