05-19-2021, 12:14 PM
#16
Originally Posted by CT135
Are you running the cooler in line with radiator or bypassing?
Bypassing. I’ll attach some photos here, though they may not be great
05-19-2021, 12:16 PM
#17
Real Name: Patrick
Real Name: Patrick
Originally Posted by Endlessblockades
That LPD4589 looks pretty nice. Did you use the hose that came with the kit for the '11/32 hose barb'? Does that fit our hard lines?
I recently put in a new radiator, so I'm OK with series or bypass - what would you recommend?
I have the same cooler (TruCool 4589) I used 3/8" ID hose and bypassed the radiator. The LPD operates similar to a thermostat but based on viscosity/pressure rather than temperature. Temperature/viscosity/pressure all change according to temperature so it's just a different way of determining if the fluid needs to be cooled or not. I haven't had any issues this way, but I live in the south where it doesn't freeze much during winter.
05-19-2021, 01:41 PM
#18
Awesome, good to see temps that low with your cooler bypassing the rad. I don't have a tranny temp gauge but am running a trucool 4590 (11x11x1.5). Its a crazy big cooler but not seeing temps still can make me uneasy. After seeing your numbers i'm pretty sure i'm always ok towing in the summer.
97 Limited, 5100’s, OME 883/891, Built Right UCA, Custom Sliders, coastal off-road front bumper, 4x innovations rear bumper(custom built swing out), 4.88 gears, Circuit Offroad 17x8.5 wheels, Kenda Klever RT 35x10.5r17
05-19-2021, 01:51 PM
#19
Real Name: Blair
Real Name: Blair
That's a big boy for sure & 48 plates. A lot of the 45XX series LPD coolers are hard to find in stock right now, but that one is available. I can't easily locate a 4589. Did you mount it on the pass side of condenser?
Edit - I like that the Tru-Cool stuff appears to be made in Canada by Dana/Spicer.
05-19-2021, 03:00 PM
#20
[QUOTE=Endlessblockades;3638851]That's a big boy for sure & 48 plates. A lot of the 45XX series LPD coolers are hard to find in stock right now, but that one is available. I can't easily locate a 4589. Did you mount it on the pass side of condenser?
Image isn’t uploading I guess. Basically installed it front and center and had to modify the hood latch mount.
This was the best place I could fit it. Had to cut off the bottom mount for it to bolt up but its been fine getting beat up off road for 15,000 miles so i'm happy.
05-19-2021, 03:07 PM
#21
Real Name: Blair
Real Name: Blair
Nice - I appreciate the visual - tight fit indeed.
05-20-2021, 09:24 AM
#22
I offset mine to the passenger side to to get it lined up more with the fan blades instead of in the dead center. Doing that I had to space the horn out to clear the cooler. I used the hose that came with the cooler.
05-20-2021, 12:15 PM
#23
Real Name: Blair
Real Name: Blair
Yeah that's what I was going to do. I don't particularly want to remove the center bracket. Did you have to also? I have some aftermarket Hella horns and i don't mind relocating one permanently.
05-20-2021, 12:44 PM
#24
The hood latch support is necessary, that definitely needs to stay! If you are creative, you can make extra space if you need it. I was able to mount my cooler (TruCool LPD4921) behind the hood latch support with some creative mods to the condenser mounts:
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
05-20-2021, 12:46 PM
#25
Real Name: Blair
Real Name: Blair
Nice!
05-20-2021, 03:21 PM
#26
B&M SuperCooler 70264 out of stock. What about the 70268?
I mounted mine to the condenser so I just pulled it to get it out of the way until I had it zipped to the condenser.
Edit. I thought I’d go to my 97 Limited Puppy Hauler thread and snag a picture of it installed but the pictures are gone.
05-20-2021, 04:20 PM
#27
Real Name: Blair
Real Name: Blair
DUH! Sorry - I made a stupid assumption (that you had deleted the support permanently). I can be pretty daft. - getting up there in dog years.
