Old 05-16-2021, 01:11 AM #1
texadelphia texadelphia is offline
texadelphia will become famous soon enough
Polyurethane steering rack bushing question.
I replaced my steering rack bushings with a Whiteline poly set today. I couldn't get the driver side bushing bolt to torque to 141 ft lbs...it just kept turning. The edges of the bushing were also bulging out from behind the washers. It seemed kind of strange how much it was bulging. Anyone notice this bulging with other poly sets?
Sent from my moto x4 using Tapatalk
1997 SR5, 3.4L, Manual
texadelphia is offline   Reply With QuoteReply With Quote
Old 05-16-2021, 03:15 PM #2
T4topher's Avatar
T4topher T4topher is offline
T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light
T4topher's Avatar
Dang man that doesn’t look right for sure. Did it have a metal sleeve inside? That’s what the nut/bolt should be bottoming out on, not the bushing itself.
T4Tophers build (click here)
T4topher is offline   Reply With QuoteReply With Quote
Old 05-16-2021, 03:43 PM #3
Definitely had a sleeve. Seems like the sleeve is too short.
Old 05-16-2021, 04:09 PM #4
T4topher's Avatar
T4topher's Avatar
That’s what I would guess, even the bolt has way too many threads poking out the back. You sure you didn’t put the drivers side sleeve in the center bushing? I have about 4-5 threads showing past the nut for the driver side bolt.
Old 05-16-2021, 06:45 PM #5
Definitely didn't do that. The center bushing sleeve is noticably shorter.
The nut did get very tight, I just got freaked out towards the end that my torque wrench wasn't working and I was tightening it too much. I'm guessing I was just shy of hitting 141.
In the moment I thought that I was just smashing the bushing between the washer and the subframe. But in retrospect I had to be up against the sleeve because the bushing material that squeezed out would have sheared of given how tight I had it. My guess is Whiteline just made the sleeve slightly shorter than it should have been so the gap for the flange of the bushing was smaller and caused it to squeeze out.
Old 05-16-2021, 09:18 PM #6
photoleif photoleif is offline
Real Name: Leif
photoleif will become famous soon enough
Real Name: Leif
in the photo, it looks like it's on the outside. isn't it supposed to be on the inside?
'99 'Highlander' 4R SR5 5VZ-FE | 5-spd | LED lighting | TBU | 265-75R17 Duratrac stuffed after some pinch-weld convincing
'95 Xtra cab 5VZ-FE swap 5-spd | 33x10.50-15 BFG AT/KOs | 4" Superlift | ARB rear locker | OME torsion bars | Total Chaos idler arm & uniball | Smittybilt bumpers | Sportsman topper | Aisin manual hubs | K&N | Dual Optimas | Extended diff breathers | Bilstein 5100s | De-striped | Hella pencil-beams
photoleif is offline   Reply With QuoteReply With Quote
Old 05-16-2021, 10:04 PM #7
T4topher's Avatar
T4topher's Avatar
Hmm well something is definitely off, I’d be tempted to contact whiteline. Did you compare the size of the sleeve to the one you pulled out with the old bushing? Also were all the other bolts already in place when you did this one?
Old 05-16-2021, 10:35 PM #8
Unfortunately I didn't think to compare them. Yes all the other bolts were in and torqued before I attempted to torque this down completely.
Old 05-16-2021, 11:09 PM #9
Skulking Skulking is offline
Skulking is a jewel in the rough Skulking is a jewel in the rough Skulking is a jewel in the rough
You can always figure out where you are at torquewise by setting your torque wrench low (For this maybe start at 80ft-lbf), and tighten the bolt. If your wrench immediately clicks, you are at least that high. Increase your torque setting by a reasonable amount (Maybe 5 or 10ft-lbf in this case), and try again. Work your way up until it stops clicking, and you know the window your torque is within.
Skulking is offline   Reply With QuoteReply With Quote
Old 05-17-2021, 11:56 AM #10
I don't follow what you mean.
Old 05-17-2021, 11:57 AM #11
Makes sense. In hindsight, I should have done this.
Old 05-18-2021, 12:10 AM #12
Real Name: Leif
Real Name: Leif
sorry i wasn't super-clear there. in the bushing kit i used, the large thick washer was to be positioned immediately next to the bushing sleeve on the forward side of the vehicle. i'm not sure here, but it could be that the image you posted showed that washer on the aft side of the bushing. i could be looking at it wrong. see @mtbtim 's vid:
Steering Rack and Front Sway Bar Bushing Replacement Tutorial - YouTube
i set the time to a couple seconds before he positions the washer. again, i could just be looking at your photo wrong, so ignore me if you did this.
Old 05-18-2021, 12:33 AM #13
T4topher's Avatar
T4topher's Avatar
For reference this is what my energy suspension kit looks like.
Old 05-18-2021, 09:19 AM #14
The Whiteline kit came with 2 washers so there's one on the fwd side between the bushing and the cross-member, and one on the aft side between the bushing and the nut.
Old 05-18-2021, 09:21 AM #15
That's what I expected mine to look like when it was done.
I've been in contact with Whiteline and they initially said that I torqued the bolt down too much. I responded back with how that shouldn't be possible if the sleeve is the right length and they haven't replied yet.
bulging , bushing , poly , rack , steering
Does anyone make polyurethane steering rack bushings for 4th gen? luke87gt 4th Gen T4Rs 8 02-01-2016 11:06 PM
03-12 Polyurethane bushing kit (for front uca's & lca's) mpower228 For Sale: Suspension/Wheels/Tires 0 03-19-2012 05:35 AM
03-12 Polyurethane bushing kit (for front uca's & lca's) mpower228 For Sale: T4R Items 0 03-19-2012 05:17 AM
