Old 05-26-2021, 09:03 AM #16
I put my gasket on incorrectly for the throttle body and that was the cause for me.
If your sensor is reading correctly you have air bypassing the sensor.
I found my issue with the gasket spraying brake cleaner.
Old 05-26-2021, 09:08 AM #17
Bad Luck Bad Luck is online now
Real Name: Patrick
Real Name: Patrick
Originally Posted by rocky.mtn View Post
Thanks.
OBD Fusion isn't showing me a sign notation, so I think it would be positive?
If it is a positive fuel trim then the engine is trying to compensate for unmetered air. Did you remove any vacuum lines when you did the repair? If you did verify they are in the correct location and seated properly. An easy way to check for vacuum leaks is to take carb cleaner or starter fluid and spray different areas of the engine/intake/vacuum hoses and listen for an idle change. It works best once the engine warms up and the idle drops. Unfortunately if it is a vacuum leak that will affect the flow of air through the MAF sensor so a low MAF reading won't necessarily tell you the MAF is bad or not. You can also see if someone has a known good working MAF that you can borrow. I believe 96-98 use a different MAF sensor than 99-02.
Bad Luck is online now   Reply With QuoteReply With Quote
Old 05-26-2021, 09:20 AM #18
Check Engine Light + Codes After MAF/Throttle Body Clean
.518 lbs/min is what both 97s run with a warmed up idle in park or neutral. It was .390 with the gasket installed incorrectly.
back , check , engine , idle , light
check engine light came on - how do i read the codes? steronz4 Classic T4Rs 6 12-07-2017 02:02 AM
spark plug change/throttle body clean=engine quieter pb&j 3rd gen T4Rs 4 09-30-2013 01:08 PM
Help with Check engine light codes. Deputy1211 Maintenance/Detailing 3 04-30-2010 08:31 PM
Codes stored without check engine light? Spencer 3rd gen T4Rs 1 04-16-2010 12:41 AM
Check Engine Light Codes 25 & 26 (O2 Sensor right?) Slinks Classic T4Rs 3 02-01-2008 07:26 AM
