Old 07-23-2023, 09:17 AM #61
Crikeymike's Avatar
Crikeymike Crikeymike is offline
Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of
Crikeymike's Avatar
Originally Posted by HiluxSurf SSR-G View Post
about the front IMS shocks for the 3rd gen, is there enough adjustment thread if in case you want to lower the ride height if in case one has a "longer-than-stock" length of coil springs?
Yes. The body is fully threaded but you shouldn't go lower than OEM coil seat height as your sway bar could make contact with the coilovers then.
Exit Offroad - Specialist in Dobinsons Suspension & Accessories
Dobinsons | RCI | Powerbrake | Long Range Tanks | Timbren | Overland Vehicle Systems
Youtube Channel | Email Directly
Been in the offroad industry since 1998. Born & raised in Australia - currently in Jax Beach, FL. 2014 4runner Trail, 3/2" Dobinsons MRA Suspension, Shrockworks bumper and sliders, M8000 w/ Treaty Oak winch line, LFD Roof Rails, Dobinsons 2m Awning, RCI skids
Crikeymike is offline   Reply With QuoteReply With Quote
Old 07-23-2023, 09:35 AM #62
HiluxSurf SSR-G's Avatar
HiluxSurf SSR-G HiluxSurf SSR-G is offline
HiluxSurf SSR-G will become famous soon enough HiluxSurf SSR-G will become famous soon enough
Hi Mike,
Thank you for replying to my post. The issue that I have is the front coils + 1/4" top spacers are given more than 3.25" of lift and I would like to use the threads to lower the lift height to 2.75" by lowering the spring perch without removing the top plate.
The sway bar and end link are far from the shock body in the 3rd gen.
HiluxSurf SSR-G is offline   Reply With QuoteReply With Quote
Old 07-24-2023, 03:40 PM #63
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Originally Posted by 3ToyGuy View Post
I Hate to be picky, but it's damping, not dampening. To dampen is to get slightly wet. To damp is to reduce.
I'm sorry, it's just a pet peeve of mine...
Pat☺
The alternative definition of "dampen" is to "make less strong or intense". The more you know...
front , gen , ims , lift , work
Dobinsons 2.0" Lift kit Bodhi 3rd gen T4Rs 89 08-11-2023 11:26 AM
Dobinsons 2.5" lift kit Daven75 5th gen T4Rs 13 05-31-2022 11:10 PM
FS: Dobinsons 1" F/R Spring Lift for TRD Pro - $375 Baltimore, MD kaikaikai For Sale: Suspension/Wheels/Tires 1 07-15-2020 02:19 PM
FS: Dobinsons C59-599 Rear Coil .75" Lift OC/CA onepremiere For Sale: Suspension/Wheels/Tires 2 09-25-2017 08:48 PM
