Steves (sonoran steel) relocation bracket is meant to be used with the stock links, it pushes the sway bar forward and up, so you actually need shorter sway bar links for the back with this kit, the original rear links work but will be leaning a bit. You only really need to do this if you have a e-locker, I have these on both my 4Runners, last set required some grinding to the supplied parts, poor fitment, easy fix. And I think Roger Brown makes a Aluminum spacer to lower the front sway bar mounts and you add new hardware and press out the studs on sway bar mount bracket. This is the best way, I found the longer 2nd gen links to be to thin of a rod and stud.
