Old 05-31-2021, 08:32 PM #1
JZiggy's Avatar
JZiggy JZiggy is offline
JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future
JZiggy's Avatar
Sway bar bushing relocation brackets??
Hey fellas,
Been doing some thinking on correcting sway bar geometry after a suspension lift. The common approach is to run extended links but the more I think about it it seems that spacing the bushings some distance would give the same effect (leveling the swaybar). I wanted to see what options folks have found for this.
I see Sonoran Steel offers a rear relocation bracket that pushes the bushing locations up about 1" and lets you run the stock links. I have not seen one for the fronts but it I expect a simple 1/4"-1/2" thick spacer would do the trick.
Please school me! Thanks
JZiggy is offline   Reply With QuoteReply With Quote
Old 06-01-2021, 04:18 AM #2
T4topher's Avatar
T4topher T4topher is offline
T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light
T4topher's Avatar
Originally Posted by JZiggy View Post
Hey fellas,
I don’t use sway bars but looking at it I don’t see why it wouldn’t work. Seems like a much simpler solution honestly.. Did you see Sonoran steel’s option for the Tacoma front sway bar LCA mounts? Might not be what your after but thought I’d mention it.
T4Tophers build (click here)
T4topher is offline   Reply With QuoteReply With Quote
Old 06-01-2021, 09:04 AM #3
JZiggy's Avatar
JZiggy's Avatar
I’ve actually got that mod already
Old 06-01-2021, 09:25 AM #4
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Hey fellas,
I believe Sonoran Steel came up with the rear sway bar relocation bracket because the stock bar location with longer sway bar links had a tendency to contact the elocker actuator when flexing. The relocation brackets correct that problem.
Old 06-01-2021, 10:19 AM #5
Malcolm99's Avatar
Malcolm99 Malcolm99 is offline
Malcolm99 has a spectacular aura about Malcolm99 has a spectacular aura about
Malcolm99's Avatar
Steves (sonoran steel) relocation bracket is meant to be used with the stock links, it pushes the sway bar forward and up, so you actually need shorter sway bar links for the back with this kit, the original rear links work but will be leaning a bit. You only really need to do this if you have a e-locker, I have these on both my 4Runners, last set required some grinding to the supplied parts, poor fitment, easy fix. And I think Roger Brown makes a Aluminum spacer to lower the front sway bar mounts and you add new hardware and press out the studs on sway bar mount bracket. This is the best way, I found the longer 2nd gen links to be to thin of a rod and stud.
Malcolm99 is offline   Reply With QuoteReply With Quote
Old 06-01-2021, 03:10 PM #6
Romeo1's Avatar
Romeo1 Romeo1 is offline
Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice
Romeo1's Avatar
Had a broken rusted out front link and went with Overland Custom designs sway bar ball joint links. I’m pretty sure I know where I broke it trying to be like BJ Baldwin …..lol….
Really beefy part and adjustable. I would buy again for sure. There might be other options. For the little bit that I researched I liked this option the best.
99’ Black “Highlander” sport, oak, 5VZ auto, 4.30 axle, e-lock, 265/75 Grabber X3,, Bilstein 6112 (2”) front 5160 rear shocks, OME 2906 springs, Durobumps, 4x Inovations front middle rear skid plates, 4XI square TRD tube sliders, lil skips tank skid, lotus dev RCA skids, overland custom sway bar links, Amp’d hidden winch, warn Vr Evo 10s
Romeo1 is offline   Reply With QuoteReply With Quote
Old 06-01-2021, 09:20 PM #7
JZiggy's Avatar
JZiggy's Avatar
Thanks for all the input, guys. I sent to email to Steve at Sonoran and he said that with the Taco front bar there is no need to relocate anything. I did some measuring and studying and I agree -- the bar is actually a bit flatter than before the lift!
I went ahead and ordered the Sonoran rear sway bar bushing relocation brackets. I like this idea better than longer links.
Old 06-01-2021, 10:04 PM #8
fourfive's Avatar
fourfive fourfive is offline
fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough
fourfive's Avatar
I have his rear sway bar relocation brackets that was included in his rear lift I got years ago that I've been considering putting on but mainly to have ball joint end links instead of the heims that I currently have on my extended links. I was considering getting the ball joint replacements for my extended links but since I already have sonoran steel's relocation brackets & still have my oem sway bar links I might do that instead.
1. Black 2002 SR5 4x4 5vz: Front Toytec Ultimate coilovers/eibach 600#, SPC UCA, durobumps Rear Bil5100/Superflex, SS adjustable panhard, PCK, durobumps Body Lift 2" 4crawler Tires 315/75/16 BFG KO2 Wheels SCS F5 Matte black 16x8 3.5bs Armor Custom bolt on rock sliders (no frame drilling)
2. Black 2001 SR5 4x4 5vz: stock
3. Black 2018 TRD Pro (wife’s): Armor Custom bolt on rock sliders (U-bolts)
fourfive is offline   Reply With QuoteReply With Quote
bar , bushing , links , run , sway
FS: 4th gen sway bar relocation brackets blackoutt For Sale: Suspension/Wheels/Tires 3 09-02-2016 12:25 AM
icon sway bar relocation brackets - help soundstudio315 4th Gen T4Rs 3 07-24-2012 01:35 AM
