Old 06-05-2021, 03:57 AM #16
Langcow1 Langcow1 is offline
Real Name: Matt
Langcow1 is on a distinguished road
Real Name: Matt
Smile
In the words of The Big Lebowski, my thinking on this case has become very uptight.
You guys are right - I need to start with the top level stuff first. I’d kind of come to the same conclusion in a roundabout way, and did the plugs today. Waiting on wires and coils to arrive from RockAuto and then we’ll see how it goes.
I do think I’ll change the injectors when I eventually tackle the valve cover gasket leak — I just don’t necessarily need to do all that right now, if the plug job gets the misfire.
1999 SR5 manual 4WD; 300,000 miles!
Langcow1 is offline   Reply With QuoteReply With Quote
Old 06-07-2021, 07:13 PM #17
zedjr zedjr is offline
zedjr is on a distinguished road
Originally Posted by Langcow1 View Post
Has anyone tried the remanufactured Denso injectors? For example, this flow matched set:
Set of 6 OEM DENSO Fuel Injectors for 99-04 Toyota Tacoma/4Runner/Tundra 3.4L V6 | AniraMotors
I’m wondering if that’s a good value or if I should steer clear. Thanks -
U can get a kit and reman them urself. The remanned ones do work fine and aren't usually hundreds of dollars
zedjr is offline   Reply With QuoteReply With Quote
Old 06-11-2021, 02:49 PM #18
Real Name: Matt
Real Name: Matt
So far so good. I replaced the plugs, wires, coils and O2 sensors, and cleaned the MAF sensor. Check engine lights are now off and it’s running well - no more misfires (though I’ve only driven 30 miles so far)
I still need to deal with the leaky VC gaskets sometime soon.
I’m a little concerned about the plug install b/c I didn’t have a torque wrench. I tried to not make them too tight but what are the risks if I got that wrong? I did them finger tight plus 1/4 turn with the socket and they felt quite tight to me at that point.
Old 06-11-2021, 04:40 PM #19
Real Name: Matt
Real Name: Matt
Also, a big shout-out to TheDurk in this thread:
02 sensor replacement???
I couldn’t have done the front/upstream O2 sensor (actually an Air/fuel Ratio sensor in my case) without this info. He’s exactly right - you pass the sensor over so you can more easily access the electrical plug. It’s a bit of a pain but do-able. Thanks TheDurk!
- I’m posting this to help future searchers.
Old 06-11-2021, 05:38 PM #20
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
I'm glad you got it figured out! As for spark plug torque, I think you'll be fine where they are at. You might be a little high, but I don't think you're at risk of thread damage or cracking the head.
Old 06-11-2021, 05:56 PM #21
Real Name: Matt
Real Name: Matt
Ok cool - so they’re meant to be fairly snug
Old 09-29-2023, 02:43 PM #22
Dawnpatrol450 Dawnpatrol450 is offline
Dawnpatrol450 is on a distinguished road
Critical flaw in original injectors?
I've been doing a lot of injector research lately, and just ordered 6 of the Motorwest injectors. I found the info below on their site....apparently even a new or rebuilt "brown" injector can have this design flaw? Just FYI to anyone struggling with misfires/ thinking about replacing/ rebuilding injectors....
After years of research and development, we are discontinuing this product and introducing and more reliable and cost effective Denso injector replacement.The original 23250-62040 (brown) injectors have an internal solenoid defect that fails over time, with high mileage engines being the most affected by this.
The symptoms begin as an intermittent random misfire. The issue then becomes ongoing when the vehicle reaches normal operating temperature. Finally the internal injector solenoid dies and the misfire becomes permanent.
The great news is we now offer a solution to solve the issue permanently. We are so confident in the replacement injector’s reliability that we are offering Lifetime Warranty on every unit sold!
The Denso replacements can be found by clicking here, or searching our store for part number HP831.
Link: Denso Fuel Injector Replacement Set for 3.4L V6 4Runner Tacoma and Tundra - HP831 (Naturally Aspirated 5VZ-FE only) | MotorWest Performance
Dawnpatrol450 is offline   Reply With QuoteReply With Quote
Old 09-29-2023, 05:08 PM #23
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Interesting, says they're not compatible with superchargers. I wonder why/how that could be(?)
Old 09-29-2023, 09:51 PM #24
Originally Posted by T4topher View Post
Did this in my build thread somewhere as well.. cost a can of carb cleaner and like 20-30$ for the rebuild kit. They don’t make all the little parts oem anymore so you gotta get it off eBay. Toyota still sells the o-rings/seals but not the filters/Pintle caps (as far as I could find anyways..)
Bumping this. Recently I replaced spark plugs and the proof is in the pudding. All spark plugs looked identical, meaning the injectors were all flowing even.
clear , good , injectors , remanufactured , steer
Remanufactured Created Engine goatfarmer Classic T4Rs 5 12-24-2016 06:55 PM
Remanufactured 3vze NC or VA Gremcat Classic T4Rs 1 02-26-2016 11:07 PM
Source for Remanufactured 1GR-FE? 054runnerNJ 4th Gen T4Rs 14 08-30-2015 11:46 PM
Remanufactured Engine Bishard Classic T4Rs 2 08-19-2012 02:47 PM
Remanufactured wheel kai920 4th Gen T4Rs 5 02-01-2011 11:08 AM
