Originally Posted by src3
the o2 sensors I installed in my 2000 t4r sr5, auto non cali, were these
toy part #89465-39855 denso part #234-4153 rear or downstream
toy part#894465-80034 denso part #234-4162 front upstream
the part number you provided could be an after market part
Downstream Denso sensor #234-4153 is a fairly universal part (it fits my CA emissions, manual transmission 1999 4runner).
Check out Rock Auto's drill down menu of all sensors for your year / model
here.
I'm not a senor expert by any means but the difference I found with CA vs. Federal emissions was two catalytic converters vs. one - meaning the downstream O2 sensor wire needed to be longer to reach past the second cat. Switch over happened in the mid-1999 model year production run.
I wouldn't be too freaked out if you were getting multiple part numbers showing up for downstream sensor.
Also, stick with the Densos.
