Old 05-17-2021, 04:17 PM #16
eimkeith's Avatar
eimkeith eimkeith is offline
Official Vendor
eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light
Official Vendor
eimkeith's Avatar
also check for play in your tcase output flange - mine had 1/4" side-side, up-down movement! (mimics a bad U-joint)
keith
eimkeith.com
all product descriptions © eimkeith LLC 2016-2023
eimkeith is offline   Reply With QuoteReply With Quote
Old 05-17-2021, 04:48 PM #17
Originally Posted by G_Raw View Post
Thanks @phattyduck and @Bad Luck for the rear link info. I already have adjustable lower links which did help but I do understand that the uppers are specifically what changes your pinion angle. How much longer are the ad uppers than 2wd one? I'm about to order upper adjustables and would like a good starting point for length.
Adjusting the lower would do it too, but would bring the axle closer to the front of the truck. I don't have any side by side comparisons, but it was about 1 bolt width, if I remember correctly.
Oh, found a pic from somebody else:
You want to basically match the pinion angle to the driveshaft instead of the transmission output.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 05-17-2021, 04:56 PM #18
G_Raw's Avatar
G_Raw G_Raw is offline
G_Raw has a spectacular aura about G_Raw has a spectacular aura about
G_Raw's Avatar
The adjustable lowers at their shortest are stock 2wd length so I can't bring the axle closer to front. So I would need to adjust the uppers to rotate the pinion properly.
@eimkeith thanks for that. I'll check it out as well. While you're here oh pan hard master. You see no issues with that pan hard angle?
99 Limited: 4wd conversion, OME 883/891, Built Right UCAs, Armored and winch up front, 285's with 4.88s and dual locked.
G_Raw is offline   Reply With QuoteReply With Quote
Old 05-17-2021, 05:02 PM #19
eimkeith's Avatar
Official Vendor
Official Vendor
eimkeith's Avatar
It'll feel/track better with correction, but that angle shouldn't be causing your vibrations, IMO.
keith
eimkeith.com
Old 05-17-2021, 05:24 PM #20
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
I don't have a clue on length, but you want the rear axle pinion to point slightly below straight through the driveshaft. I use a magnetic angle finder like this one: Wixey Digital Angle Gauge Type 2 with Magnetic Base and Backlight: Amazon.com: Industrial & Scientific. With the vehicle on all 4 wheels under it's own weight put the angle finder on the driveshaft lengthwise either at the very bottom (6 o'clock) or very top (12 o'clock) and zero it out, then remove the driveshaft from the rear pinion and place the angle gauge on the pinion flange vertically (the display will face either 3 o'clock or 9 o'clock), adjust your upper/lower control arms until you reach 88 (or 92) degrees. Make sure you jounce/bounce the rear suspension after each adjustment.
EDIT: Drive Shaft Angles Explained - YouTube 4wd driveshaft starts around 7:30
Old 06-07-2021, 08:58 PM #21
G_Raw's Avatar
G_Raw's Avatar
Sorry folks... took a bit to get the arms. They were back ordered. Then had family visiti mg. But I swapped em out today. Feels better but vibes are still there. Got them on to late to do a freeway run to really see how bad they still are but I'll do that tomorrow once morning traffic dies out.
Weigh in on my panhard-20210607_142901-jpg  Weigh in on my panhard-20210607_142908-jpg  Weigh in on my panhard-20210607_142851-jpg  Weigh in on my panhard-20210607_145706-jpg
2wd , axle , drive , put , stock
Panhard Correction Kits for the 4th gen - fix that panhard bar angle! eimkeith 4th Gen T4Rs 109 01-08-2021 04:21 PM
How much does it weigh? patkelly4370 General Discussions 1 01-04-2020 03:16 PM
How much does your 3rd gen weigh? papabeach 3rd gen T4Rs 42 09-29-2018 09:50 PM
Anyone ever weigh their T4R? I did. Xplore 5th gen T4Rs 13 04-02-2017 02:33 PM
How much does the cap weigh? SEoperator77 Classic T4Rs 16 10-19-2011 03:46 PM
