Old 05-25-2021, 06:15 PM #1
T4topher's Avatar
T4topher T4topher is offline
T4topher is a jewel in the rough T4topher is a jewel in the rough T4topher is a jewel in the rough T4topher is a jewel in the rough
T4topher's Avatar
All long travel options
Here is a current list of all the 3rd gen 4runner front long travel options out there and some specs comparing them. This is not meant to bash any company at all, simply just trying to do some research. If anyone knows of other kits not listed or think there should be more specs listed please let me know. Hopefully this helps others who are potentially looking at long travel kits.
-Total Chaos:
-3.5” wider/13” of travel
-Included with kit: LCAs, UCAs, brake lines, limit straps, steering extensions, shock mounts
-Camburg:
-JD Fabrication:
-MCM Fabrication:
-3.5” wider/13”-14” of travel
-Solo Motorsports:
-3.5” Wider/14” of travel (long travel)
-Included with kit: LCAs, UCAs, brake lines, limit straps, steering extensions, shock mounts, axles
-4.5” Wider/17-19” of travel (XLT)
-Included with kit: LCAs, UCAs, spindles, brake lines, limit straps, steering extensions, shock mounts?, axles
-BTF Fabrication:
-4.5” wider/14” of travel
-Included with kit: LCAs, UCAs, brake lines, steering extensions, shock mounts, axles
-Marlin Crawler?:
(specs are from 4th gen+ kit, supposedly there will be a kit for us someday)
-2.75” wider/12-14” of travel
-Included with kit: LCAs, UCAs, spindles, brake lines, steering hardware, limit straps
It will probably be a while before I buy a LT kit but right now I’m leaning toward Solo Motorsports, couldn’t find the extra width spec on their regular LT kit.
T4Tophers build (click here)
T4topher is offline   Reply With QuoteReply With Quote
Old 05-25-2021, 07:34 PM #2
Devbot's Avatar
Devbot Devbot is online now
Real Name: Devan
Devbot is just really nice Devbot is just really nice Devbot is just really nice Devbot is just really nice
Devbot's Avatar
Real Name: Devan
Why do you prefer LTIFS to a SAS? Always curious to hear people's reasoning since both are a very large chunk of change and effort
I know nothing of them but off the bat I would also go with Solo Motorsports since they offer the most travel. Might as well go big or go home, right?
Y2K Highlander Millennium Silver 3.4L auto @ 295k and climbing
Tundra TRD Lift in Front / LC Lift in Rear / JBA UCAs / CVJ 9168R Axles / Diff Drop / PCK / Extended Bump Stops; Brake Lines; Sway Bar Links; Rear Diff Breather / True North Fab. Hybrid Bumper / Smittybilt XRC Gen 3 Comp. / Northstar 880CCA AGM / Drivelines NW Rear Shaft / Lil Skip Gas Skid / BudBuilt Front Skid
Devbot is online now   Reply With QuoteReply With Quote
Old 05-26-2021, 12:51 AM #3
T4topher's Avatar
T4topher's Avatar
I wouldn’t say I prefer LT, I actually would prefer an SAS. Especially for the territory around me: Northern California. My problem with doing an SAS is at that point I’m going to want to go all out (links, fabricated housings, etc). Yes the price on LT is high but that SAS would cost ALOT.. Plus the SAS would most likely take quite a bit more time to install. If someday I decide to just go SAS I will probably be able resell the LT kit at a decent price. Solos travel numbers are really nice, the bad thing about their XLT kit is for that cost I almost midswell go SAS lol…
Old 05-26-2021, 11:06 PM #4
midcoma midcoma is offline
midcoma has a spectacular aura about midcoma has a spectacular aura about
Solo's standard LT is +3.5" per side like the rest of them.
I run a SAS on my Tacoma and a Solo LT on my 4Runner. Reason is because the 4Runner is my wife's offroad car and I wanted it to be able to keep up with the truck, but have better road manners for her driving and the kids being in there. With that said, my truck drives awesome with the 4WU SAS, but LT is closer to what my wife is use to.
I went all out on the LT build and it probably cost a little more than half of what the SAS cost. There was significant down time for the vehicle, but it was overall easier. It was easier to reinforce the factory frame components than to cut them off and start new like with SAS. Also not having to worry about significantly modifying the steering system and using a different steering box was much easier.
Another thing not mentioned about Solo is that they offer a fully fabricated spindle. This design replaces the lower ball joint with a uniball and also uses Dana 44 hubs, giving you the option to run manual hubs.
Here's a few shots of mine as I was wrapping up the project.
midcoma is offline   Reply With QuoteReply With Quote
Old 05-26-2021, 11:57 PM #5
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
How do you like having uniball LBJs, notice any squeaking or anything? There was some member that was soon gonna offer OEM sets with a uniball installed, the same ones that Total Chaos uses (forget the manufacturer) - it seemed very appealing at first but after more research I saw endless complaints about them squeaking with many saying thats just name of the game when it comes to using uniballs
Old 05-27-2021, 10:21 AM #6
T4topher's Avatar
T4topher's Avatar
Thank you for posting this, really helpful insight. Did you match the extra width of the LT in the front to the rear?
