Hey guys,
Installing a lift this weekend I had a total brain fart about how the cam adjusters work. I attempted to loosen them by cranking as hard as I could on the adjuster NUT rather than the bolt... which wiped out two of the tabs the cam rests on. Doh!!
Here's what I need your help with:
- Will I need to replace these tabs? I could get a
Total Chaos kit or I'm thinking I can bend the tabs back up and weld them from the outside.
- Would a cam eliminator kit fix my problem, and would using it allow me to forgo fixing the cam tabs? Or does the kit still rely on having intact cam tabs?
- If my alignment guy can manage to align it anyway and torque down the adjusters well do you think they will stay put without the tabs for street driving?
Thanks!
