Old 05-18-2021, 09:19 PM #1
sirhcx's Avatar
sirhcx sirhcx is offline
sirhcx is on a distinguished road
sirhcx's Avatar
Tundra Brake Upgrade time?
So Ive had a bit of a sticky piston issue going on with my brakes for the last couple of years thats been just been a small annoyance at most. Well now the Spring is finally well under way, one of my pistons decided to stay stuck until I was able to pull over and mash on the brake. Needless to say, the smoke and the large amount of brake dust is more motivation than I need to finally replace the factory calipers after 235k miles of loyal service.
All that being said, Ive read plenty of the articles on what to do but cant find a solid answer if these rims will work after the upgrade or is it safer to just go with direct replacement?
TRD Off-Road Wheel - 2nd Gen
Part# 42611-AD031 (42611-AD030)
Dimensions: 16x7 +30
Im currently running these
4Runner 3-Spoke Wheel
Part# 42611-35140 (42611-35130)
Dimensions: 16x7 +16
2001 Toyota 4Runner SR5 4X4
3.4L V6, 250,000+ Miles
Slowly getting upgrades while fighting the rust...
sirhcx is offline   Reply With QuoteReply With Quote
Old 05-18-2021, 11:35 PM #2
thenightman's Avatar
thenightman thenightman is offline
Real Name: keith and jenny
thenightman will become famous soon enough
Hard to find Specs, Info & Measurements on 231mm 13WL Tundra Calipers & Rotors
Post #3 in this thread has a list of wheels that fit. I was lucky in that mine came with 5 stars, which clear fine.
Build thread
http://www.toyota-4runner.org/3rd-ge...ncemobile.html
Few dollars, and fewer sense
thenightman is offline   Reply With QuoteReply With Quote
Old 05-19-2021, 12:20 AM #3
sirhcx's Avatar
sirhcx's Avatar
Thanks so much, I should have looked a bit more into the 231's. I thought due to the more positive offset, I would need to use the 199's.
Old 05-19-2021, 12:53 PM #4
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
the wheels in lower picture wont work and the link that thenightman posted is very valuable.
One thing to keep in mind. The stock spare wheel will not fit the TBU. IF you get a flat in front you have to put spare on back and move back to front. Or carry a spacer to use the stock spare., or some just have spacers on front anyway. Maybe thats not an issue with the 199 caliper....was with the bigger.
My spare is a wheel that will fit, stock 5 star, and I set it up that way not only for the TBU but now I do 5 wheel rotations
Old 05-19-2021, 01:24 PM #5
sirhcx's Avatar
sirhcx's Avatar
Thanks for the heads up! Guess I'll get my fronts swapped and run mismatched for a week. Oh and already got a 5th 5-spoke for the spare swap as well.
Old 05-19-2021, 04:41 PM #6
JohnMc JohnMc is offline
JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all
I have those 'snowflake' wheels (AD030/31, your first pic) on mine, and while I am running 1" adapters on it now, I did run them without spacers or adapters with the 231mm Tundra brakes earlier on. Everything fits just fine.
And concur with the above, the stock 'double tri-spoke' style wheels will not fit with the larger brakes without a pretty good sized spacer.
JohnMc is offline   Reply With QuoteReply With Quote
Old 05-19-2021, 05:20 PM #7
cl4Rk's Avatar
cl4Rk cl4Rk is offline
cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold
cl4Rk's Avatar
Do you think a 1.25” spacer would provide enough clearance for the split-spoked wheels?
2000 SR-5 V6 4x4 Auto
"Ol' Ruby" - build thread
@Y2K_4X4
cl4Rk is offline   Reply With QuoteReply With Quote
Old 05-20-2021, 08:24 AM #8
Refreshed my memory, all it took for them to fit was a 1/4" spacer (which was a bit iffy in terms of thread engagement with regular lug nuts). So 1.25" spacers - no problem at all.
Old 05-20-2021, 03:00 PM #9
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
If you are replacing the calipers anyway then 100% agree do the TBU. I also have the Tacoma TRD wheels on my 4Runner and they clear the larger 231mm calipers with no issue. To be honest there's not a whole lot of benefit going to the 199mm calipers since you won't gain extra stopping power.
326WHP 347TQ
Old 05-20-2021, 03:13 PM #10
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Are you comparing 199mm to stock or 231mm?
Old 05-20-2021, 06:15 PM #11
FD7683 FD7683 is offline
FD7683 will become famous soon enough FD7683 will become famous soon enough
My brakes sadly has the vibration while heavy braking so I might consider this in the future instead of replacing just the disc and pads. How much would this project cost on average guessing?
2000 4Runner Limited 4x4 V6
Old 05-20-2021, 09:39 PM #12
ChromeT4R ChromeT4R is offline
ChromeT4R is on a distinguished road
A few weeks ago I installed the 231mm caliper on my 2000 T4R with no clearance issues. No spacers needed with my new wheels. Replaced the original 15" wheels.
ChromeT4R is offline   Reply With QuoteReply With Quote
Old 05-20-2021, 09:42 PM #13
I noticed a huge difference in stopping. Go with the 231mm if you can. You won't regret it. Just do some more homework and ask questions so the 231 fits with no issue.
Old 05-21-2021, 12:07 PM #14
Real Name: Jerod
Real Name: Jerod
The 199mm to stock. The surface area of the pads isn't much more than the stock 4Runner pads. The difference though of the thicker rotor will help with the common warping issue. Going to 231mm increases the surface area of the pads dramatically allowing for shorter stopping distances and helps when towing.
326WHP 347TQ
Old 05-21-2021, 12:16 PM #15
Real Name: Patrick
Real Name: Patrick
I disagree. The 231 brake pad backing plate is bigger than 199 brake pad backing plate, but the brake pad material is very close to the same size between 231 and 199 (at least for OEM pads). You can see the two side by side in this post: https://www.toyota-4runner.org/3378920-post1.html The 199 and 231 brake calipers both have the same size pistons. I do think the larger rotors are the biggest advantage to either upgrade.
Side rant: A lot of people complain about a softer pedal, but that's just how hydraulic systems and fluid dynamics function. When you increase the brake caliper piston size you increase the amount of fluid required to move the piston out the same distance as the smaller OEM caliper piston which is why people complain of a softer/lower pedal. In order to keep the same pedal feel/distance you would need to increase the master cylinder piston bore proportionally to the brake caliper piston increase.
brake , time , tundra , upgrade , wheel
Spongy/Long travel Brake Pedal w/ Tundra brake upgrade 2002_thundercloud 3rd gen T4Rs 9 07-23-2023 10:07 PM
Tundra Brake Upgrade: Brake Pads Side Specific? trevo_man 3rd gen T4Rs 3 10-05-2016 11:45 PM
Did tundra brake upgrade and brake pedal mushy. 3rdgenfan 3rd gen T4Rs 5 10-25-2015 08:51 PM
is Tundra brake Upgrade = Sequoia brake Upgrade??? infamousRNR 3rd gen T4Rs 11 02-20-2014 05:22 AM
