Old 05-29-2021, 06:49 PM #1
TX4Running's Avatar
TX4Running TX4Running is offline
TX4Running is on a distinguished road
TX4Running's Avatar
Master Cylinder Levels
I bled my brakes last weekend and on two of the wheels the level went down but the other two wheels the level seemed to go up. Upon the last wheel (driver's front), the level was low, so I topped up to the Max. I checked the level after driving all week and found it to be below Max and when I pulled the cap some fluid came out. I wasn't expecting that. With the level below Max I started to add but it only seemed to fill the top section so I stopped. The level in the reservoir didn't increase. The brakes are working fine with no issues. Any thoughts?
Master Cylinder Levels-master-cylinder-jpg
James
2001 4Runner SR5 4WD - 231 mm TBU, B&M 70264 external transmission cooler, Magnefine external transmission filter
TX4Running is offline   Reply With QuoteReply With Quote
brakes , level , max , started , wheels
Is it definitely my master cylinder? dgoll75 3rd gen T4Rs 26 04-13-2021 01:38 PM
ABS master cylinder to one ton master swap? dennisuello 3rd gen T4Rs 3 07-16-2018 07:02 PM
Slave cylinder or master cylinder? That is the question. ieatelk Classic T4Rs 8 07-14-2012 04:54 PM
Master Cylinder, Slave Cylinder Issue bomhour Classic T4Rs 6 01-10-2010 09:14 PM
