05-20-2021, 12:26 PM
#16
Real Name: Patrick
Real Name: Patrick
Originally Posted by biglar
Kinda semi-moot, I guess. I plan on installing the trans cooler before I leave and doing that will spill some and add capacity as well, that will need to be topped up. I'll count that as a partial drain/refill.
That's less than a quart between added capacity and how much fluid you'll lose.
Trans fluid isn't pristine but not dark and doesn't stink, either. My feeling is that lubricating qualities are prob'ly OK, but like the idea of fresh plus fresh additives. Then do a transmission drain and fill.
I'm debating adding a thermostat control on the cooler to keep temps in a good range in cooler weather....but I'm on a tight budget and can't spend $100's on it. Any suggestions would be welcome. Larger coolers have built in fluid bypass. Look at TruCool fluid coolers to see which ones come with a low pressure bypass.
Also very open to the idea of manual shut off valves to cooler so I can choose when to use it. Ideas for which valves would be useful, too. I want to be very sure that anything I put on there would be temperature and fluid compatible.
If you decide to do valves make sure that the fluid has a way to return to the transmission rather than a simple on/off valve. All fluid used in the transmission heads to the cooler. If you try to stop that bad things will happen.
My comments in bold.
05-20-2021, 12:35 PM
#17
Having some fresh trans fluid in there with a single (or maybe two) drain and fill(s) before your trip will be all you need. 100k is not horrible for the A340, but if you want to keep it a while, catch back up on the maintenance.
Oh, yeah - consider doing the rear diff, transfer and front diff gear oil while you are at it. Those are often totally neglected, and you have 0 risk of negative effects by changing out those fluids.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
05-20-2021, 05:31 PM
#18
Didn't see it mentioned, but another possibility I've read about over the years is that when you do a thorough flush, fine particles are removed that might have actually been helping worn out clutch plates to grip. Once everything is flushed clean, discs and plates begin slipping which might explain transmissions "failing" soon after this type of service.
"Not everyone is cut out to be a 3rd Gen owner."
2000 Black LTD with ELOCKER, almost 100% stock
05-21-2021, 09:54 AM
#19
Real Name: Patrick
Real Name: Patrick
A further explanation of the same old mechanic's myth. There is no evidence behind that claim. If that was true then people would be adding finely ground metal to their transmissions when they start slipping.
05-21-2021, 10:59 AM
#20
Right on!
05-21-2021, 12:24 PM
#21
Banned
Real Name: Tommy Bahamas
Banned
Originally Posted by Sarki
Like many others here I just pop the trans pan plug out every other engine oil/filter change which I do at 5K intervals.
Just did this today and noted 4 1/2 quarts drained out. Refilled with fresh Valvoline Max full synthetic.
Original trans with 191K.
i like this by sarki
But can you safely mix it with the WS that's in there?
05-21-2021, 12:34 PM
#22
Well, he's running a 2002 that came with T-IV. Your transmission came with WS.
05-21-2021, 12:50 PM
#23
this is the 3rd gen section... no 3rd gen came with WS.
05-21-2021, 12:58 PM
#24
no need to add a thermostat control to an aux trans cooler, run it as designed in series with the rad cooler & the fluid will get heated in cold weather by the radiator, then the fluid goes to the aux cooler to get cooled some & then back to t he trans. this is how all aux cooler companies suggest doing it & is how toyota does it on vehicles with trans coolers/towing package. check out b&m or hayden stacked plate style coolers, mid size haydens are less than $100 & work great.
running on just the cooler as some do is not a good idea, in cold weather the trans fluid doesnt get to operating temp fast enough & when it stop go traffic the cooler doesnt get any airflow that is needed to function, causing too high of fluid temps.
& i agree with everyone else that says changing trans fluid at 100k or more will not harm a healthy trans, old worn out fluid will. the stories on this came from neglected trans that had other issues or more so from shops doing a power flush with a machine that may dislodge some debris & cause problems. doing a pan drain & fill or using the engine to pump out ~2qts at a time & adding the same 2 qts wont harm a healthy trans.
05-21-2021, 07:39 PM
#25
My experience with adding a B&M trans cooler in series with a new radiator has has been problematic as far as getting trans fluid to a reasonable temperature during the colder months here in the northeast.
Even after driving 30-45 minutes fluid temp would remain between 95-115 and rarely reach 120. Outside temps weren’t typically below 30F.
Even mildly cold outside temps would keep trans fluid below 120.
Have been considering removing the cooler though it does come in handy when stuck in summer city traffic when temps are above 90F.
Thinking that prolonged trans fluid temps between 100 - 125 F can’t be good for long term trans health.
Trans temp monitored by Scangauge.
2002 SR5 Sport 4WD
05-22-2021, 11:29 AM
#26
im in iowa where winters can be below 0f for weeks straight, even in mild temps it takes the trans fluid quite a while to fully warm up. doing the fluid check at temp via toyotas jumper process can take 15-20+ minutes to get to the 115-130 range but after that it gets to 150+ pretty quick, so its not really "prolonged" or going to harm the trans. i monitor my temps with OBD scan gauge & the torque pro app.
trans fluid temps take awhile to get to the 160-170 ideal temps even with a factory aux cooler so i dont think 30-45 minutes time causes any harm to the trans or fluid, much better to be on the cool side than too hot. was just saying that bypassing the rad cooler is not a good idea & will take a lot longer to get to temp in the winter without the rad cooler in series & can cause severe damage to only use the aux cooler in summer stop & go traffic or towing. but you can always slip in a piece of cardboard to block the trans cooler in the winter if needed.
i have ran aux coolers for 20+ years in my daily driver SUV's that do some light towing as well as higher horsepower street/strip muscle cars, never had a too cool problem & probably saved the trans in my previous jeep cherokee i towed regularly with for long trips in 90f temps for welll over 100k miles.
just wanted to post what the transmission & cooler manufactures say is the best way to run a cooler.
05-22-2021, 11:53 AM
#27
Actually your suggestion about blocking the radiator with cardboard in the winter is something I’ll be trying this coming winter.
This past winter even after driving for 1-2 hours in 30-40 degree temps my trans fluid stayed below 120-125.
It would never exceed 125 regardless of how many hours I drove.
2002 SR5 Sport 4WD
05-22-2021, 11:57 AM
#28
strange they stay that low that long, but i supposed each case is different. maybe the aux cooler is too large for your needs, i use a mid size coolers for my vehicles, about 12" wide by 10" tall.
heres a good chart for trans temps, 125f isnt terribly low, i think the damage at prolonged low temps is more like 100 or below.
05-22-2021, 03:18 PM
#29
Installed B&M 70264 which is on the small side. Have been very surprised at the low temps it’s generated.
Great in the summer but not so great in the winter.
2002 SR5 Sport 4WD
05-23-2021, 12:00 PM
#30
those stacked plate coolers are very efficient compared to the tube style. i use about the same size on my cars but the hayden brand thats priced a little cheaper.
the cardboard should help a lot.. or use a smaller cooler?
