Originally Posted by Bad Luck
The OBD port does not read ABS/TRAC/VSC/AIRBAG codes. Those have to be flashed using a special procedure which I don't know because I have a 2000 which doesn't have TRAC/VSC. If you search on the forum here you should be able to find the procedure.
I'm surprised. It (the OBD) showed the bad 02 sensor last year, but only specified front sensor. Came to find out both were bad, but it took a while and some fussing with it. When the sensors were bad, the mileage drop was noticeable - couldn't go past 2 gas stations in a row. This time around, it seems fairly normal.....just eyeballing it.