My end goal is to be able to do the rubicon and fordyce without struggling much, I think with a LT kit Iíd be able to accomplish that.. It will already be hard enough convincing my wife we need LT I canít imagine convincing her we need a SAS haha..
Uni balls are a ton of maintenance if you donít want them to squeak. Probably have to clean and put dry lube in them almost every time you drive it.. Same goes for heims joints..
Old 05-27-2021, 01:03 PM #7
MattJakobs's Avatar
MattJakobs MattJakobs is offline
Real Name: Matthew
MattJakobs has a spectacular aura about MattJakobs has a spectacular aura about
MattJakobs's Avatar
Real Name: Matthew
Originally Posted by T4topher View Post
My end goal is to be able to do the rubicon and fordyce without struggling much, I think with a LT kit I’d be able to accomplish that..
Interested in hearing @theesotericone comment on this
2002 Stellar Blue Pearl - Build Here
Instagram: mattyjako
MattJakobs is offline   Reply With QuoteReply With Quote
Old 05-27-2021, 07:43 PM #8
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
What are you guys using for axles? Don't think it's been mentioned yet
Old 05-27-2021, 08:03 PM #9
theesotericone's Avatar
theesotericone theesotericone is offline
theesotericone is a jewel in the rough theesotericone is a jewel in the rough theesotericone is a jewel in the rough theesotericone is a jewel in the rough
First, you can't compare the Con to Fordyce. Not even remotely in the same level of difficulty.
My first time on the Rubicon we did it in 8 hours. Second time it took us 9 hours but an hour of that was waiting for my buddy Kyle to fix his shit. Neither trip required any rock stacking. The tow strap only came out once in both trips.
When I did Fordyce 2 years ago it took 12 hours. It's not even 1/3 as long. My buddy Andy and I did the whole trail and as far as we know there are VERY few other IFS Toyota's that have done that. It's about as hard a trail as you can do. It's the only trail I've ever completed where when we got to camp I was glad it was over. It's hard the whole way and keeps getting harder. Rocks where stacked and winch line was pulled.
With that said, I don't have LT. If you want to run the Con easily you need 35's, dual lockers and a dual case. You also need to know how to drive off-road. Andy, Kyle and I all have a lot of hard trail miles under our belts.
If you want to run Fordyce you need a desire and skills. I have both but that trail approached the limit of what myself and my rig can do.
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former. --Albert Einstein
theesotericone is offline   Reply With QuoteReply With Quote
Old 05-27-2021, 09:14 PM #10
T4topher's Avatar
T4topher's Avatar
I think some of the kits come with things to extend your axles, RCV is an option, and I think maybe tundra axles is another. Might be more options this would be a great addition to the OP. Not to mention the Dana 44 joints that the solo XLT kit uses..
With that said, I don't have LT. If you want to run the Con you easily you need 35's, dual lockers and a dual case. You also need to know how to drive off-road. Andy, Kyle and I all have a lot of hard trail miles under our belts.
I kinda figured Fordyce was more difficult. Iíve tried it a bit with a buddy and had to turn around maybe a couple miles in (only had 33ís and rear locker). I have 35ís/5.29ís/dual lockers/dual cases now (not fully installed yet) so Iíll just focus on completing the Con for now.. I have the desire, skills I will get with a little more seat time hopefully lol. Very helpful in making my decision of which kit Iíll probably be going with someday.
Old 05-27-2021, 09:23 PM #11
Experience will absolutely come with seat time. It doesn't have to be all hard trails. Even cruising moderate trails will let you learn about where your going to be when you line up a line. Sometimes having that rear tire off by 4" will be make or break.
Sounds like your rigs gonna be plenty capable when you get everything installed. LT is great and I won't steer you away from it but it's not needed in the rocks. If you like the go fast stuff then it's absolutely needed. My rig goes plenty fast but I get left in the dust when hitting the dirt with my LT buddies. lol
Old 05-28-2021, 07:28 PM #12
T4topher's Avatar
T4topher's Avatar
Well Iím more going for rocks than go fast.. Maybe I will just slowly collect SAS parts instead when the time comes..
3.5Ē , kit , long , specs , travel
Cheapest Long IFS long travel Kits? Cap. Morgan General Discussions 19 05-05-2020 02:28 AM
Going long travel on my '06...need some help saulty81 Off-Roading 9 06-25-2019 05:00 PM
Dirt King Long Travel System, 14" Travel - +3.5" Wider - Under 2700 Delivered!! TotalAutomotiveLV Total Automotive Performance 13 07-04-2017 02:32 PM
Long Travel set up HiluxSurfGuy 3rd gen T4Rs 15 06-19-2017 03:12 AM
Long Travel Tooltime19 4th Gen T4Rs 40 01-14-2015 10:05 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
