Old 05-24-2021, 03:10 PM #16
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
A shame to hear they raised their prices, they're 210v were already expensive enough buying them. About double the price as the rest.
Old 05-24-2021, 03:19 PM #17
fourfive's Avatar
fourfive fourfive is offline
fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough
fourfive's Avatar
Originally Posted by JZiggy View Post
we were able to bend the tabs back with care... and a torch, punched, and a lot of hammering. I'm glad we could correct it this way without having to cut anything off and reweld.
C-clamps & channel locks also saw some action.
For anyone else that finds themselves in this situation, heating up the cam tab to reshape it back to its original position seemed pretty crucial because we could barely get it to budge before. @JZiggy lighting it up while I held his beer.
C-clamp came in handy to maintain stability while the tab was getting hammered and bent back into shape.
Cam tab fixed & happy.
1. Black 2002 SR5 4x4 5vz: Front Toytec Ultimate coilovers/eibach 600#, SPC UCA, durobumps Rear Bil5100/Superflex, SS adjustable panhard, PCK, durobumps Body Lift 2" 4crawler Tires 315/75/16 BFG KO2 Wheels SCS F5 Matte black 16x8 3.5bs Armor Custom bolt on rock sliders (no frame drilling)
2. Black 2001 SR5 4x4 5vz: stock
3. Black 2018 TRD Pro (wife’s): Armor Custom bolt on rock sliders (U-bolts)
fourfive is offline   Reply With QuoteReply With Quote
Old 05-24-2021, 08:02 PM #18
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
I was just thinking about this today, and you might have an answer since you were clearly just working on them...
We all know that when removing the LCA bolts they contact the steering rack unless it's swung out of the way or disconnected entirely. But is there any reason one couldn't simply reinstall them from the inside out instead to prevent this in the future?
Old 05-24-2021, 10:01 PM #19
fourfive's Avatar
fourfive's Avatar
Doesn't look like it because you would still have to clear the nut side of the cam sleeve and that end would stick out further contacting the itre boot. Would also run the risk of tearing up the itre boot making alignment adjustments.
Old 05-25-2021, 12:31 PM #20
RoRod RoRod is offline
RoRod is on a distinguished road
So the fronts sitting at about 23 1/4" fender to hub. So they dropper it about an inch in front. Shes getting wheels and tires as we speak. done within the hour. I tried posting pics but the files too big. Ill try and re-size later.
RoRod is offline   Reply With QuoteReply With Quote
Old 05-25-2021, 02:29 PM #21
JZiggy's Avatar
JZiggy JZiggy is offline
JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future
JZiggy's Avatar
Hopefully they are only dropping the coil adjustment by 1/4"-1/2" since you get a 2x multiplier on the ride height.
JZiggy is offline   Reply With QuoteReply With Quote
Old 05-25-2021, 07:31 PM #22
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Ah that could be it. I figured there had to be some reason, otherwise you'd hear people talk about it MUCH more
Old 05-26-2021, 02:33 AM #23
HiluxSurf SSR-G's Avatar
HiluxSurf SSR-G HiluxSurf SSR-G is offline
HiluxSurf SSR-G will become famous soon enough HiluxSurf SSR-G will become famous soon enough
Do you have free lengths and wire diameter of those two coils springs?
What's the valving of the shocks, progressive or digressive?
Thanks!
Stuff I bought for the lift:
Front springs: C59-276 (2" lift, light/med load)
Rear springs: C59-131 (2" lift linear, light/medium)
IMS adjustable height front shock: IMS59-50222
IMS rear shocks: IMS59-50225
JBA upper control arms
HiluxSurf SSR-G is offline   Reply With QuoteReply With Quote
Old 05-26-2021, 07:40 AM #24
JZiggy's Avatar
JZiggy's Avatar
Thanks!
I don't, sorry. I can measure the wire diameter for you at some point.
@Crikeymike maybe Mike can comment on the shock valving question? I would be interested to know as well.
Old 05-26-2021, 10:05 AM #25
Crikeymike's Avatar
Crikeymike Crikeymike is offline
Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of
Crikeymike's Avatar
Shock valving in all Dobinsons shocks in linear/progressive.
Exit Offroad - Specialist in Dobinsons Suspension & Accessories
Dobinsons | RCI | Powerbrake | Long Range Tanks | Timbren | Overland Vehicle Systems
Youtube Channel | Email Directly
Been in the offroad industry since 1998. Born & raised in Australia - currently in Jax Beach, FL. 2014 4runner Trail, 3/2" Dobinsons MRA Suspension, Shrockworks bumper and sliders, M8000 w/ Treaty Oak winch line, LFD Roof Rails, Dobinsons 2m Awning, RCI skids
Crikeymike is offline   Reply With QuoteReply With Quote
Old 05-27-2021, 05:35 PM #26
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
I've been looking for a Dobinson rear shock comparable to an FJ80 rear shock (14.5" compressed to 23.5" extended) or possibly a shorter compressed length around 13.5" with a good amount of travel, but I'm having a hard time finding measurements on most Dobinson rear shocks. Do you have any suggestions or recommendations? I'm trying to find a good shock to match with FJ80 7.5 wrap coils or Dobinson 210V.
Old 05-27-2021, 05:51 PM #27
fourfive's Avatar
fourfive's Avatar
Interested in exactly this also.
Old 05-28-2021, 07:52 AM #28
IMS59-50705: rear shocks for the N215 and N285 4Runner
Extended length -- 23.23"
Compressed length -- 13.98"
hth
Old 05-28-2021, 09:31 AM #29
Real Name: Patrick
Real Name: Patrick
hth
Thanks for that! What's the difference between IMS59-50705 and IMS59-50701? They both show to be for the same vehicle applications for the same amount of lift.
Old 05-28-2021, 10:25 AM #30
IMS59-50705 has comfort valving. but both are for 0-2.5" lift.
But accdg to this, it's 0-3" lift:
Dobinsons IMS Struts and Shocks - Adjustable Height Monotubes - 5th Gen 4Runners
front , gen , ims , lift , work
Dobinsons 2.5" lift kit Daven75 5th gen T4Rs 13 05-31-2022 11:10 PM
Dobinsons 2.0" Lift kit Bodhi 3rd gen T4Rs 88 05-01-2021 07:10 PM
FS: Dobinsons 1" F/R Spring Lift for TRD Pro - $375 Baltimore, MD kaikaikai For Sale: Suspension/Wheels/Tires 1 07-15-2020 02:19 PM
FS: Dobinsons C59-599 Rear Coil .75" Lift OC/CA onepremiere For Sale: Suspension/Wheels/Tires 2 09-25-2017 08:48 PM
