Old 05-21-2021, 08:46 AM #1
clanofwolves's Avatar
clanofwolves clanofwolves is offline
clanofwolves is on a distinguished road
Stalls while sitting at traffic light, no codes.
So my daughter's '00 stalls while sitting at lights (three times over the past week).
It was throwing a code a few weeks ago, so I replaced the PVC, it's boot and hose) and cleaned the MAF and the code went away and she was running good.
Now she stalls at traffic lights, AC not on, no idiot light on, no other symptoms.
Ideas?
Thanks in advance for any ideas!
"Family and God - that is what's important. Money, cars, those are things that come and go."
clanofwolves is offline   Reply With QuoteReply With Quote
Old 05-21-2021, 09:58 AM #2
TX4Running's Avatar
TX4Running TX4Running is offline
TX4Running is on a distinguished road
TX4Running's Avatar
Fuel filter? Has it ever been changed?
James
2001 4Runner SR5 4WD - 231 mm TBU, B&M 70264 external transmission cooler, Magnefine external transmission filter
TX4Running is offline   Reply With QuoteReply With Quote
Old 05-21-2021, 10:12 AM #3
D.O.B.'s Avatar
D.O.B. D.O.B. is offline
D.O.B. is on a distinguished road
D.O.B.'s Avatar
Air intake hose may be needing replaced.
Mine will stall if it's come loose.
MM Ltd 4X4
D.O.B. is offline   Reply With QuoteReply With Quote
Old 05-21-2021, 10:36 AM #4
JLTD JLTD is offline
JLTD has a spectacular aura about JLTD has a spectacular aura about JLTD has a spectacular aura about
How many miles since plugs etc. were changed? Has it been raining in her area lately? I've had several older vehicles that would stall when it was wet if the plugs etc were old.
Between outfits.
JLTD is offline   Reply With QuoteReply With Quote
Old 05-21-2021, 02:03 PM #5
gamefreakgc's Avatar
Real Name: Jerod
gamefreakgc is a splendid one to behold gamefreakgc is a splendid one to behold gamefreakgc is a splendid one to behold gamefreakgc is a splendid one to behold gamefreakgc is a splendid one to behold gamefreakgc is a splendid one to behold gamefreakgc is a splendid one to behold
Real Name: Jerod
It's a classic clogged or dirty Idle Air Control valve. That's the valve on the underside of the throttle body that has a vacuum line and coolant lines going through it. Debris falls through the air holes in the throttle body and then clogs up the valve, not allowing enough airflow to pass through to maintain idle speed. Only will stumble or stall when the engine is fully warmed up, otherwise when cold it'll open more to keep from stalling.
There's some threads on here that will help if you search "IAC cleaning" but the gist of it is to remove the throttle body, remove the IAC (coolant will leak out but not very much as long as you keep the hoses upright), clean out the valve, replace the gasket and reassemble. I don't recommend replacing the IAC unless you absolutely have to because the part costs $250.
'98 4Runner SR5 - 4x4 JDM 5VZ-FE Supercharged - 233K miles.
326WHP 347TQ
Old 05-21-2021, 02:27 PM #6
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot is just really nice Devbot is just really nice Devbot is just really nice Devbot is just really nice
Devbot's Avatar
Real Name: Devan
Should be $100 or less. Just replaced mine last year, believe I got it from partsouq. I imagine it would be more if youre going directly through a dealer, they always love to tack on another 50% but thaf still sounda kinda high. 96-00 don't have an integrated IAC/TB like 01-02.
Y2K Highlander Millennium Silver 3.4L auto @ 295k and climbing
Tundra TRD Lift in Front / LC Lift in Rear / JBA UCAs / CVJ 9168R Axles / Diff Drop / PCK / Extended Bump Stops; Brake Lines; Sway Bar Links; Rear Diff Breather / True North Fab. Hybrid Bumper / Smittybilt XRC Gen 3 Comp. / Northstar 880CCA AGM / Drivelines NW Rear Shaft / Lil Skip Gas Skid / BudBuilt Front Skid
Old 05-21-2021, 06:24 PM #7
jgue467's Avatar
jgue467 jgue467 is offline
jgue467 has a spectacular aura about jgue467 has a spectacular aura about jgue467 has a spectacular aura about
jgue467's Avatar
As Gamefreak said, IAC just needs a little cleaning, its easy peasey and takes about 5 mins Do the butterfly while you're at it.
