Old 05-22-2021, 10:52 AM #1
Mike's4Runner Mike's4Runner is offline
Mike's4Runner is on a distinguished road
My 4Runner journal: MY00 Limited 2WD
Hello Everyone!
I'll make this my official journal thread.
Not that anybody cares since I know by now everything I will be doing to my car has probably been posted over a thousand times, but anyways..
My name is Mike and my car is a 2000 4Runner Limited 2WD.
This is my first 4Runner and in fact the first Toyota I ever own. I'm still learning a lot, reading threads, watching videos, and absorbing as much info as I can since these cars are totally new to me. Already following a few members here, this seems like a great community with lots of knowledgeable folks.
The car had 126,400 miles when I bought it 2 weeks ago..
I was very lucky it is in such great shape in and out, and most importantly, no rust in the frame. It's always been in Florida.
Services to do:
First Things first..
Replaced LBJs and bolts with OEM Toyota parts. Service done on 5/15/21
Pending: Replace the OEM Radiator (has a small bottom leak/cracked on top)
Pending: Replace Valve Cover Gaskets(Left is leaking), along with spark plugs, PCV valve/grommet and rest of valve cover washer seals, grommets, etc.
Pending: Replace Timing Belt, along with #1 & #2 pulleys, Tensioner, all 3 service belts and Crank Pulley bolt. (Belt looks in good shape but I don't know if it has been replaced so it will get done)
Pending: Fix/replace the CCU (it's acting all crazy, one button does everything lol)
That's about it for now..
2000 4Runner Ltd 2WD
Mike's4Runner is offline   Reply With QuoteReply With Quote
Old 05-22-2021, 11:55 AM #2
The work begins..
Replaced both LBJs on 5/15/21
Even though supposedly my VIN # was not affected by the LBJs catastrophic failure, I didn't want to take the chance so that's the first thing I did..
The job went pretty well, except I had a hard time pulling out the Right Tie Rod from the LBJ's frame. Left side went a lot better/faster since I knew already what to do.
Had to modify the internal space on of the Pitman Arm pullers with a grinder because it would not fit around the Outer Tie Rod end..
My 4Runner journal: MY00 Limited 2WD-lbjs-replaced-jpg  My 4Runner journal: MY00 Limited 2WD-oem-lbjs-bolts-jpg  My 4Runner journal: MY00 Limited 2WD-lbj-service-4-jpg  My 4Runner journal: MY00 Limited 2WD-lbj-service-3-jpg
Old 05-22-2021, 12:10 PM #3
Checking the Timing Belt..
My previous car was a 2001 Forester which I did everything on. Subaru's Left Cam Sprocket is almost identical to the Toyota 4Runner Cam Pulleys!
I was very excited about this because it means I don't have to purchase more tools for the Timing Belt service.. well, at the least the Cam Pulleys anyways..
Company 23 makes some awesome tools. I haven't tested if the Subaru Crank Pulley tool works on this car. For the Forester, the tool used the 4 bigger diameter bolts. But I'm hoping the distance between the two smaller bolts on the tool is the one for the 5VZ-FE Crank Pulley. If I'm not mistaken, I think the distance should be about 2 -15/16", almost 3". We'll se..
My 4Runner journal: MY00 Limited 2WD-company-23-subaru-tools-jpg  My 4Runner journal: MY00 Limited 2WD-subaru-cam-sprocket-tool-works-5vz-fe-jpg  My 4Runner journal: MY00 Limited 2WD-subaru-cam-pulley-tool-works-5vz-fe-jpg  My 4Runner journal: MY00 Limited 2WD-subaru-crank-pulley-specialty-tool-jpg
4runner , belt , car , cover , replace
Octanejunkie's 4runner Journal octanejunkie 3rd gen T4Rs 201 10-25-2020 09:26 AM
My 2007 Limited V8 Ownership Journal Timberland 4th Gen T4Rs 73 06-17-2018 11:18 AM
2014 4R Limited winter journal - pix dekeman 5th gen T4Rs 27 02-04-2014 06:18 PM
Men's Journal review of 2010 4Runner shm38 5th gen T4Rs 7 04-15-2010 12:46 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
