Originally Posted by texadelphia
The way I figure, I weigh 150 lbs and I was pulling down on the torque wrench so if it's about a foot long the most I could put into it would be 150 ft-lbs before I was doing pull ups on the torque wrench. Lol. But it might be a little longer than a foot. Still seems like there should be a bigger factor of safety on the hardware.
Sent from my moto x4 using Tapatalk
Just so nobody makes the mistake of assuming their mass (weight) is small enough to hang on a torque wrench - the lbs in ft-lbs is pounds - force. You need to multiply your mass (150 lbs) by the acceleration of gravity to get the true force. I believe gravity is ~32 ft / sec^2. Thus, a 1 ft long torque wrench with you hanging off it would be 4,800 ft-lbs of torque.