2001 Limited 4WD - 331+K - SunfireRed\Thunder Cloud; - 265/75/16 Michelin A/T2s - Fat Pat's 1.5" BL, ZERO RUST - StopTech ANGLED rotors - Magnefine trans filter - In series trans cooler, ORIGINAL: paint, engine, 4wd, trans, mstr cyl & brake system, rear axle seals, A/C, steering pump, steering rack, front/center/rear diffs, all electric motors, seat heaters and so on. WooHoo!!
Oh yeah, GO LONGHORNS!
Old 05-21-2021, 06:35 PM #8
HiLife HiLife is offline
HiLife is a jewel in the rough HiLife is a jewel in the rough HiLife is a jewel in the rough
The reason why members say take the iac out and clean it, because there actually a electric motor that open and closes the valves. You may risk damaging that motor if cleaner makes it's way to the motor.
Plus having the iac out is a better way to getting at the angles to properly cleaning out all the carbon and oil.
After cleaning give time for the ecu to learn proper how to idle again.
Old 05-21-2021, 06:40 PM #9
Real Name: Jerod
Real Name: Jerod
Maybe the price changes. The one I bought from partsouq last year was $212 plus shipping. I had reason to believe mine had bit the dust (it hadn't, was the TPS).
326WHP 347TQ
Old 05-21-2021, 06:59 PM #10
FordF150 FordF150 is offline
Banned
Real Name: Tommy Bahamas
FordF150 is an unknown quantity at this point
Banned
What year is this 4runner? OK. I see. it's a 2000.
I have a 2005 4runner and it has never stalled.
I would guess fuel-related. Possible fuel pump. Fuel filter?
I'd ask around Toyota dealer or mechanic.
Advice above looks good?
FordF150 is offline   Reply With QuoteReply With Quote
Old 05-22-2021, 11:34 AM #11
This4RunnerIsMine This4RunnerIsMine is offline
This4RunnerIsMine is on a distinguished road
Get a cheap OBD reader and watch the PID's for fuel trim.
if the fuel trims are way high, it could indicate vaccum/air leak on the intake.
If its running super lean, you could have leaking injectors.
No code stalls/failure to start are usually something wrong with the A/F ratio. Could be IAC too as others have suggested.
So, clean out the carb/IAC, maybe look at some spark plugs.
This4RunnerIsMine is offline   Reply With QuoteReply With Quote
Old 05-22-2021, 12:13 PM #12
Bad Luck Bad Luck is offline
Real Name: Patrick
Bad Luck is a splendid one to behold Bad Luck is a splendid one to behold Bad Luck is a splendid one to behold Bad Luck is a splendid one to behold Bad Luck is a splendid one to behold Bad Luck is a splendid one to behold
Real Name: Patrick
Your 4th Gen advise is not wanted here. Go back under your bridge you troll.
2000 Limited V6 Auto E-Locker
Old 05-22-2021, 01:01 PM #13
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
I swear some people post just for the sake of posting
Old 05-22-2021, 09:49 PM #14
IAC valve. Check that, thanks to more experienced folks.
Between outfits.
code , ideas , lights , sitting , stalls
A Traffic Light, a 4Runner and a Couple of Drunks RichinRidgewood General Discussions 0 03-11-2020 05:09 PM
Engine loud metallic engine rattle @1800 rpm after sitting in traffic protist 3rd gen T4Rs 5 08-17-2019 08:04 PM
Does you T4R creep forward with AC on @ traffic light? best $36 ever spent! gshadow325 4th Gen T4Rs 50 06-04-2017 06:19 PM
Toyota 4 Runner stalls at Stop sign/light hadia Classic T4Rs 48 02-28-2016 10:44 PM
Engine squeak when sitting at light Phx994Runner 3rd gen T4Rs 2 10-03-2011 05:52 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
