Old 05-24-2021, 05:16 PM #1
thezentree's Avatar
thezentree thezentree is offline
Real Name: Robert');DROP TABLE Students;
thezentree is a jewel in the rough thezentree is a jewel in the rough thezentree is a jewel in the rough thezentree is a jewel in the rough
thezentree's Avatar
Stuck in 4wd - troubleshooting? Fixed!
2001 SR5 with multi mode t-case.
I’m at the end of a 5 day 4x4 trip with some friends and have been stuck in AWD since midday yesterday, and now I finally have cell signal.
Front driveshaft is locked in and I’m definitely getting power to the front end, but the 4wd dash light is either flashing or just off entirely, even though it’s in 4wd and the 4wd button is engaged. No problem shifting in and out of 4LO.
I can’t lock the center diff, or get it out of 4wd. Putting the shifter in the 2HI pos gets me a flashing dash light and will eventually cause a godawful squeal (sounds like worn out brakes). Stopping and turning the front driveshaft will cause it to lock back in to 4wd.
I’ll be home tomorrow and am going to clean it off and start troubleshooting, but am not sure where to start. I remember reading a good thread about checking the position switches on the tcase and front diff but I can’t find the thread.
Any ideas?
2001 SR5 - Like OEM, only worse (gears, e-locker, armor)
thezentree is offline   Reply With QuoteReply With Quote
Old 05-24-2021, 05:42 PM #2
Cree's Avatar
Cree Cree is offline
Cree will become famous soon enough Cree will become famous soon enough
Cree's Avatar
Sounds like you lost a position switch on the T-Case. Not sure which one it might be, don't have a diagram in front of me. But there's 2 on the case.
00 Limited - Stuff!
18 Audi A6 3.0T - APR Tuned, RS6 Interior
19 Audi A6 3.0T
Cree is offline   Reply With QuoteReply With Quote
Old 05-25-2021, 06:54 AM #3
thezentree's Avatar
thezentree's Avatar
I’ll pull those when I get home and check them. Just a matter of continuity when depressed and not looking for specific resistance, right?
Old 05-25-2021, 12:17 PM #4
Wraytex Wraytex is offline
Wraytex is on a distinguished road
That's correct. I used some brake cleaner and vigorous actuations (tapping the ball on the workbench) to clean the contact points until the replacement arrived.
Wraytex is offline   Reply With QuoteReply With Quote
Old 05-25-2021, 04:04 PM #5
thezentree's Avatar
thezentree's Avatar
Welp, both switches on the tcase and the one on the tcase actuator test good.
Is there a switch on the front diff I didn’t see?
If not, any advice for checking the tcase and ADD actuators? Is there a separate actuator for the center diff lock?
I saw the little vent tube between the tcase actuator and tcase was disconnected at the actuator, and I got into some pretty deep water the other day, so that doesn’t bode well for my tcase actuator...
Old 05-25-2021, 05:53 PM #6
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Disclaimer: I have a 2000 which is a vacuum operated front diff actuator. 2001-2002 use an electric front diff actuator.
On mine there is a switch on the front diff.
The transfer case actuator controls the 2hi/4hi/4hi locked shifting and the transfer case shift lever manually changes the high and low transfer case gear selection. My assumption is that your transfer case actuator got water in it and fried. If you can find a pinout for the transfer case actuator you can apply power and ground to the actuator. If the actuator is good then it will shift. I did this on a lift so there wouldn't be any drivetrain binding. You may want to put all 4 corners on jack stands to avoid any drivetrain binding that may be present.
Old 05-26-2021, 06:37 PM #7
thezentree's Avatar
thezentree's Avatar
Well, I dumped 2 or 3 ounces of water out of the actuator motor cover, so that'd be the problem.
But, I took the motor apart and cleaned the commutator/brushes and all the rotary contacts in the case. They're pretty pitted from either arcing or corrosion, but some 800 grit sandpaper, MAF sensor cleaner, and white lithium grease later and it works again. Not sure for how long, but it works great. In and out of 4wd and center diff lock without problems at all.
Also, for anyone who might need to replace the actuator, this might actually be possible without having to split the case.
This morning I found this video, which deals with an older style multimode tcase where you can pull the pinion gear on the shift rod out through that little triangular inspection cover. The 01-02 style case doesn't have that cover, so you can't get the actuator off that way. But, when I had the motor assembly off to clean it, I gently tugged on the spur gear with the electrical contacts that's attached to the pinion/shift rod and got a face full of gear oil, so I think you can probably get that little pinion gear out that way and then pull the actuator off the shift rod without splitting the case. Timing it when you put it back together looks like it'd be a *****, but if it'll come off like that, timing is doable and WAY cheaper than splitting the case.
4wd , flashing , front , light , start
Troubleshooting vsc off mod benztech82 4th Gen T4Rs 1 01-02-2021 09:36 PM
4wd troubleshooting fochtup1 3rd gen T4Rs 12 05-05-2018 09:50 AM
Cone washers stuck stuck stuck 4eigner 3rd gen T4Rs 14 04-03-2015 03:49 AM
rear hatch stuck is stuck tried everything.. tristentrd28 3rd gen T4Rs 4 11-09-2014 12:45 PM
Troubleshooting help arduckhntr 3rd gen T4Rs 5 10-28-2014 08:44 AM
