Old 05-30-2021, 06:27 PM #1
TucsonMike TucsonMike is offline
TucsonMike is on a distinguished road
Rear hatch is stuck closed
Guys
Looks like a piece of metal got wedge in the rear hatch latching mechanism and I can't get the hatch to open. When I removed the inside panel and was looking around I just happened to notice this piece of metal wedge between bottom weather stripping and underside of door. My kids were helping my wife move her classroom stuff so could explain where this piece came from.
Appreciate any suggestions u might have in opening door. I did check cable and lever mechanism on latch is moving just wont release door.
Been prying and metal strip to dislodge it but no luck.
Thanks
Mike M
TucsonMike is offline   Reply With QuoteReply With Quote
Old 05-30-2021, 06:54 PM #2
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Is it fully latched or just jammed with the metal in the wedge. If just jammed you may be able to evenly press on the inside with some pressure to get it open. If locked, you going to have to have the latched jammed with something on the open position. Then put pressure from the inside to get it open.
Old 05-30-2021, 07:11 PM #3
Fully shut and unlock. I think the latching mechanism is bound up by this piece which in turn is not fully releasing
Old 05-30-2021, 07:34 PM #4
Got it fixed. It was one of those heavy duty paper clips that u squeeze. I just keep hitting the metal part with screw driver and hammer and it finally dislodged
Old 05-31-2021, 09:09 AM #5
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Great job. At least its fixed..
door , hatch , metal , piece , rear
Rear Hatch Won't Stay Closed NorthernRyan 4th Gen T4Rs 14 09-06-2021 04:20 PM
Actuator Failure Rear Hatch Won’t Stay Closed. I found a Shoelace? Slowgoat 4th Gen T4Rs 3 10-10-2019 02:46 PM
Rattle in rear hatch when opened and closed JCSTEW 4th Gen T4Rs 15 03-26-2019 10:31 AM
rear hatch stuck is stuck tried everything.. tristentrd28 3rd gen T4Rs 4 11-09-2014 12:45 PM
Rear Hatch mechanism DEAD and CLOSED!! Northern Bigdoggy 4th Gen T4Rs 6 12-14-2012 08:53 PM
