Old 05-31-2021, 06:50 PM #1
texadelphia texadelphia is offline
texadelphia will become famous soon enough
Brake booster ticking
Is the brake booster making a ticking noise normal on these rigs? I haven't noticed any problems with brake performance but there is a fairly audible ticking noise coming from the booster. Has done it for as long as I've had it but I'm about to drive it from Oregon to Texas and I don't need any mid-trip surprises.
1997 SR5, 3.4L, Manual
texadelphia is offline   Reply With QuoteReply With Quote
Old 05-31-2021, 08:52 PM #2
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
What year of rig 2001 or 2002 or older ?
Old 06-01-2021, 12:39 AM #3
1997
Sent from my moto x4 using Tapatalk
Old 06-01-2021, 08:10 AM #4
ej86923 ej86923 is offline
ej86923 is on a distinguished road
Sure it is not the evap solenoid that sits in front of the booster on top of the inner fender well? If so, I'm pretty sure it is normal for those to tick. My 99 does.
ej86923 is offline   Reply With QuoteReply With Quote
Old 06-01-2021, 08:53 AM #5
spartacus's Avatar
spartacus's Avatar
It's called the 4runner tick.
Old 06-01-2021, 09:43 AM #6
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Probably the EVAP stuff ticking away on the fender well in front of the booster. Mine does this. Or you could be hearing the fuel injectors (also known as Toyota Tick/4Runner Tick). We've got some really loud injectors compared to most other vehicles of that age.
Old 06-01-2021, 05:21 PM #7
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Makes more sense to have the evap ticking.. Mostly only the 2001 and 2002 with the integrated abs and master cylinder makes the noises. :-) As its right in the same area I am agreeing with Badluck on this one. :-)
Old 06-01-2021, 05:22 PM #8
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
The injectors can tick.. The Evap can tick. The engine can slightly knock...
Toyotas was never known to be quiet.. However, they mostly run for quite a long time before complete failure..
Old 06-01-2021, 11:31 PM #9
Just did the old fuel line stethoscope check and it's the EVAP can. It sure did sound like it was coming from the booster to my naked ear. False alarm. Haha.
booster , brake , long , noise , ticking
Hard Brake Pedal During Panic Stops - Brake Booster? Friday88 3rd gen T4Rs 24 Yesterday 12:14 AM
Which Brake Booster? tbryanh 3rd gen T4Rs 8 03-07-2021 11:40 PM
anyone ever mess up a brake booster by changing brake pads? jluu6r 3rd gen T4Rs 19 12-12-2019 05:01 PM
Brake booster: Is non-ABS ok? HARP Classic T4Rs 3 10-14-2017 12:41 PM
Brake Booster? MtnLlama 3rd gen T4Rs 10 10-16-2014 09:59 PM
